Classic synth found at dump
Page 1 of 1 [17 Posts]
audiodef
Audio files: 63
PostPosted: Sat Nov 17, 2018 2:07 pm    Post subject: Classic synth found at dump
Subject description: My, oh my
Went to the dump today. While unloading recyclables, I noticed a keyboard in one of the electronics recycling bays. Curious - and thinking it was surely a Yamaha PSR or a Casio someone tossed - I walked over.
Nope.
It was a Korg Poly 800.
You're not supposed to take things out of the dump, but nobody was around, so screw it, I took it.
No idea if it works yet. I need to find a power adapter, or put in some batteries. There's a bit of rust around the battery cover, so I'll have to inspect that more closely.
I assume it was tossed because it doesn't work, but you never know. If it doesn't, maybe someone here would like to take it and fix it - and keep it.
More to come as I find out!
Korg Poly 800, rescued from dump
 Filesize:  2.42 MB
 Viewed:  549 Time(s)
Audiodef.com
Soundcloud
PostPosted: Sat Nov 17, 2018 2:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
https://www.youtube.com/watch?v=gUfq93PSuzk
Teardown, cleaning, and some repair of a Poly800. Might help you.
audiodef
Audio files: 63
PostPosted: Sat Nov 17, 2018 2:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, Alan. Cool
Audiodef.com
Soundcloud
audiodef
Audio files: 63
PostPosted: Sun Nov 18, 2018 8:41 am    Post subject: Reply with quote  Mark this post and the followings unread
So I opened it up today. It looks like someone left a couple of batteries in there, which leaked. This is the apparent reason for its trip to the dump. I'm hoping that's all it is, because this can be easily fixed.
I just need to unscrew whichever board the RAM battery is hidden under so I can replace that - maybe a la the video Alan linked above.
Not a good sign.
 Filesize:  2.35 MB
 Viewed:  482 Time(s)
Yep, not good.
 Filesize:  2.27 MB
 Viewed:  500 Time(s)
Ouch.
 Filesize:  2.55 MB
 Viewed:  488 Time(s)
But at least it's pretty much intact - hopefully.
 Filesize:  2.71 MB
 Viewed:  496 Time(s)
Audiodef.com
Soundcloud
audiodef
Audio files: 63
PostPosted: Sun Nov 18, 2018 12:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
I removed the corroded spring coil for the C cell batteries on one end. Now I'm trying to remove the plate on the other end. Using the flash on my camera shows just how bad it is. It appears to be inserted into a plastic slot. It's possible glue was involved, but I'm hoping it's just rust that's making it stick.
Pretty! Not!
 Filesize:  2.84 MB
 Viewed:  509 Time(s)
Audiodef.com
Soundcloud
audiodef
Audio files: 63
PostPosted: Sun Nov 18, 2018 1:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Gave up on trying to repair the battery terminals and ordered a PSU. Should arrive within a week, and then I'll know if I have a working instrument.
Audiodef.com
Soundcloud
PostPosted: Sun Nov 18, 2018 2:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
That last picture is beautiful BTW (zoomed in on it a bit) :-)
PostPosted: Sun Nov 18, 2018 2:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
That last picture is beautiful BTW (zoomed in on it a bit) Smile
indeed, lovely colors and textures. Razz
nice find damien!
(vinegar can be useful for cleaning up battery corrosion btw)
audiodef
Audio files: 63
PostPosted: Sun Nov 18, 2018 3:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I was thinking exactly the same thing. Nice colors, could make a nice cover photo for something with a well-placed filter.
EDIT:
Audio tech pun not intended. Razz
EDITEDIT:
It occurs to me from looking at the zoomed-in photo that I could clip the wing off the current terminal plate and find one that I can bend over the old one, then solder the wire onto the new one.
Audiodef.com
Soundcloud
PostPosted: Mon Nov 19, 2018 12:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
nah, just dremel the hell out of it Laughing
my synth
audiodef
Audio files: 63
PostPosted: Mon Nov 19, 2018 1:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, you know, recently, I dremelled my Nord in half...
Audiodef.com
Soundcloud
PostPosted: Mon Nov 19, 2018 4:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Laughing it'll never get old (neither did the synth)
PostPosted: Tue Nov 20, 2018 5:24 am    Post subject: Reply with quote  Mark this post and the followings unread
my synth
audiodef
Audio files: 63
PostPosted: Tue Nov 20, 2018 6:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Laughing
Audiodef.com
Soundcloud
audiodef
Audio files: 63
PostPosted: Sat Nov 24, 2018 2:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Got the AC power adapter. It powers up just fine. Have not heard it yet. Need to find a spot for it in my patch bay, which I will do later.
Audiodef.com
Soundcloud
1roomstudio
PostPosted: Sun Nov 25, 2018 10:26 am    Post subject: Reply with quote  Mark this post and the followings unread
So awesome that you are rescuing this bit of gear.
Thank you for sharing
https://www.instagram.com/1roomstudio/
https://markames.bandcamp.com
https://soundcloud.com/1roomstudio
https://www.youtube.com/channel/UCdOj3y4Q55K2nUX688PDt5Q
Reality is one thing... Perception is everything
audiodef
Audio files: 63
PostPosted: Sun Nov 25, 2018 10:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, 1roomstudio.
Update: It does work. So the next step is to take it apart, clean it up, replace the RAM battery, and put it back together.
Audiodef.com
Soundcloud
