 Forum index » Discussion » Introduce Yourself
Here I am, and looking for S10430 information
Page 1 of 1 [5 Posts]
chris_burrell
PostPosted: Mon Jan 31, 2011 3:16 am    Post subject: Here I am, and looking for S10430 information Reply with quote  Mark this post and the followings unread
Greetings from cold Scarborough UK.
I am a maker of retro components to help people keep their older electronic instruments working.
It gives me great pain that the original manufacturers basically disown their products after a certain amount of time. The newer the product the shorter the time.
So, for the sake of keeping things running we make retro components - similar to the originals but which function in exactly the same way; well as exactly as one can!
I have had a few enquiries for the S10430 keyer / divider used in Korg delta and lambda instruments (to name a couple) and have not been able to find the data sheet. It was an AMI product and was listed in their 1979 AMI MOS Products Data Book.
Can anyone help please?
Kind regards
Chris Burrell
freddp
PostPosted: Sun Jan 01, 2012 11:37 am    Post subject: Reply with quote  Mark this post and the followings unread
here:
Please give us needing ones a ling to your venture Smile
S10430.pdf
 Filename:  S10430.pdf
 Filesize:  250.7 KB
 Downloaded:  599 Time(s)
chris_burrell
PostPosted: Mon Jan 02, 2012 1:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you for that freddp.
I will see what can be done and post a link if and when there is a solution. These are notoriously tricky things to retro as they use relatively high supply voltages - most modern parts are relatively low.
Kind regards
Chris
NerveJam
PostPosted: Mon Apr 11, 2016 12:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm guessing you didn't have any luck with replicating the s10430, then?
Shame, as I'm just up the coast from you, and looking for one (or more)..
https://synteknik.com
soundworker
PostPosted: Tue Aug 30, 2016 12:53 pm    Post subject: S-10430 sources Reply with quote  Mark this post and the followings unread
Look here:
http://electro-music.com/forum/post-421593.html#421593
