Midi CC Problem
Page 2 of 2 [31 Posts]
Goto page: Previous 1, 2
Audio files: 329
PostPosted: Sun Jun 05, 2016 3:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
The idea is that you should be able to do whatever suits you best there ... both ways should work. Oh and re. miditangle vs. NetMidi, they should act the same.
One other thing is that CC mapped controls will not send CC values when the mapped control is changed in the editor (with mouse or keyboard), they can only listen. I could change that I guess at some stage.
PostPosted: Sun Jun 05, 2016 5:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
. . . CC mapped controls will not send CC values when the mapped control is changed in the editor (with mouse or keyboard), they can only listen. I could change that I guess at some stage.
I have not gotten to generate midi values (notes or CCs) to send outside of wren. I did try to have wren send midi notes to another softsynth, but I didn't figure out how to set it up properly. Maybe another time.
PostPosted: Mon Jun 06, 2016 5:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Any incoming MIDI is assembled into proper messages, taking running status into account.
Then the message is sent into the patch where any special MIDI modules get a chance to pick it up according to the message content and the settings for that module.
I will assume this means the modules like CCMidiIn and NoteMidiIn.
Then when the message is a MIDI CC message and the receive channel for Wren matches the message's channel
I will assume this refers to the global CC assignments that currently use the midi channel as assigned in Settings/NetMidi-MidiTangle.
(or when Wren is set to receive in OMNI mode, meaning it processes all channels) a possibly matching CC to knob assignment is being processed. For this the whole CC range of 0 to 127 is mapped onto the actual number of knob positions available.
Again, I will assume this refers to the global CC assignments.*
Steve
*Addendum 1:
The value module (see screen shot I posted showing 16 CC knobs coming from the nanoKontrol) does indeed display 0 to 127. In addition, when the CC is globally mapped to the freq. knob in the osc., a midi value of 0 corresponds with the lowest possible freq value so far as I tested and a midi value of 127 corresponds to the highest possible frequency value.
Audio files: 329
PostPosted: Mon Jun 06, 2016 10:31 am    Post subject: Reply with quote  Mark this post and the followings unread
A channel for MIDI CC's .. hmm .. you really need more than 120?
lamptablecomputer
PostPosted: Wed Jun 08, 2016 11:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for fixing the midi cc problem Jan!
Audio files: 329
PostPosted: Wed Jun 08, 2016 11:10 am    Post subject: Reply with quote  Mark this post and the followings unread
You're welcome - please let me know about other issues ... I'm still finding some myself as well.
