micromusic
Posted: Tue Apr 12, 2016 10:53 am Post subject:
Germanium diode |
Hi
Any one more knowledgeable than me know what to replace an OA95 with a modern equivalent, I can get some but would be easier if Rapid ,Farnell RS etc would have an alternative
Thanks |
Joined: Apr 03, 2004 Posts: 24513 Location: The Netherlands, Enschede
Posted: Tue Apr 12, 2016 11:09 am Post subject:
It depends on what they are used for .. like in a distortion circuit you'd probably want to use Germanium as has a lowish voltage drop which kicks in slowly ... when softness is not needed, for the voltage you could use a Schottky type .. when the exact volltage is not interesting a silicon diode or even an LED.
The OA95 very much is a general purpose diode, so for types it could just be a general purpose thing too - provided the design constraints dont get in the way. _________________ Jan
Joined: Nov 23, 2015 Posts: 1319 Location: Netherlands
Posted: Tue Apr 12, 2016 12:18 pm Post subject:
| also, not known to everybody: when the black paint is damaged or (partially gone) the diode get very sensitive to (changes of) light. |
Posted: Tue Apr 12, 2016 12:26 pm Post subject:
There is ungodly amounts of variation in Ge diodes, even within the same production code. Same with Ge transistors.
If you're able to, socket the position and audition a few diodes. I've got a bagful of Russian D9D diodes I just use. |
sompost
Posted: Fri Apr 15, 2016 1:22 am Post subject:
In the ASM-2 synth that I'm building, the designer suggests using a 1N34A as a substitute for the OA95.
But I'm just an ignoramus. _________________ Built: MFOS SLMS plus, SL Ultimate & Expander, 10 step seq; SLMS MkII; PAiA FatMan, Mutable-Instruments Shruthi-1; Jasper Wasp Clone
Backlogging: MFOS 16 step seq; TH SN Voice; Takeda One Board Farm; Okita Vocoder; Page TR-9090; TH GM Voice, AY Voice |
sompost
Posted: Fri Apr 15, 2016 4:51 am Post subject:
I'd say it depends on the details of the circuit. In his suggestion "my designer" wrote: "Any germanium will work fine here" (magic word: "here"). So there appear to be situations where a 1N34A will do the trick if you can't get OA95s. In all honesty, I'm the not most qualified person to tell.
In any case, I believe you can still get OA95s at places like utsource.com or on ebay.
Ralph _________________ Built: MFOS SLMS plus, SL Ultimate & Expander, 10 step seq; SLMS MkII; PAiA FatMan, Mutable-Instruments Shruthi-1; Jasper Wasp Clone
Posted: Fri Apr 15, 2016 7:29 am Post subject:
thats why i wrote:" i tend to..."  |
Posted: Fri Apr 15, 2016 11:37 am Post subject:
| How is it used? The BOM indicates it's in the VCO, but I can't find a schematic. |
Posted: Fri Apr 15, 2016 2:15 pm Post subject:
| Grumble wrote: | | also, not known to everybody: when the black paint is damaged or (partially gone) the diode get very sensitive to (changes of) light. |
I was confused with the OA71  |
