today> Bill Fox solo tonight! Chez Mosc
CD4029 based sequencer skipping 0
Page 1 of 2 [44 Posts]
PostPosted: Sat Apr 22, 2017 10:07 pm    Post subject: CD4029 based sequencer skipping 0 Reply with quote  Mark this post and the followings unread
I'm working on a trigger/gate sequencer.
First rule of responses: don't tell me I ought to be using (insert your favorite programming platform), because I don't want this to be something people have to flash/program, and I don't want it to be something I have to supply programmed chips for. It's nice if you don't think that's an impediment, but some people still do and I want to include them if this thing ever gets to the "selling it from Synthcube" stage.
Design points:
Variable duty cycle output, so we can sequence triggers to gates.
Up/Down control
Ability to use it for 16 steps or 2x8 steps
CVs (gates, really) over all these controls
Clock out/clock in so you can chain several of them
Up/Down led me to the CD4029
Intent to generate variable duty cycle via AND with step gates led me to a variable duty cycle clock -- 555 for the basic clock, use the triangle buffered and run through a comparator to get the duty cycle.
Using 2 x 4051 to decode the counter into either 8 steps, or using the high bit of the clock and its inverse to alternate the two for 16 steps.
Initial problem was my clock was using an LM311 for the comparator, and only getting 0->6V, when it needed to be 10-12V for the high side.
Revised the comparator to use an LM358 (single supply config) and I'm getting a decent clock out of it.
What is weird is that from the start, when the counter was working, it was skipping steps. Counting up it would skip 0 and 8, counting down it would skip 4 and 12.
After adding a transistor buffer on the clock input, I'm no longer skipping 8 when counting up, nor am I skipping anything when I count down. But I am still skipping 0 when counting up.
So other relevant things....
the jam inputs are all grounded, as is carry in.
the load jam inputs ("PE") pin is connected both to a power on reset (cap to +V, resistor to ground) and to a diode coming from the reset input which is transistor buffered and normalled to a reset button. Pressing the reset button gets the expected result of resetting to 0 (and always has).
The schematic is something of a problem, it's actually split over multiple sheets, but the relevant bit with the 4029 is here.
I am simply not grasping why it would skip step 0. There's nothing odd about the clock as far as I can tell, for testing it's on its own power supply all alone...... Hoping someone with more CMOS experience can point to something. Speaking of which, all chips have 100nF bypass caps near their power pins.
 Filesize:  192.14 KB
 Viewed:  1109 Time(s)
PostPosted: Sat Apr 22, 2017 10:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, and ignore the headers at the top; this was an experiment in how I could indicate mating headers between two boards -- controls and a little bit of support stuff is on a panel PCB, the main logic is on its own PCB. I hate the way this looks, it only made sense when I was first drawing it, and I just haven't gone back to revise it.
Overall this is going to go through a lot of serious revision (changing the switches, which also means changing to do something else instead of a 3 pole switch, they don't apparently make those in submini). But I want to get all the stupid mistakes resolved before I do that.....
And yes, I have realized I have no Run/Stop Embarassed
PostPosted: Sun Apr 23, 2017 2:09 am    Post subject: Reply with quote  Mark this post and the followings unread
By "skipping" you mean the outputs of the 4029, or the outputs of the 4051?
I mean: where did you noticed the skipping?
Because if you say that the skipping occurs at some point at 0,8,4 and 12 it's common nominator is Q4 of the 4029, so my guess is that there is something wrong with it (bad solder, shortcut ...)
PostPosted: Sun Apr 23, 2017 2:46 am    Post subject: Reply with quote  Mark this post and the followings unread
A resistor from the base of Q4 to GND might help. I had some problems with skipping
when using a resistor that was too large and you don't have one at all. I wasn't using
the transistors as an emitter follower though, but I think it's worth a try. btw. If you use
them like this it will most likely not work with 5V gate/triggers signals.
PostPosted: Sun Apr 23, 2017 4:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Why not use the same resistor values around Q4 as with Q? (that's the Q with the question mark Wink
gdavis
PostPosted: Sun Apr 23, 2017 10:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry I don't have time to read everything and go into detail right now, but I really don't think you should be using emitter-followers to buffer the inputs of the CMOS chips. And the diode on reset makes things even worse and seems completely superfluous. Anyway, I can explain more later if you want.
gdavis
PostPosted: Sun Apr 23, 2017 1:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, I took another look and your inputs are seriously flawed. There's absolutely no way this thing can be expected to work reliably.
1. As I mentioned above, you don't want to use emitter-followers for logic. The output of the emitter-follower is going to follow the input voltage but lose one diode drop through the base-emitter junction (about 0.6V). So for a high input at best you get Vin - 0.6V (reset is even worse with the extra diode). The problem is that CMOS logic really wants to be driven by Vdd and Vss for high and low respectively (as close as you can get to this). so a) your clock input needs to be very specific and b) you don't want to be giving up that diode drop.
Edit: Disregard point 2. This analysis is incorrect.
2. The base and emitter resistors of Q? and Q4 (you really should annotate your schematics before posting them for help) are forming voltage dividers in addition to the drop of the emitter follower. With the values shown, you are reducing the input by about 1/10. This is going to kill the circuits ability to operate properly, especially on the clock.
3. Your reset input is floating when there's nothing connected and the button isn't being pressed. Add a pull down before the transistor base.
I would suggest replacing the emitter followers with common emitters like Q5 and Q6. Then you know you are getting the correct voltages to the CMOS inputs regardless of the external input voltages, as long as they cleanly cross the threshold of the transistor.
I also don't see the need for R41, C16 and D3. I'm guessing you're trying to extend the reset pulse? Are you worried that your reset source is going to generate too quick of a pulse?
Edit: I just read your explanation of the reset. Not sure it's going to work reliably, might work well enough. I don't see it as critical so I'm not worried about it, but you should fix the input as explained above.
PostPosted: Sun Apr 23, 2017 9:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Many thanks to the E-M alerting system which hasn't bothered to notify me of any of you folks' kind responses.
I notice it on the outputs of the 4029. I can clearly see that Q1 is not outputting a normal evenly-spaced up/down waveform as I would expect for the LSB of a binary counter.
PostPosted: Sun Apr 23, 2017 9:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
So I had two points in doing this.
1) first, trying to make sure I protect from the possibility of an incoming -12V signal off the jacks, always a possibility with random LFOs being patched in as clocks (though yes, 90% of the time -5V is most likely the lowest).
2) before I added the transistor Q?, I was getting *worse* results. At that point it was just the resistor and diode for -V protection. Edit: on the clock.
Apologies, these are "in progress" and I just bodged that transistor onto the PCB about 4 hours before I posted asking for help, and the transistor into the schematic probably only a few minutes.
That makes sense; I'm curious why it works at all though then....
Assuming I leave the transistor there? Very Happy
Except those are inverting the signal. Not what I want on Q? and Q4. (it has somehow become Q1 since I annotated it, not sure where the original Q1 went Very Happy ) Do I need to use PNPs and a slightly different setup then? I'm less confident in my PNP transistor knowledge than I am with NPNs Smile
The resistor and capacitor are there for power on reset. Diode was intended to isolate that function from the incoming signal, but I see how it's probably entirely redundant. I do understand the cap & resistor are not a perfect solution, but it's a common enough one that I figured it should work, and I haven't noticed it ever coming up in any state but 0 to begin with.
It's preferred to the counter coming up in a random state. If there's a better solution I would certainly be interested in what you would recommend.
PostPosted: Sun Apr 23, 2017 9:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
So further clarification on this.
I'm not sure I understand how/why the presumed divider is relevant, because I'm using the transistor as a buffer. As I understand it, I'm driving it into saturation (hopefully) and so it should be behaving as if I just threw 12V onto that line, and the 1K is to keep me from shorting my supplies together (note elsewhere I've mostly been using 10K for the same purpose, but again, experimenting with the circuit to see if anything works better, that seemed to be better).
PostPosted: Sun Apr 23, 2017 10:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
As in my previous clarification question, since my goal is to drive the transistor into saturation (and no, I haven't done the math, sloppy me), as long as I have enough signal to turn on the transistor, would it matter?
I do see where I probably need to drop those other 100K input resistors down though....
PostPosted: Sun Apr 23, 2017 10:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
a 10K pulldown on Q4 and eliminating D3 was insufficient.
I will see whether additional replies help me understand better before I go poking around with random values though....
Again: thanks very much for all the replies. I have a degree, but I was never very good with transistors (obviously Wink ), and that degree didn't get used in any practical way for 25 or so years, so even what I did know is all pretty rusty where it hasn't been polished by actual use troubleshooting other circuits.....
PostPosted: Mon Apr 24, 2017 4:29 am    Post subject: Reply with quote  Mark this post and the followings unread
As the name suggest with an emitter follower the voltage on the emitter follows the voltage at the base,
so 5V in gives you about 5V out but with a low impedance. I would suggest using comparators (made with
opamps) for the CLK and reset inputs. PNP transistors would still invert, be it the other way aroud, so you'd
need a negative/low voltage on the inputs or an extra transistor.
PostPosted: Mon Apr 24, 2017 5:53 am    Post subject: Reply with quote  Mark this post and the followings unread
so either 1) I'm not actually driving the transistor into saturation or 2) I have no goddamn idea what I'm doing with transistors and should go grow cabbages. Possibly both.
PostPosted: Mon Apr 24, 2017 8:12 am    Post subject: Reply with quote  Mark this post and the followings unread
It doesn't have anything to do with saturation but the way the transistor is configured in the circuit. this might clear things up a bit.
Growing cabbages can be fun if you like them. I once grew a Romanesco broccoli, beautiful plant and tasted good too.
gdavis
PostPosted: Mon Apr 24, 2017 1:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, but you've got the diode on the input to prevent the negative voltages, which is good, but the transistor isn't really relevant to this.
This is a tell tale sign of this type of problem. When you change things that don't actually fix the root cause, you get slightly different behavior that may even seem to improve, but the symptoms don't completely go away. You may even get to a point where it appears to be working fine, then one day you may try to connect a new module, get a new PS or something and suddenly it's not behaving right again. The key word is "reliable".
When you have quick transients, parasitic inductances of the circuit result in some over shoot. My guess is that you're getting enough overshoot for the circuit to operate, but makes it unreliable.
I would (but change the configuration), unless you want to replace it with a comparator (which would still need a pull). What you want is to ensure that you drive either Vdd or Vss to the CMOS input regardless of your input levels. The transistor is a simple way to do this, in the right configuration.
Yes, it will invert which you need to take into consideration. If you really don't want inversion, you can simply cascade a second transistor after the first one to get the original polarity back.
PNP will still invert, it just makes the "on/off" behavior of the transistor relative to V+ (assuming emitter is connected to V+) instead of GND.
The cap and resistor work for active low reset where they keep reset low for a short period after power comes up (I think this is why async resets are usually active low). I've never seen it on an active high signal like you've done. It would rely on power coming up very quickly which may not be the case. I understand the desire to have it power up in the 0 state, I'm just saying that there are worse things that can happen than it not coming up in 0. At least it wouldn't trouble me greatly Wink Have you noticed that it gets random values if you leave the POR circuit out? I'm just curious if it has something built it that would load jam on power up or something.
I don't have one, it's difficult with an active high signal at power up, which is why I'm wondering if there's something built it that makes it power up in a known state.
As PHOBoS mentioned, the output of the emitter follower will just follow the input (minus the base emitter diode drop). By definition, saturation requires both junctions to be forward biased. Since you have the collector connected to V+, this means the base has to be >V+ to saturate.
You're actually in the forward active mode: C > B > E
Edit: disregard flawed analysis.
In this mode, the circuit is essentially IN---R---D----R---GND
The D just creates a voltage drop that alters the divider ratio a little bit, but you still essentially have a voltage divider. The transistor is only providing current as needed to maintain the output voltage independent of the load (within it's limits).
In the common emitter configuration, you have a resistor between V+ and the collector. This resistor drops a voltage when the transistor turns on, allowing the collector voltage to drop to the base voltage thereby entering saturation. This can happen with a small base voltage because of the current gain of the transistor.
In the emitter follower, you move that resistor to the emitter, so the collector is always fixed and the emitter voltage rises as the transistor turns on, keeping the base-emitter voltage at a level that limits the current through the transistor.
PostPosted: Mon Apr 24, 2017 8:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Fair enough.
Yes, my biggest nightmare is, as a semi-inexperienced designer I throw something out there that ends up not working right for some buyers. I do prototype pretty rigorously, I cannot fathom why some folks put out PCBs that need traces cut and workarounds done.
I've gone back over it, and I think I'm better off putting more chips on the main PCB (which is pretty sparse as it is) and using 40106 hex schmitt trigger/inverter in the place of the transistors. I'll still need to invert twice for the two I want to be active high, but that's not a huge problem, I have the gates to use. Mildly concerned about gate delay causing lag, but the only time I've actually seen that much has been when I intentionally did it by adding caps to ground in the signal line, so we shall see what the rework looks like.
Again, thanks very much. I'll report back when I've had a chance to figure out if I can do the extensive changes on the existing prototype boards (considering glue & deadbug Smile ), or if I just need to bite the bullet and order revised prototypes. I have a lot of revision to the panel PCB as well, I was going to use mini toggles, but I agree with some other commentary I've gotten elsewhere that subminis would be better. Which, btw, is another reason why I'm adding more logic in place of transistors, they don't make 3 pole submini's that I've been able to find. Which means if they *are* out there, they're probably far more spendy than I care to deal with.
The inhibit logic for the 4051's is such that I can replace the 3P with an SP and a couple AND gates.
gdavis
PostPosted: Mon Apr 24, 2017 9:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
No!!! CMOS Schmitt triggers are for slow input transitions, they do nothing to resolve the level issue that you're trying to address. In order to tolerate a wide range of input voltages, transistors or comparators (rail to rail!) are your best options.
PostPosted: Tue Apr 25, 2017 6:21 am    Post subject: Reply with quote  Mark this post and the followings unread
I didn't say I was taking out the input resistor and diode to ground Smile
But if they are slow..... Rawrg.
This was the revision. Not the last one then... Smile
 Filesize:  241.32 KB
 Viewed:  505 Time(s)
JovianPyx
Audio files: 224
PostPosted: Tue Apr 25, 2017 7:37 am    Post subject: Reply with quote  Mark this post and the followings unread
I think gdavis was referring to the use of the 40106, not that it is a slow IC. A schmitt trigger input gate works well with signals the rise or fall slowly. Non schmitt trigger gates don't like this and can generate noisy output while the input signal is changing values.
Time flies like a banana.
corruptio optimi pessima
PostPosted: Tue Apr 25, 2017 8:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Instead of using 2 schmitt trigger inverters, which won't really help you, use a transistor (configured the same way as
Q5, Q6 in the original schematic but with a resistor to GND) followed by 1 schmitt trigger inverter. This will give you
a wider voltage range and because of the schmitt triggers smooth transitions at a logic level. Or, as I mentioned before,
some simple comparators which have always worked great for me.
I am very confused by this. Since the transistors are configured as an emitter follower the output voltage
is pretty much the input voltage (ignoring the voltage drop caused by the transistor itself). And one of the most
useful aspects of this configuration is to drive higher loads with a small base current while maintaining this voltage.
If you take Q? for example the load is R? (1K) which is hardly a load at all and shouldn't cause any voltage drop.
I am probably misunderstanding what you mean but to me it sounds like you are saying the transistor doesn't do
anything at all and actually gives an even lower voltage than if you would just use the 2 resistors as a voltage divider
without the transistor.
gdavis
PostPosted: Tue Apr 25, 2017 12:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Exactly.
In the revised circuit, the diode and resistor will protect against negative voltages, but you still have the issue of the high voltage if it's not V+. The common emitter transistor configuration will have a small threshold and anything above that will switch it. Comparator lets you set the threshold you desire. The CMOS inverters have a much higher threshold, and the schmitt makes it even higher still. Basically all you've done is move the CMOS input problem from the 4029 to the 40106.
You know, now that you mention it I think I am mistaken Embarassed I applied the wrong conditions to my analysis and forgot that with the resistor on the emitter the base resistance will actually be much higher. There will still be a voltage divider effect reducing the output voltage slightly but not nearly as bad as what I stated earlier.
Thank you for pointing this out. Nothing I hate more than putting out erroneous information.
electrotech
PostPosted: Tue Apr 25, 2017 3:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello,
If you'd like to use a simple all-discrete component circuit for the clock interfacing, I'd like to offer the attached one I came up with. It's already been suggested above and personally, I think it's all that's needed Wink
The CMOS inverters that are being considered would still need additional voltage level translation to work with a 5V clock for example.
In my circuit, the over-voltage and polarity protection is taken care of by the zener diode.
Bipolar or unipolar clock inputs from 3V upwards are catered for.
The resistors either limit the current or act as potential dividers to enable clean switching of the transistors, there being one NPN type followed by a PNP type so that the output signal is just a 0 to 12V clock signal in phase with the input.
I should add that I haven't actually built this but it works fine in the simulator.
Regards,
Andy
EDIT : An updated circuit plus an alternative are posted further down.
 Filesize:  4.14 KB
 Viewed:  20966 Time(s)
gdavis
PostPosted: Tue Apr 25, 2017 4:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for posting that up Andy, looks like a solid solution to me thumb up
Audio files: 327
Ah, that looks like design Andy Cool
