<on air> Twyndyllyngs - not cancelled tonight Chez Mosc
My project
Page 1 of 3 [52 Posts]
Goto page: 1, 2, 3 Next
Cfish
PostPosted: Tue Nov 29, 2016 8:08 am    Post subject: My project Reply with quote  Mark this post and the followings unread
My dream is becoming reality.
I decided to open this thread to ask questions and solicite advice.
I would firs off like to thank all of you that have made this an obtainable dream for a man with my limited education. With special thanks to
PhoBos
And elmigel
Everything I have so far is built on perf. I will give a quick overview of where it's at so far.
Lower rack
Midi to cv. ( built from a cluster of schematics, analog is Ray Willson)
VCO1. (Thomas Henrey, built with tl071s so I could get in and experiment)
Divider mixer ( based loosely on valve wizard sub octave)
4017 8 channel 2 line sequencer
4 Chanel mixer and patch bay
E.G. VCA Basic LFO combo
E.G. VCA combo
Basic drum sound module. (Closer to metronome sounds for practice)
Low pass VCF and pink noise
Second rack is to be an independent but complementary improvement rack.
VCO1 triangle core only ( I intend to use it mostly to drive first VCO)
4 Chanel 1 line sequencer ( syncable compliment to 8 Chanel)
Divider. More advanced than first
6 channel mixer ( realized 4 channels on first one weren't enough)
Dual VCA (13700 based. Pretty close to application sheet)
Now the questions can begin.
I'm looking for different ADSR recommendations. I will be building it dual in the one wide blank I have in the top rack. My first two EGs are 555 AR types.
I want high quality with these ADSRs so I can leave the ARs as utility spares.
Any suggestions of schematics or dual ADSR kits are welcome.
I am on 15v+-
 Filesize:  1.4 MB
 Viewed:  549 Time(s)
PostPosted: Tue Nov 29, 2016 9:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Right here in the other forum Smile
http://electro-music.com/forum/topic-54641.html
PostPosted: Tue Nov 29, 2016 9:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
BTW, two more things
1) Your rig looks awesome, good job!
2) The schematics vault is a great resource when looking for circuit ideas
http://electro-music.com/wiki/pmwiki.php?n=Schematics.Schematics
Cfish
PostPosted: Wed Nov 30, 2016 6:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Elmegil
LFLab
PostPosted: Wed Nov 30, 2016 11:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
100m ADSRs are highly recommended, love them.
For slow envelopes, the Thomas Henry CMOS ADSRs.
Cfish
PostPosted: Mon Dec 12, 2016 6:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Quick question???
In the Thomas Henrey ADSR recommended above, there is an extra connection at the trigger and gate input.
Are these connections that break when something is plugged in the jack?
If so, what are these type of jacks called? I have 1 from an organ headphone jack, but am not sure what to call it to order anouther.
 Filesize:  844.33 KB
 Viewed:  452 Time(s)
PostPosted: Mon Dec 12, 2016 7:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes that is exactly what that means.
Normally it's called a switched jack. 1/4" jacks would be like a Switchcraft 112AX
http://www.mouser.com/Search/ProductDetail.aspx?qs=iwvYsH9bSFbeNolTVXhbQQ%3d%3d
PostPosted: Mon Dec 12, 2016 8:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
They're also sometimes called normalized connections.
Cfish
PostPosted: Tue Dec 13, 2016 12:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks guys. Having correct name for things makes them so much easier to order.
Cfish
PostPosted: Mon Jan 09, 2017 4:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
So I love building modules, but was really wondering how my modules compair to others, so I cheated and purchased a few.
Im actually even more happy with my perf board home built after the true test comparison. However it was nice to add all the virsitility of the top rack all at once.
 Filesize:  1.07 MB
 Viewed:  445 Time(s)
PostPosted: Mon Jan 09, 2017 9:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
You... spent money on a finished module?
Stingy bugger that I am, the most I'll do is buy a full kit.
PostPosted: Mon Jan 09, 2017 10:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
That just looks awesome!
Could you post a picture taken from the front so we can have a peek to what your synth looks like now?
Cfish
PostPosted: Tue Jan 10, 2017 5:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi guys
Yes I did AlanP. However I did find half of them very reasonable on eBay second hand. So that made doing a purchased rack of modules within my grasp.
Purchased the rest from lower west side (flareless on here) and synthesizers.com.
Actually turned out that if you purchas a blank 5u panel, purchas that style of knobs, and purchas a good ADSR board kit. At 95$ American the synthesizers.com ADSR is about 15 dollars more than the integrated parts.
Was a Merry Christmas to me present. Got about 800 US in the hole top rack. I thought that was pretty darn reasonable. The CGS01 from Lower west side is my favorite purchased module. Though I could do everything it does with my home built gear, it is so convenient to have it all in one module. (Odd divides, even divides, a quasi ring mod, and a mixer) layd out very nicely, I must add.
Hi Grumble
I think this is what you are looking for.
Am trying water slide decals on my modules. ( really don't want to take my sequencer apart to do a better graphics job)
Water slide decal paper is looking a lot better.
 Filesize:  1.02 MB
 Viewed:  414 Time(s)
PostPosted: Tue Jan 10, 2017 5:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, thats part from what I meant, was curious about the top part you bought at Ebay Embarassed
Cfish
PostPosted: Tue Jan 10, 2017 5:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Ok. Here you go.
From left to right
Dotcom VCO
Lower west side CGS01
Lower west side Barton switched resistor VCF
Dotcom state variable filter
Dotcom ADSR
Dotcom VCA
Dotcom ringmodulator
Dotcom mixer
 Filesize:  923.61 KB
 Viewed:  401 Time(s)
PostPosted: Tue Jan 10, 2017 6:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Realy nice! Thats a complete modular synth you have there!
*drewls*
Cfish
PostPosted: Tue Jan 10, 2017 7:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Grumble
While each rack of my synth is different and complimentary.
My goal was to have each rack also be an independant synth on its own.
I can haul the top keyboard and bottom rack to rehearsals and be able to get buy.
Not that I play out much any more. A guy can still Dream LOL
PostPosted: Tue Jan 10, 2017 7:25 am    Post subject: Reply with quote  Mark this post and the followings unread
I have two syths (one modular and one not) and several keyboards, but can't play...
NoSkilzz lol
alanwilder81
PostPosted: Tue Jan 10, 2017 7:26 am    Post subject: Reply with quote  Mark this post and the followings unread
fuck's sake Chris ! i love those two new synthesizers sitting on top of the pile.
there s something about that raw and unrefined wood cabinet. i like the amateurish look most DIY synths have,as opposed to that of the synths you can buy off the shelf.
never been a fan of that polished, new breed of modern analog synths.
i believe in making cabinets from scratch,although imperfect. they drip character in my view. Cool Cool
Cfish
PostPosted: Tue Jan 10, 2017 7:54 am    Post subject: Reply with quote  Mark this post and the followings unread
I have no skill at synth either Grumble. I'm a guitar player. I mostly use everything through my bass pedals, which I use to fill in a lot.
LOL the mistakes really stand out when you make a mistake on 2 instruments at the same time.
THanks Alanwilder81. I'm going for a little more refined finished product. However I'm not going for factory built look. Things should have a little Character.
LOL speaking of Character, there is an odd tradition amongst a lot of the musicians around here to put the first scratch or dent in any new guitar you buy before you leave the store. Gets it out of the road, so you can focus on playing the thing.
Will never forget the look on a store owners face in a much larger town, when my brother purchased a 1500 dollar guitar, asked to borrow a drum stick, and put the first ding in the back. LOL was priceless!!!
alanwilder81
PostPosted: Tue Jan 10, 2017 8:26 am    Post subject: Reply with quote  Mark this post and the followings unread
chaps,
i can't play keyboards either, but all in all, who give's a crap ? Laughing Laughing Laughing
i love synthesizers from a technician-engineer standpoint. Or sound designer if you will. You press one key and you have a sound. You tweak it, you mould it, you hammer it. that's what synths are made for,ultimately. Exploring sound and creating atmospheres.
it's not all about performing Smile the wankfest showoffs of those musicians playing hundred notes in a bar never appealed to me.
and lets not forget that a synth is the very punk instrument, as mr Daniel Miller, former Depeche Mode producer often claims. In that it's the DIY attitude that plays a major role in electronic music production
it doesnt take skills to play a synthesizers
PostPosted: Tue Jan 10, 2017 9:17 am    Post subject: Reply with quote  Mark this post and the followings unread
One of my brothers:
I didn't know you played keyboard?
Me:
I don't
What do you do with a synth than?
I have a great SEQUENCER Laughing
Cfish
PostPosted: Tue Jan 10, 2017 9:24 am    Post subject: Reply with quote  Mark this post and the followings unread
I will second that you have a nice sequencer grumble
I would say it's an awesome sequencer.
alanwilder81
PostPosted: Tue Jan 10, 2017 11:34 am    Post subject: Reply with quote  Mark this post and the followings unread
i got asked the same question very frequently, or worse yet, when friends tell
" c'mon man,lemme hear you play " Cool Cool
" i cant play a keyboard" is my obvious answer to them. They look at me in disbelieve.
People don't know what sequencers are. They can hardly tell apart a piano from a frigging church organ, let alone knowing sequencers.
i sometimes feel to be part of one of the most obscure musical crews out there, to the average person.Never mind Wink
Cfish
PostPosted: Fri Feb 03, 2017 4:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
I did some cabinet work last weekend
It's coming along.
 Filesize:  913.29 KB
 Viewed:  383 Time(s)
