June Solstice 2017 live streaming event
Page 2 of 3 [72 Posts]
PostPosted: Wed Jun 21, 2017 4:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Whee welcome aboard Jan! Smile
chupchups
PostPosted: Thu Jun 22, 2017 11:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Dear All Smile
Just a little message to tell @Antimon that I will test the connexion during the day tommorrow Smile promise.
Audio files: 161
PostPosted: Thu Jun 22, 2017 12:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
pic to swap with old ones when streaming , thanks Phobos Smile
 Filesize:  1.72 MB
 Viewed:  964 Time(s)
PostPosted: Thu Jun 22, 2017 12:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
resized version of dale's photo to make it a bit more radiopage friendly.
 Filesize:  212.85 KB
 Viewed:  945 Time(s)
PostPosted: Thu Jun 22, 2017 1:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
The poster with schedule. a small one for the radio and a larger one for whomever needs it.
small June Solstice 2017 poster
 Filesize:  173.64 KB
 Viewed:  949 Time(s)
large June Solstice 2017 poster
 Filesize:  1.22 MB
 Viewed:  938 Time(s)
Acoustic Interloper
Audio files: 89
PostPosted: Thu Jun 22, 2017 3:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, PhoboS, great looking poster, I can't wait to share it around. It looks like Les and I have an identical start time on the poster. Shocked
When the stream is deep
my wild little dog frolics,
when shallow, she drinks.
PostPosted: Thu Jun 22, 2017 3:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Embarassed let me fix that, thanks for noticing.
AlBaldwin
PostPosted: Fri Jun 23, 2017 9:36 am    Post subject: Stream test Reply with quote  Mark this post and the followings unread
Testing now.
Everything working great.
Al
AlBaldwin
PostPosted: Fri Jun 23, 2017 9:54 am    Post subject: Phobos....
Subject description: @ Al Baldwin: would 15:00 (GMT) work for you ?
Yes
jack
PostPosted: Fri Jun 23, 2017 11:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Preferred Start Time* (Please use GMT/Military Time): 21:30
3. Artist Name (For displaying on the poster): Jack Tamul
4. Chat Name (if different from artist/forum name): Jack Tamul
5. Location (City/State/Country - Optional): Providence
7. Website Address:
JACK
PostPosted: Fri Jun 23, 2017 11:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Schedule and poster have been updated to accommodate Jack.
PostPosted: Sat Jun 24, 2017 5:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello from Leawood, KS. I am unable to connect to the chatroom -- is the chat room offline or is the problem on my end? Thanks!
Audio files: 324
PostPosted: Sat Jun 24, 2017 5:46 am    Post subject: Reply with quote  Mark this post and the followings unread
the chat is not working - I've sent out a message to wmonk.
PostPosted: Sat Jun 24, 2017 5:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you. I still have to do my port check -- tried to do it yesterday but probably did it so late in the day that no one was around to check it for me. I think I will go ahead and stream to the server and hopefully someone will be able to verify it for me.
1300 GMT: I just stopped broadcasting on my port. Need to step away for a few minutes. I will check in later.
schugo
PostPosted: Sat Jun 24, 2017 5:58 am    Post subject: Reply with quote  Mark this post and the followings unread
just in case.... I'm on a backup channel:
irc.freenode.net
6667
#electro
PostPosted: Sat Jun 24, 2017 6:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Just acknowledging that I'll be the first switcher. If the chat doesn't come alive maybe we can coordinate in this thread, or log into schugo's irc.
PostPosted: Sat Jun 24, 2017 6:16 am    Post subject: Reply with quote  Mark this post and the followings unread
PANIC!!
Hideing
(schugo's IRC doesn't work but that might just be me being a noob)
PostPosted: Sat Jun 24, 2017 6:33 am    Post subject: Reply with quote  Mark this post and the followings unread
PANIC!!
Hideing
Hi Phobos! Would you be able to port check me? I will go ahead and start up my stream. Thanks. (It is just a loop with some synth drones. )
schugo
http://webchat.freenode.net/
#electro
PostPosted: Sat Jun 24, 2017 6:42 am    Post subject: Reply with quote  Mark this post and the followings unread
that works for me, thanks! cheers
PostPosted: Sat Jun 24, 2017 6:44 am    Post subject: Reply with quote  Mark this post and the followings unread
a reminder for the performers:
DON'T FORGET TO RECORD YOUR SET!
Audio files: 324
PostPosted: Sat Jun 24, 2017 7:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Edit : Our own chat server is back
Audio files: 161
PostPosted: Sat Jun 24, 2017 7:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Im good to go for the set time we will keep update from here , Smile Smile Smile
Dave (Epicyclus)
PostPosted: Sat Jun 24, 2017 7:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Dave (Epicyclus)
Gotcha Dave, I'll be switching you in. Smile
Audio files: 161
PostPosted: Sat Jun 24, 2017 7:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Stefan , i will idle my port 5mins before start time as usual .
Thanks Smile
