Automatically switch between midi clock or patch's clock gen
Page 1 of 1 [5 Posts]
gauthier
PostPosted: Wed Oct 05, 2016 11:10 pm    Post subject: Automatically switch between midi clock or patch's clock gen
Subject description: Make sequenced patches more versatile
There are few sequenced patches in my synth, although they use internal clock generator.
When I connect to my sequencer, I'd like to use the midi clock instead so I figured I could easily put a fader to swap between the two clocks.
I see on Midi Clock module there is a "Active" port, and I wonder how I can make a generic clock depending on the fact that "Active" port has signal and if not use the internal clock gen of the patch.
I'm not yet familiar with the logic modules but seems someone more knowledgeable would probably be able to patch this and share this with us easily Smile
Thanks for the help!
 Filesize:  15.62 KB
 Viewed:  8011 Time(s)
Audio files: 303
PostPosted: Thu Oct 06, 2016 3:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
How about this one?
I did not test it though.
gauthier
PostPosted: Thu Oct 06, 2016 3:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey I think I tried that one but might not have tried the correct value on that x-fader knob, will give it a shot at night.
gauthier
PostPosted: Thu Oct 06, 2016 10:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Got it working eventually, had to swap 1 - 2 and push X-fade knob all up and 1-2 knob all down.
 Filesize:  67.81 KB
 Viewed:  559 Time(s)
auto.clock.picker.pch
Internal and external clock being chosen automatically depending on presence of external clock.
 Filename:  auto.clock.picker.pch
 Filesize:  828 Bytes
 Downloaded:  637 Time(s)
Audio files: 303
PostPosted: Fri Oct 07, 2016 6:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Great :-)
