 Forum index » DIY Hardware and Software » The Repair Shop
Korg RK-100
Page 1 of 1 [2 Posts]
Dragon's Lair
PostPosted: Tue Nov 07, 2017 7:20 pm    Post subject: Korg RK-100 Reply with quote  Mark this post and the followings unread
Looking for a grey switch cap for a Korg RK-100 Keytar, or any info on other things that used the same switches.
Dan Lavin
Audio files: 21
PostPosted: Tue Nov 14, 2017 7:00 am    Post subject: Reply with quote  Mark this post and the followings unread
If you have no luck finding an original one, you can make a duplicate for next to nothing. I've done this when fixing Roland AX-1's and AX-7's.
Take a good key and push it into modeling clay to make a clay mold. Then slowly fill the cavity with hot glue from a hot glue gun. Let it cool for 15 minutes, then pull it out of the clay. You may have to trim it up a little with a razor blade. Paint to desired color.
It's not as pretty, but from a few meters away, it's not noticeable Wink
Synth DIY since 1977!
