2018 Build Photos
Page 1 of 3 [66 Posts]
Goto page: 1, 2, 3 Next
wmonk
Audio files: 15
PostPosted: Mon Jan 08, 2018 2:37 pm    Post subject:  2018 Build Photos
Subject description: What did you finish this year?
Happy New Year everyone!
This year it seems I am the first to finish a little project. Very Happy
This is Inventors Karplus-Strong project from 2010. Still had a PCB waiting to be populated. Besides some tuning it works great Smile
Link to the topic in case you want to build your own: http://electro-music.com/forum/topic-36165.html&postorder=asc
And now, lets all post some photos, and good luck DIYing this year!
 Filesize:  2.74 MB
 Viewed:  467 Time(s)
Weblog!
PostPosted: Sat Jan 13, 2018 4:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
first finished module for this year: Deus Ex Machina.
more info here
PostPosted: Mon Jan 15, 2018 9:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Always feels good to wrap up a longrunning project. I've had this on the backburner for a couple years now -- while the panel says 2018, the back of the pcb says 2016 Embarassed Catgirlsynth Stomp Box Adaptor.
Yusynth Comparator. With how well the CGS60 panel turned out (I tried ordering aluminium for the material, rather than the usual FR4 pcb material), I kinda wish I'd ordered this and the sequencer in aluminium too. Forgot the bypass caps on the PCB... eh, I can patch them in on the back if I find they need it.
PostPosted: Fri Jan 19, 2018 1:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Right. So, I've had this on the backburner for awhile, and electrically, it's all sorted. The toggle switches I used, however, are cheap and do not match the pots' height. Plus the panel is a trifle too short, and two mounting holes don't match. Quibbles! (Although I may well do a new panel!)
PostPosted: Fri Jan 19, 2018 2:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
looks great , nice work Alan
PostPosted: Fri Jan 19, 2018 2:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
nice module Phobos Smile
cool KS module Wmonk Smile
LFLab
PostPosted: Mon Jan 22, 2018 3:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice, the wiring on the original is mindboggling indeed, good way to simplify.
With respect to the switches, there's a Tyco switch which is small enough, the APEM TL series will work, and Thonk has submini switches with a height which matches 9mm Alpha and PC mount jacks. All of 'm are a lot more expensive than the "el-cheapo Chinese" SPDT's though.
PostPosted: Mon Jan 22, 2018 4:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
great job on the sequencer alan, looking at it again it must have been quite a challenge
to get everything on such a small panel space and conncet it all up as well. thumleft
jh
PostPosted: Sun Jan 28, 2018 2:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Syna is a 13 voice poly analog synth with touch sensitive keyboard. It was built as a thesis work. Keyboard made from pine wood, case from steel.
 Filesize:  1.1 MB
 Viewed:  482 Time(s)
PostPosted: Sun Jan 28, 2018 9:14 am    Post subject: Reply with quote  Mark this post and the followings unread
What a lovely lil big synth - do you have any details on it?
jh
PostPosted: Sun Jan 28, 2018 11:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for your interest.
13 voices, 13 voice polyphony. Same functions per key.
Select waveform from ; sine,tri,sqr,saw,pulse,pwm
Pulse adjustable, (positive period from 0...50%)
PWM speed control, pulse width control
12 db/octave filters, lp/hp/bp, Q value adjustable
Cutoff control with lfo / pot.
PostPosted: Sun Jan 28, 2018 7:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
WOW that is impressive!
What do the guts of it look like? Smile
PostPosted: Mon Jan 29, 2018 12:54 am    Post subject: Reply with quote  Mark this post and the followings unread
And more important: How does it sound? Shocked
my synth
jh
PostPosted: Mon Jan 29, 2018 4:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks.
Inside is some 200 meter of wire and casual pcb's, comparators, integrators, inverting and non inverting op amp's. Sorry, don't have picture and dare not to open hood, because prototype tends to have new faults every time the hood is open.
LFLab
PostPosted: Wed Jan 31, 2018 1:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, you can post your thesis here, I assume it has some more info? Very Happy
What are you studying?
kaputtpanzer
Audio files: 15
PostPosted: Sat Feb 03, 2018 11:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Built myself a little prototype board. Looks pretty crappy in a line with all your beautiful builds, but it is actually very useful. It has 4 fixed voltages (12V, 9V, 4,5V, 5V), 10x mounted pots and different audiojacks. Sorry for the crappy pics.
 Filesize:  2.94 MB
 Viewed:  391 Time(s)
 Filesize:  3.14 MB
 Viewed:  403 Time(s)
PostPosted: Sat Feb 03, 2018 11:38 am    Post subject: Reply with quote  Mark this post and the followings unread
doesn't matter how it looks as long as it is useful Very Happy
I have thought about making something like that many times before and I think I even have a list of things I wanted to incorporate.
Someday, someday,.. Rolling Eyes
kaputtpanzer
Audio files: 15
PostPosted: Sat Feb 03, 2018 11:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Phobos, took me around 5 years to finally built this. It was finished in a few hours and it is totally worth it...
Broadwave
Audio files: 6
PostPosted: Thu Feb 08, 2018 2:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Just on the final leg of another Minimoog Clone - This one is built from the Guin Guin MME kit, and sounds amazingly like a genuine Minimoog (no reason why it shouldn't - same circuit to the 3046 VCO version), and still cheaper than hacking the Behringer D.
Edit - March 19th. Finished the 5 week build
Synth DIY Projects
Musical Doodlings
PostPosted: Fri Feb 23, 2018 10:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Probably doesn't yet count as "finished" but here's my Appendage PCB fully stuffed.
 Filesize:  2.76 MB
 Viewed:  413 Time(s)
PostPosted: Sat Feb 24, 2018 3:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Shocked
never relalized that the appendage was that big and the pcb was that well stuffed.
It all works? or don't know yet?
PostPosted: Sat Feb 24, 2018 8:25 am    Post subject: Reply with quote  Mark this post and the followings unread
I have not wired it up to any of the external controls, or the actual softpot, so no idea Smile
PostPosted: Fri Apr 06, 2018 12:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
962 style sequential switch Smile Trigger in, out, and pushbutton per stage Smile
PostPosted: Fri Apr 06, 2018 1:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
looks good alan Smile
stolenfat
PostPosted: Sun Apr 15, 2018 8:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just finished a project I'm super excited about... so excited I made a little informative video with my free time.
https://www.youtube.com/watch?v=OMPya5KsqeY&t
 Filesize:  3.18 MB
 Viewed:  417 Time(s)
