help me understand 10step seq
Page 1 of 1 [4 Posts]
Karlisss
PostPosted: Wed May 18, 2016 10:58 am    Post subject: help me understand 10step seq Reply with quote  Mark this post and the followings unread
Hi
Can someone explain, why there is 10 step sequencers, or 7 step seq. (Like serge)
Are those can be driven as 4/4 for mfos excluding 2 last steps and last 3 steps for serge?
Or they is ment for polyrythms?
Can 10step seq be builded as 8step?
PostPosted: Wed May 18, 2016 7:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Most 10 step sequencers use the 4017 counter, which can be set to between 1 and 10 steps.
PostPosted: Thu May 19, 2016 6:10 am    Post subject: Re: help me understand 10step seq Reply with quote  Mark this post and the followings unread
In addition to AlanP's succinct answer, yes, you just have to take the step 9 output and tie it to the reset pin of the 4017. Commonly these are built with a rotary switch that lets you determine which step resets the sequencer and thereby controls the number of steps.
PostPosted: Thu May 19, 2016 7:13 am    Post subject: Reply with quote  Mark this post and the followings unread
as for why does it exist. You can create different time signatures and using multiple sequencers with a different number of steps can create
more variation and interesting patterns. And although sequencers are often used to control the pitch of a VCO you can of course use it to
control anything that accepts a control voltage. For example an 8 step sequencer controlling the pitch of a VCO with a 5 step sequencer
controling a VCA can create changing accents on notes.
