modular perfboard lunetta
Page 1 of 1 [10 Posts]
trav
PostPosted: Thu Jan 14, 2016 11:30 pm    Post subject: modular perfboard lunetta Reply with quote  Mark this post and the followings unread
I've been dreaming up a perfboard lunetta for a while and have finally started building the modules, so thought I'd document it here.
First the enclosure. It fits eleven boards, five along each of the top two rows and one more bottom right, which will be my "modules". If I build more I can swap them in and out as required (or just build another box!). For the interconnect I'll use pin headers; you can see my bundle of female-female cables in the leftmost storage compartment in the bottom row. The rightmost compartment holds the wall wart that will power everything. In the center there's a handy breadboard which flips up; underneath I keep jumpers for adjacent pins and jumper wire for the breadboard.
 Filesize:  319.11 KB
 Viewed:  537 Time(s)
 Filesize:  356.33 KB
 Viewed:  529 Time(s)
trav
PostPosted: Fri Jan 15, 2016 12:27 am    Post subject: Reply with quote  Mark this post and the followings unread
4520 tone generator
First I need some square waves. Put a fairly high frequency clock into the blue pin at the top and produced at the bottom are four octave divisions of seven pitches in the key of lunetta. The pins in the top right are for power. In general I'll use multiple pins per input/output where I think it might be useful. This includes power pins, since daisy-chaining will probably be tidier than patching them all to one board. It could also be convenient to have some logical 1s and 0s close to hand for some modules. Digital inputs have 87k pull-down resistors, outputs have diodes.
See this thread for circuit details.
 Filesize:  196.89 KB
 Viewed:  517 Time(s)
trav
PostPosted: Wed Jan 20, 2016 2:20 am    Post subject: Reply with quote  Mark this post and the followings unread
4067 16-step sequencer
The four-bit binary count top left determines which channel is active. Next to it is an inhibit pin, and then the common input/output. The top row of each double row of 16 pins is connected to the mux channels so can be used as a standard mux. The main usage I envisage, though, is as a drum sequencer: you set up your pattern with jumpers and feed a trigger into the common input, then you can get four different trigger patterns at the single pins on the end of each row.
Stupidly I did not realise I would need the diodes to prevent the four patterns interacting until I had built it, so I'll need to fix this when I get some more 1N4148s. Alternatively the pattern rows could be female headers and I could use diodes instead of jumpers...
 Filesize:  17.82 KB
 Viewed:  554 Time(s)
 Filesize:  145.86 KB
 Viewed:  512 Time(s)
 Filesize:  151.87 KB
 Viewed:  477 Time(s)
PostPosted: Sun Jan 31, 2016 5:30 am    Post subject: Reply with quote  Mark this post and the followings unread
looks like that's going to be a nice system Very Happy
did you make the nice box yourself from scratch ?
trav
PostPosted: Sun Jun 26, 2016 1:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Finally getting back onto this after moving house and getting caught up with other things. Yeah, box is from scratch; a few things I might have done better, but it keeps things tidy and portable. Last week I wired in power: I had been daisy-chaining it with patch cables, but this started to seem silly.
Today's module is a lot simpler and less crowded than the first two: three square/triangle oscillators using a 40106 and 4069, plus a high-frequency oscillator to run the tone generator. It was tempting to crowd the board with six oscs and not waste gates, but I have plenty of audio frequencies from my first module, and I plan on building a master counter for low-frequency stuff from a 4060, which has an oscillator on the chip.
 Filesize:  183.36 KB
 Viewed:  439 Time(s)
trav
PostPosted: Sun Jul 03, 2016 12:56 am    Post subject: Reply with quote  Mark this post and the followings unread
4060 master clock & pseudo-random bit generator
 Filesize:  156.68 KB
 Viewed:  462 Time(s)
PostPosted: Sun Jul 03, 2016 8:00 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't really build anything, but I am enjoying following your progress here. I do enjoy reading easy-to-follow projects, like the ones you have posted so far. Also, I like the case; it seems portable and handy.
Steve
trav
PostPosted: Thu Jul 07, 2016 2:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, Steve.
Last night I soldered up two of the 4066 VCA of sorts. Each has a cap which can be attached to the output with a jumper: a simple way of smoothing stepped CV from R2R ladders, for example, or turning gates/triggers into percussive sounds. Since my square waves come through diodes, I can feed a few different frequencies straight into the control pin and get some neat sounds. The caps range from 1uF to 100uF
 Filesize:  170.44 KB
 Viewed:  463 Time(s)
trav
PostPosted: Tue Jul 12, 2016 6:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
The next module has a whole bunch of CV generators: 3 gate-to-triggers, 2 ramp-up/ramp-down/triangle stepped voltage generators, and 2 3-bit R2Rs.
 Filesize:  24.06 KB
 Viewed:  472 Time(s)
trav
PostPosted: Wed Jul 13, 2016 3:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's a picture.
 Filesize:  185.19 KB
 Viewed:  387 Time(s)
