Adventures in Sound
Page 42 of 50 [1226 Posts]
Goto page: Previous 1, 2, 3, ..., 40, 41, 42, 43, 44, ..., 48, 49, 50 Next
Audio files: 281
PostPosted: Thu Jul 07, 2016 10:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's the recording for Episode 280 - Into Infinity
This one has no looping, just op-1, microgranny, 2 ipads, ipod, blofeld and tenori-on
On the op-1 I used the tombola sequencer to get some randomised drones, the blofeld was triggered by the tenori-on's 'push' mode, the i-devices were running animoog, cubesynth and samplewiz and the microgranny was used for sampled drones
Adventures_In_Sound_280_060716.mp3
Adventures In Sound - Episode 280 - Into Infinity
 Filename:  Adventures_In_Sound_280_060716.mp3
 Filesize:  57.38 MB
 Downloaded:  2188 Time(s)
Audio files: 281
PostPosted: Wed Jul 20, 2016 2:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Tonight's Adventures In Sound, 2 OP-1s into 2 DD-20s, with 18 and 22 second loops, producing loops that only repeat every 6.6 minutes Cool
Audio files: 281
PostPosted: Fri Jul 22, 2016 10:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's the recording for Episode 281 - Binary Operators Squared
This one was just 2 op-1s, 2 dd-20s, mixer and pandora mini for reverb and delay. The dd-20s were set to loop lengths of 18 and 22 seconds, resulting in loops that only lined up every 6.6 minutes Very Happy
Adventures_In_Sound_281_200716.mp3
Adventures In Sound - Episode 281 - Binary Operators Squared
 Filename:  Adventures_In_Sound_281_200716.mp3
 Filesize:  57.51 MB
 Downloaded:  2170 Time(s)
Audio files: 281
PostPosted: Wed Aug 03, 2016 2:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Tonight's Adventures In Sound will be an ambient drone excursion featuring the Roland JD-Xi Smile
Audio files: 281
PostPosted: Thu Aug 11, 2016 1:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
better late than never Smile
Here's the recording for Episode 282 - JD-Xi Ambient Drone Excursion
Here's the setup
just JD-Xi and looper Smile
Adventures_In_Sound_282_030816.mp3
Adventures In Sound - Episode 282 - JD-Xi Ambient Drone Excursion
 Filename:  Adventures_In_Sound_282_030816.mp3
 Filesize:  58.26 MB
 Downloaded:  2152 Time(s)
Audio files: 281
PostPosted: Wed Aug 17, 2016 2:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Tonight's Adventures In Sound will be OP-1 through microbrute, it could get a bit noisy!
Audio files: 281
PostPosted: Mon Aug 22, 2016 6:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's the recording for Episode 283 - OP-1 & Microbrute Noise Ambients
Here's the rather simple setup, op-1 run through microbrute into dd-20
This one turned out quite raw, noisy and experimental Smile
Adventures_In_Sound_283_170816.mp3
Adventures In Sound - Episode 283 - OP-1 & Microbrute Noise Ambients
 Filename:  Adventures_In_Sound_283_170816.mp3
 Filesize:  59.72 MB
 Downloaded:  2173 Time(s)
PostPosted: Tue Aug 23, 2016 11:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
I like how that sounded raw, but didn't have that teeth-vibrating digital high-pitch whine Smile
Audio files: 281
PostPosted: Wed Aug 24, 2016 2:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Smile
Audio files: 281
PostPosted: Wed Aug 31, 2016 1:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
If my internet holds out, tonight's Adventures In Sound is going to be just looped Blofeld, controlled by Keystep Smile
PostPosted: Wed Aug 31, 2016 4:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, it performed like over 80% Ok I think, and it was very nice!
(but I hope the recording will be better even!)
Audio files: 281
PostPosted: Thu Sep 01, 2016 3:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Cheers Jan, once I realised it was dying I managed to record the end separately so have got most of the show and have stitched something together Smile
PostPosted: Thu Sep 01, 2016 6:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool
Audio files: 281
PostPosted: Thu Sep 01, 2016 10:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's the recording for Episode 284 - Looped Blofeld Improvisations
This one used a very simple setup, Blofeld into DD-20 for looping, controlled by Arturia Keystep midi controller keyboard Smile
I spent most of the preparation time for this set going through my Blofeld sounds and assigning modulation and aftertouch to sound parameters that produced interesting timbral changes, such as opening filters, controlling LFO modulation depth, increasing oscillator FM, sweeping through wavetables, increasing LFO speed etc
Adventures_In_Sound_284_310816.mp3
Adventures In Sound - Episode 284 - Looped Blofeld Improvisations
 Filename:  Adventures_In_Sound_284_310816.mp3
 Filesize:  55.05 MB
 Downloaded:  2044 Time(s)
Audio files: 281
PostPosted: Mon Sep 05, 2016 4:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm in the USA when the next show is due, so am uploading a backup episode just in case Smile
Audio files: 281
PostPosted: Tue Sep 27, 2016 6:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've got a gig tonight, so have just uploaded a show to the non-downloadable playlist Smile
Hopefully someone will find it and play it Very Happy
PostPosted: Wed Sep 28, 2016 2:46 am    Post subject: Reply with quote  Mark this post and the followings unread
got it Very Happy
Audio files: 281
PostPosted: Wed Sep 28, 2016 3:43 am    Post subject: Reply with quote  Mark this post and the followings unread
got it Very Happy
Thanks Very Happy
PostPosted: Wed Sep 28, 2016 11:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool
PostPosted: Wed Sep 28, 2016 4:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
well done well done
Audio files: 281
PostPosted: Wed Sep 28, 2016 6:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
well done well done
Thanks Jan Smile
Audio files: 281
PostPosted: Sun Oct 09, 2016 3:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's the recording for Episode 285 - Metalvoiddrones
This was a studio improv from 29th December 2014, an early attempt at a drone set that didn't use looping
From memory this was ipads, op-1, microbrute and microgranny
Adventures_In_Sound_285_140916.mp3
Adventures In Sound - Episode 285 - Metalvoiddrones
 Filename:  Adventures_In_Sound_285_140916.mp3
 Filesize:  55.24 MB
 Downloaded:  1993 Time(s)
Audio files: 281
PostPosted: Sun Oct 09, 2016 4:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's the recording for Episode 286 - OP-1 Dronambients
This was recorded in the middle of the night the night before it was broadcast, in a strange feverish state, using 2 OP-1s and DD-20 for looping
Adventures_In_Sound_286_280916.mp3
Adventures In Sound - Episode 286 - OP-1 Dronambients
 Filename:  Adventures_In_Sound_286_280916.mp3
 Filesize:  56.77 MB
 Downloaded:  2007 Time(s)
Audio files: 281
PostPosted: Wed Oct 12, 2016 1:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Tonight's Adventures In Sound is entitled 'Space 1672' and will feature manual flanging and grain shifting, and possibly a bit of sequencing in between the spacey bits Smile
Audio files: 281
PostPosted: Thu Oct 13, 2016 11:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's the recording for Episode 287 - Space 1672
This episode was brought to you by the OP-1, electribe 2 and effects 16 and 72 of the mini KP Smile (with reverb and looping from mini pandora and DD-20)
Adventures_In_Sound_287_141016.mp3
Adventures In Sound - Episode 287 - Space 1672
 Filename:  Adventures_In_Sound_287_141016.mp3
 Filesize:  58.29 MB
 Downloaded:  2049 Time(s)
