TR-808MC
Page 1 of 1 [13 Posts]
PostPosted: Sun Mar 30, 2014 7:33 am    Post subject: TR-808MC
Subject description: 3x TR-808 Cowbell clone
I accidentally received some stripboard instead of the usual pad-per-hole perfboard, so I made 3 TR-808 cowbell clones using the beautiful stripboard
layouts posted by minus here.
this is how it looked before I added the oscillators and mixer to the board.
One cowbell will be tuned at the original TR-808 frequencies, the other two have adjustable tuning and besides the build in oscillators an external
source can be used aswell. I did some tests using a VCO which resulted in a short track posted here. Cool
I'm using 555's in monostable mode to provide a short trigger pulse which can be adjusted. It can also be switched to gate mode in which case the
trigger length is set by the trigger input signal. Each cowbell has it's own accent input and level control for which I used part of the original TR-808
circuit. The mixer circuit also came from the original TR-808 schematic.
TR808MC: oscillators, mixer, accent & trigger control
 Filesize:  84.57 KB
 Viewed:  1102 Time(s)
TR-808MC: front panel design
 Filesize:  322.52 KB
 Viewed:  731 Time(s)
PostPosted: Sun Mar 30, 2014 7:40 am    Post subject: TR-808MC case Reply with quote  Mark this post and the followings unread
I cut some scrap shelves into pieces to make a case similar to the CR-78, I'll probably gonna stain the wood or treat it some other way.
TR-808MC case
 Filesize:  98.67 KB
 Viewed:  673 Time(s)
TR-808MC case
 Filesize:  60.32 KB
 Viewed:  670 Time(s)
TR-808MC case
 Filesize:  65.89 KB
 Viewed:  651 Time(s)
TR-808MC case
 Filesize:  69.34 KB
 Viewed:  649 Time(s)
TR-808MC case
 Filesize:  89.88 KB
 Viewed:  660 Time(s)
PostPosted: Mon Mar 31, 2014 6:03 am    Post subject: TR-808MC - wiring it up Reply with quote  Mark this post and the followings unread
wiring up the frontpanel (the lighter was there to hold some wires in place, forgot to take it out for the photos Embarassed )
TR-808MC - wiring
 Filesize:  132.48 KB
 Viewed:  647 Time(s)
TR-808MC - wiring
 Filesize:  127.26 KB
 Viewed:  671 Time(s)
PostPosted: Mon Mar 31, 2014 7:30 am    Post subject: TR-808 MC - more wiring Reply with quote  Mark this post and the followings unread
some more wiring (almost done) Cool
TR-808MC - wiring
 Filesize:  118.42 KB
 Viewed:  679 Time(s)
PostPosted: Mon Mar 31, 2014 1:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the wiring photos... looks lovely. Well, apart from needing MORE COWBELL!
James.
PostPosted: Mon Mar 31, 2014 10:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Utterly brilliant panel. I want to hear it Smile
PostPosted: Wed Apr 02, 2014 1:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks guys Very Happy
did you hear MoooonCows ?
I tried to record some new sounds using the Bandersnatch to trigger the cowbells, but I ended up playing mostly with that one instead Cool
Here's a photo of it all wired up. I still have to drill some mounting holes, stain the case, and get some knobs (that might take a while).
TR-808MC all wired up
 Filesize:  117.94 KB
 Viewed:  671 Time(s)
PostPosted: Wed Apr 02, 2014 2:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have now Very Happy Excellent....
Audio files: 161
PostPosted: Sat Apr 12, 2014 10:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Very nice build Phobos , love the panel Smile .... Max Zorran Very Happy
PostPosted: Mon Oct 17, 2016 3:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
finally, after 2.5 years (can't believe it's been that long) I found some knobs Razz
TR808MC
 Filesize:  235.85 KB
 Viewed:  591 Time(s)
TR808MC
 Filesize:  238.08 KB
 Viewed:  548 Time(s)
TR808MC
 Filesize:  227.07 KB
 Viewed:  591 Time(s)
PostPosted: Mon Oct 17, 2016 5:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
You stole them from somebody's jasper, didn't you? Wink
PostPosted: Tue Oct 18, 2016 11:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry; nothing is funny around here any more. JMO
PostPosted: Wed Oct 19, 2016 2:54 am    Post subject: Reply with quote  Mark this post and the followings unread
silent (actually I got them from ebay)
MusicMan11712 wrote:
Can you play "These Knobs Are Made For Walken" on that? Laughing
