today> Various Artists September equinox Concert
ERRATUM Soundtronics yusynth PCB
Page 1 of 1 [15 Posts]
yusynth
PostPosted: Mon Jan 30, 2017 10:15 am    Post subject:  ERRATUM Soundtronics yusynth PCB Reply with quote  Mark this post and the followings unread
I have been a bit to hasty when I redesign my PCB for Soundtronics and some mistakes are present on some PCB, I will see with soundtronics to fix these.
Minor problem :
METALIZER BOARD , silkscreens IN and GND are swapped, check if the silscreen differs from what's on my site.
ARP VCF , missing track between the -15V pad of the MOTM connector and the small square pad beside it. Just connect a small wire between those two pads.
Major problem
MIXER : cut the small track that connects the +15V pad of the MOTM connector to the ground buss of the PCB. Then connect the 0V pad of the MOTM connector to the ground buss of the PCB.
AUTOBEND : cut the small track that connects the +15V pad of the MOTM connector to the ground buss of the PCB. Missing track between the two square pads loacted midway between the MOTM connector and the EUro connector. Cure : connect a strap
PULSE DELAY
Error of silkscreen, C2 must be rotated (bad polarisation) the - pin must be the closest to the edge of the board.
SAMPLE AND HOLD
RING MOD
The ground pad of the input connector misses a track to actually connect it to the ground, thus the 1.5K (R8 and R30) is not connected to the ground although it should be. Connect a wire between the ground pad pf this connector to the closest ground track.
There is also a missing track between R16 and the ground track.
Well that's all I hope.
Yves
marfoski
PostPosted: Tue Jan 31, 2017 9:33 am    Post subject: Re: ERRATUM Soundtronics yusynth PCB Reply with quote  Mark this post and the followings unread
Yves, maybe I'm dumb, but I cannot find anything on your site about the Metalizer. There's only the old beloved Wavefolder... Am I missing something?
Thank you
Marco
yusynth
PostPosted: Tue Jan 31, 2017 9:45 am    Post subject: Reply with quote  Mark this post and the followings unread
It is not directly accessible because not yet finalized. But you may have a glimpse here.
Yves
marfoski
PostPosted: Tue Jan 31, 2017 11:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow. Thank you so much, Yves!
Flareless
PostPosted: Mon Mar 06, 2017 8:07 am    Post subject: Reply with quote  Mark this post and the followings unread
I resolved a bit of a nightmare problem with the Clock Divider;
The +15 voltage from R1/C1 doesn't go anywhere.
The board seemed to work (LEDs flashing and responding to rotary switches) but the output voltage was barely 0.6V.
I jumpered +C1 to the Collector on Q9 and everything worked fine.
Rich
Lower West Side Studio
Fizzbin on SoundCloud
yusynth
PostPosted: Mon Mar 06, 2017 2:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Gee that's another one, I will have this corrected in the next batch and will send a note to Soundtronics about that.
Yves
Flareless
PostPosted: Mon Mar 06, 2017 2:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Yves! I really love your modules. Thanks for all you've done for the community!!!
Rich
r0main
PostPosted: Fri Mar 10, 2017 6:02 am    Post subject: VCO pcb Reply with quote  Mark this post and the followings unread
Great, do you know when VCO pcbs will be available? Thanks
yusynth
PostPosted: Fri Mar 10, 2017 10:43 am    Post subject: Reply with quote  Mark this post and the followings unread
I working on that.
Yves
Flareless
PostPosted: Sat Jul 22, 2017 8:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
There is a problem with the Output Monitor module.
There is a missing Ground (Earth) connection on the board at the U1 TL074 pin 3 or 5.
It can be remedied by connecting one of these pins to Ground. I used the centre connection of the 3 wire connection to the Master Volume pot.
Rich
yusynth
PostPosted: Sun Jul 23, 2017 12:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the info I will correct that on my site and have an erratum published on Soundtronics
Yves
noby
PostPosted: Fri Aug 04, 2017 4:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Firstly, thanks Yves, it's great to see the pcbs for sale.
My pcb etching skills aren't the greatest - I managed to succeed with the minimoog vcf, mixer, lfo, and one of the two ADSRs I etched, after a bit of kludging.
I had etched an OK-looking VCO (3rd attempt), but was hesitant to start populating such a complex board so was delighted to see Soundtronics stocking them.
My question - I have the parts bought for a couple of 2SC1583 VCOs. Are the pcbs for these coming soon, or should I go ahead and kludge it on the available pcb (which seems relatively straight-forward?
yusynth
PostPosted: Fri Aug 04, 2017 5:47 am    Post subject: Reply with quote  Mark this post and the followings unread
It is not planned though I may check with soundtronics
Yves
noby
PostPosted: Fri Aug 04, 2017 8:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, Yves.
synthcube
PostPosted: Wed Dec 06, 2017 6:27 am    Post subject: Reply with quote  Mark this post and the followings unread
we are happy to report we are continuing to offer prior and newer yuSynth PCBs in our webstore including the Output Monitor (with the trace correction incorporated)
http://synthcube.com/cart/yusynth-output-monitor-pcb?search=output%20monitor&description=true
web store: www.synthcube.com/cart
we've acquired MFOS to help carry on Ray Wilson's work: www.musicfromouterspace.com
