saving patches in performance mode
Page 1 of 1 [5 Posts]
laurentius
PostPosted: Mon Mar 12, 2007 11:21 am    Post subject: saving patches in performance mode Reply with quote  Mark this post and the followings unread
if i edit a patch in performance mode and i edit and save it the patch won't be saved in way to be accessable in single mode. only in performance mode i can now play this newly edited patch. or am i totally wrong? please help.
lars.
Audio files: 303
PostPosted: Mon Mar 12, 2007 12:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
This seems to be unrelated to the patch conversion tool, I'll move the post.
In the editor you can use shitt (or control) + click on the toggle button for performance/patch mode to split the performance into patches. Then you can save the single patches, either to disk or into the synth.
Also you can use "save patch from" (file menu) from performance mode to save a single patch to disk.
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Mon Mar 12, 2007 12:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
... In the editor you can use shitt (or control) + click on the toggle button ...
Jan, use the SpellCheck! It is spelled with only one 't'. Surely the 'toggle' problem?
Wout
Audio files: 303
PostPosted: Mon Mar 12, 2007 12:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Might be, likely even Very Happy
Now let's just hope the shitt click works ...
PostPosted: Fri Aug 04, 2017 9:11 am    Post subject: Reply with quote  Mark this post and the followings unread
A decade later, thanks for this bit of info. It's the things you don't do very often that are the hardest...
