Joined: Apr 03, 2004 Posts: 24676 Location: The Netherlands, Enschede
Posted: Mon Mar 19, 2018 4:24 am Post subject:
you diddit
Ah, at least it got a bit late I see yesterday  _________________ Jan
Posted: Mon Mar 19, 2018 4:31 am Post subject:
And yes, eight outputs is pretty nice already, I've implemented 15 in software ... but then again in my code it works a bit different .. guess I should try this bounded version as well (with the four bounds treatment options).
Rule 30
9 3 4 .. erm .. not 13 then? .. hmm, ah eight! .. yeah yeah as in 8647 .. 47 is an 88 .. pwew .. numbles! Last edited by blue hell on Mon Jan 14, 2019 2:04 pm; edited 1 time in total |
JovianPyx
Audio files: 224
Posted: Mon Mar 19, 2018 7:04 am Post subject:
I believe a pi-zero has enough pins to do this. Or Arduino. _________________ FPGA, dsPIC and Fatman Synth Stuff
Joined: Mar 11, 2014 Posts: 746 Location: New Zealand
Posted: Mon Mar 19, 2018 8:54 pm Post subject:
I'm looking forward to seeing your pcb for this
I still think it's a problem best solved in digital-land. |
Posted: Tue Mar 20, 2018 4:12 am Post subject:
Oh .. an analog implementation would be cool too  |
Posted: Fri Mar 23, 2018 7:58 am Post subject:
| AlanP wrote: | I'm looking forward to seeing your pcb for this  |
If I built it on perf I'd probably spread the circuit over 3 PCB's. 2 of them will have 4 muxes and a latch and 1 PCB with the rest.
Hmm, with the AND gates added to the boards with the muxes you get a system that could be easily expanded to any number of cells.
It would probably be more suitable for point to point wiring although I'm not a big fan of doing that, but that's partly because I don't
really have suitable wires for it. I bet synaesthesia could probably fit it on a pretty small board. It's almost tempting to just solder the
chips on a PCB with some headers connected to all the pins and then use dupont wires to connect everything together. Like a reverse
breadboard. _________________ "My perf, it's full of holes!"
Posted: Fri Mar 23, 2018 8:38 am Post subject:
I might test it with a PIC I actually have a nice extension with 32 inputs and 32 outputs that I can use for it.
heres a photo:
I have a small controller for it with a PIC but I'm not sure where that is at the moment. Actually a larger controller with
an LCD screen, a bunch of toggle switches and buttons and maybe pots could be usefull. I could add more in/outs to also
interface it with my lunetta stuff. I do have an Arduino which I haven't started with but that might be even more suitable
than a PIC for something like this as it would be easier to update the code. _________________ "My perf, it's full of holes!"
SoundCloud BandCamp MixCloud Stickney Synthyards Captain Collider Twitch YouTube Last edited by PHOBoS on Sun Apr 01, 2018 3:59 pm; edited 1 time in total |
piedwagtail
Posted: Fri Mar 30, 2018 6:19 am Post subject:
I've been using the small Altera MaxII CPLDs to build bigger things.
Using the block schematic design in Quartus; frowned on in the FPGA community.
The Chinese development boards are sub $10 on ebay.Search "CPLD EPM240 or EPM570"
Vidme took down the videos I posted in " A heretical approach to Lunetta design" but the block diagram file is still there at the end.
I've since dropped all the lines when I found they weren't necessary
R |
gabbagabi
Joined: Nov 29, 2008 Posts: 652 Location: Berlin by n8
Posted: Sat Mar 31, 2018 10:51 am Post subject:
where ordinary people have a bloodstream - Mr. Phobos must have a bus-system installed
maybe from the god of binarys in order to cure us poor humans from the analog sickness
