selecting a case for the soundlab
Page 1 of 1 [6 Posts]
danv
PostPosted: Wed Jun 08, 2005 11:12 am    Post subject: selecting a case for the soundlab Reply with quote  Mark this post and the followings unread
hello,
what is the minimum depth i should look for when choosing a case for the soundlab??? thanks!
Wild Zebra
PostPosted: Wed Jun 08, 2005 12:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well I guess it depends where your going to place your board. If your going to to put it on the top, bottom, or sides it has to be at least bigger than 3 and 11/16"(the width of the board). If your going to place it behind the panel I'm guessing it could be alot smaller. Its up to you.
Do you already have something and your wondering if it will fit?
"your stripes are killer bro"
danv
PostPosted: Wed Jun 08, 2005 1:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
if i was trying to put the board behind the front panel, parallel to the bottom of the case and the front panel. what are the minimum depth requirements for a case?
what i'm pretty much trying to figure out is how tall the soundlab board will be when all of the components are soldered in.
thanks!
Wild Zebra
PostPosted: Thu Jun 09, 2005 7:34 am    Post subject: Reply with quote  Mark this post and the followings unread
the board won't be that tall the tallest component will be electrolytic caps, about half inch maybe. Its hard to say how deep I haven't got that far yet, but I'd give yourself alittle room. If I had to guess no less than 3 inches maybe.
danv
PostPosted: Thu Jun 09, 2005 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok, thanks a lot!
Wild Zebra
PostPosted: Fri Jun 10, 2005 8:31 am    Post subject: Reply with quote  Mark this post and the followings unread
let us know how it goes
