today> Twyndyllyngs Chez Mosc
The right mounting rails for Yusynth
Page 1 of 1 [6 Posts]
Kilombo
PostPosted: Fri Aug 25, 2017 1:58 am    Post subject: The right mounting rails for Yusynth
Subject description: Which ones fit, where do you get yours?
Hi everybody,
I was wondering how you mount your DIY Yusynth modules to your cases.
Using rails like these?
http://www.krisp1.com/store/forums.html?main_page=product_info&cPath=3&products_id=90
Or do you recommend any other source/product?
Thanks for your input!
Kilombo
PostPosted: Fri Aug 25, 2017 2:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Just found this article
https://www.soundtronics.co.uk/synth-modular-cabinet-construction/
mentioning these beams
https://www.makertronics.co.uk/openbeam-beams/
and cutting them down to 22U (978mm).
Seems like a good solution, though any input is still very much appreciated.
Also, a good way of searching for these things in the forums would be of great help (simply searching for "rails" gives me every thread where the word is mentioned).
Thanks again!
yusynth
PostPosted: Sun Aug 27, 2017 4:18 am    Post subject: Reply with quote  Mark this post and the followings unread
I checked the first site (Krisp) and it is written : "Not for use with MU systems." in other words "no good for yusynth modules" cause they are MU (Moog Unit).
Yves
Kilombo
PostPosted: Mon Aug 28, 2017 2:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Yves,
didn't know that things can be 5U-compatible but not Moog-compatible, seems I got the concept somehow wrong.
I'll see more into the solution of my second post then.
yusynth
PostPosted: Mon Aug 28, 2017 2:09 am    Post subject: Reply with quote  Mark this post and the followings unread
This incompatibility has to do with the fixation hole spacing not with the size of the panels.
Yves
Kilombo
PostPosted: Mon Aug 28, 2017 2:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah, alright, got it. Thanks again for the help!
