Fading between several oscillators?
Page 1 of 1 [11 Posts]
laurentius
PostPosted: Tue Apr 11, 2017 1:45 pm    Post subject: Fading between several oscillators? Reply with quote  Mark this post and the followings unread
How would you do this?:
Let's say I have 8 different oscillators. I wanna fade from one to the next using a controller (might be the mod wheel for instance).
On top of that it would be amazing to have the option to not fade between the osc's but mix/blend them together.
Each option itself wouldn't be a too hard task, but both together in one patch seems impossible for me.
Any idea?
Thanks,
L.
PostPosted: Tue Apr 11, 2017 10:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would use 8 digitally controlled potmeters, a rotary encoder and an Arduino to pull this off
PostPosted: Tue Apr 11, 2017 11:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://jhaible.com/legacy/interpolating_scanner_and_scanv/jh_interpolating_scanner_and_scanvib.html
The Interpolating Scanner sounds like the first part of what you're after.
Easiest way to have the second part would be to have a little 8 input mixer (little, he says!) just before the OTAs.
Edit -- don't solder your G2. It probably won't end well.
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Wed Apr 12, 2017 12:40 am    Post subject: Re: Fading between several oscillators? Reply with quote  Mark this post and the followings unread
Any idea?
Thanks,
L.
The Mux8-1X (in the switch group) does this. The X-Fade knob varies from hard switch to smooth cross fade between consecutive inputs.
Patch your mod wheel or whatever to the Ctrl input.
PostPosted: Wed Apr 12, 2017 12:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Very sorry, I did not spot that this was the G2 section.
PostPosted: Wed Apr 12, 2017 2:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Me neither Embarassed
laurentius
PostPosted: Wed Apr 12, 2017 3:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, much appreciated. Still the second part of my task remains unclear to me how solve it... Wink
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Wed Apr 12, 2017 6:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, I missed that. Can you explain to me the difference between fade, mix and blend?
laurentius
PostPosted: Fri Apr 14, 2017 3:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Fade: pretty obvious, I hope. I want to fade from one to the next oscillator so that basically it's just one osc sounding.
Blend: I mean mixing them together (all of them together).
The problem is to find a solution to be flexible in doing both: Having one controller like the mod wheel for the fade-thing while having the encoders at hand to mix all the oscillators together when I want to...
I don't know how to patch that together...
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Fri Apr 14, 2017 3:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Like using a mixer and a fader?
This patch allows you to choose with a switch. If you were thinking of doing both at the same time, just replace the switch with a two input mixer.
Please excuse me if I still don't understand what you are trying to do.
fade-mix.pch2
demo
 Filename:  fade-mix.pch2
 Filesize:  1.33 KB
 Downloaded:  3989 Time(s)
laurentius
PostPosted: Sat Apr 15, 2017 9:27 am    Post subject: Reply with quote  Mark this post and the followings unread
that seems like a perfect solution! Thanks!!!
