thru zero VCO
Page 2 of 2 [29 Posts]
Goto page: Previous 1, 2
gabbagabi
PostPosted: Sun Mar 18, 2018 7:52 am    Post subject: Reply with quote  Mark this post and the followings unread
the collector and the emitter of the reset transistor have to be swopped
in the schemo from post Mar 05, 2018
piedwagtail
PostPosted: Thu Apr 05, 2018 6:03 am    Post subject: Reply with quote  Mark this post and the followings unread
time flies like two years almost Shocked
I did breadboard the original design last year but couldn't see a use for it.
Slow_Riot's inclination for LFO use didn't seem that special.
Recent threads elsewhere, have got me to thinking about a One Operator FM module. Initially I thought of a LM13700 for an out VCA and a pitch in VCA. On further consideration perhaps LDR control is more in keeping with the simplicity.
The module could then hopefully be combined in cascade/mix with other OOFMMs (!) etc to generate FM percussion and drones with suitable EGs.
R
gabbagabi
PostPosted: Thu Apr 05, 2018 9:57 am    Post subject: Reply with quote  Mark this post and the followings unread
if i remember right
i had a lot of fun with this simple patch
as i had two of the triangle-core on the breadboard
 Filesize:  17.82 KB
 Viewed:  552 Time(s)
gabbagabi
PostPosted: Sun Nov 22, 2020 1:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi guys,
i had this in the simulator today.
I will call the circutit "IVAR".
May someone find it usefull or can get an inspiration out of it.
For some month i will not have access to any hardware to test it.
cu
 Filesize:  45.95 KB
 Viewed:  429 Time(s)
