Wobble
Posted: Tue Feb 21, 2017 2:08 pm Post subject:
Suggestion for 2 modules Subject description: FixedDivider and MultiOsc |
I very often find myself needing 3 or 4 oscillators chained and at same frequency. Like in this example where I simulate a kick bass drum:
It would be real handy to have 1 MultiOsc that has 4 outputs, 1 for each waveform and still includes pulse-width modulation for the squarewave. Just for convenience.
Same for Divider. It would be very convenient to have 1 FixedDivider, which has these outputs: 1/2, 1/3, 1/4, 1/8, 1/16, 1/32, 1/64. |
Joined: Apr 03, 2004 Posts: 24476 Location: The Netherlands, Enschede
Posted: Tue Feb 21, 2017 3:33 pm Post subject:
Seems like very doable, will make something.
but re. the multi osc .. would the Hrast type not be usable for that?
As an aside - I see you use the EnvAR module often where I would expect the EnvARRetrig .. the latter having the advantage that it still works when the time is set longer than the repeat time of the trigger .. you may not actually want that to happen of course, was just wondering. _________________ Jan
Wobble
Posted: Tue Feb 21, 2017 3:49 pm Post subject:
Blue Hell wrote: | but re. the multi osc .. would the Hrast type not be usable for that? |
It does not sound the same as mixing up to 4 waveforms. And it does not have a separate output for each waveform, which is useful for separate paths for each waveform sometimes:
Blue Hell wrote: | I would expect the EnvARRetrig |
You are right, in the above drum case I also realized I used the wrong one, was just too lazy to change it, since the LFO was running slower than the envelopes. |
Posted: Tue Feb 21, 2017 4:55 pm Post subject:
Ok.
On the multi-osc I may not be able to combine the three of PM, PWM and anti-aliasing .. but will look into it.
Will make the fixed divider as I've wanted one myself and never got to making one. But will make a couple of 'odd' divisions on it as well. The numbers will be : 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 16, 32 and 64 ... unless it turns out too expensive to do all that. In that case I may remove some and add a prime div module or something, but it probably will be fine.
As another aside, apart from dividing down you can also multiply up using the ChebGen module. You need a sine, saw or tri as input then. This will give you factors 2 .. 13. Sine saw and tri can also be used as a clock generator of course. _________________ Jan
Posted: Wed Feb 22, 2017 3:11 pm Post subject:
Both seem to work OK and will be in the next release. _________________ Jan
Wobble
Posted: Wed Feb 22, 2017 4:53 pm Post subject:
Awesome! |
