Differentiation and Integration of Audio Signals
Page 1 of 1 [3 Posts]
Audio files: 500
PostPosted: Sun Apr 27, 2014 6:21 am    Post subject: Differentiation and Integration of Audio Signals Reply with quote  Mark this post and the followings unread
http://pcfarina.eng.unipr.it/Differentiation-Integration.htm
This web page explains in audio terms what it means to apply these processes on an audio signal. Even I can almost grasp it. Wink
elektromeister
PostPosted: Wed Jan 11, 2017 12:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
That is interesting. The differentiation performs something like a high pass, while the integration performs a high cut.
Hm, I wonder how one could use the in sound processing.
Anybody knows, where and how this is done?
music is the key
Audio files: 299
PostPosted: Wed Jan 11, 2017 12:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some I've been using are ...
differentiation is change detection, so can be used for instance to detect a pitch control signal change to start an envelope.
In digital signal generation there is an alias reduction trick based on integration / differentiation (DPW, Differentiated Parabolic/Polynomial Waveform).
Integration can be used to create saw and triangle wave forms, both analog and digital.
The integrator is a building block for the State Variable Filter (SVF).
