dual gated slew not working
Page 1 of 1 [5 Posts]
selbersuess
PostPosted: Mon Apr 24, 2017 9:37 am    Post subject: dual gated slew not working Reply with quote  Mark this post and the followings unread
hello,
i have a problem with "dual gated slew". i get no glide/slew (with or without gate). not lin nor log.
to test, i plugged midi-cv to input, output to vco.
by a slew-rate from 0 to 3 in lin mode, i hear a detune (the detune will stay, no slew). if i rise rate greater than 3, in- and output is the same.
in log mode, there is no difference between in- and output. i checked +-15v, shorts, etc. tl07x in correct positions.
any ideas?
thank you
daniel
selbersuess
PostPosted: Wed Apr 26, 2017 7:43 am    Post subject: Reply with quote  Mark this post and the followings unread
i noticed that i used bf245B instead of bf245C. could that be the problem?
selbersuess
PostPosted: Wed Apr 26, 2017 9:10 am    Post subject: Reply with quote  Mark this post and the followings unread
when i said detune, i mean the output ist lower than the input...
selbersuess
PostPosted: Wed Apr 26, 2017 10:46 am    Post subject: Reply with quote  Mark this post and the followings unread
damn, i accidentally used 1nf instead of 1uf.
now its running fine.
Audio files: 310
PostPosted: Wed Apr 26, 2017 11:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Good you solved it Cool
