gabbagabi
  Joined: Nov 29, 2008 Posts: 652 Location: Berlin by n8
ixtern
 Posted: Sun Jan 20, 2019 1:17 pm    Post subject:
Re: parametric EQ Subject description: from a SVF a Atenuverter and a mixer? |
 	  | g.gabba wrote: | 	 		  hi guys,
could you give me a hand?
is my thinking right or wrong?
can we use our building blocks/modules to form a parametric eq?
cu
gabigabba |
I think that parametric equalizer is simply set of bandpass filters plus one low- and one high-pass filter with a full control (means frequency, gain and bandwidth or Q). So yes, it could be build with a set of VCFs, if you really have such a whim. |
  Joined: Nov 23, 2015 Posts: 1319 Location: Netherlands
 Posted: Sun Jan 20, 2019 2:17 pm    Post subject:
vcf are usualy low pass filters... _________________  my synth  |
JovianPyx
Audio files: 224
 Posted: Sun Jan 20, 2019 3:29 pm    Post subject:
mmm...  a state variable VCF can easily be made multimode, and there's a lot of modulars that have state variable filters  because they are easy to build.
Anyway, for this application the state variable filter is probably ideal since you can get low pass, band pass and high pass. _________________ FPGA, dsPIC and Fatman Synth Stuff
  Joined: Apr 03, 2004 Posts: 24493 Location: The Netherlands, Enschede
 Posted: Sun Jan 20, 2019 4:02 pm    Post subject:
 	  | g.gabba wrote: | 	 		  | can we use our building blocks/modules to form a parametric eq? |
Yes, and you can do other stuff with it too.
When N is like 3 you can approximate voice formants (eaoiu), and when its a bit larger you can use it to do basic physical modeling. With N=11 I have a very nice bell sound.
The trick is then in finding the right parameters .. to do that manually is a bit tedious ... but still .. you can find tables on the webs. _________________ Jan
L´Andratté
  Joined: Sep 23, 2012 Posts: 151 Location: Hamburg, Germany
 Posted: Mon Apr 01, 2019 3:25 pm    Post subject:
 	  | Blue Hell wrote: | 	 		   	  | g.gabba wrote: | 	 		  | can we use our building blocks/modules to form a parametric eq? |
The trick is then in finding the right parameters .. to do that manually is a bit tedious ... but still .. you can find tables on the webs. |
Very interesting to stumble about this Blue Hell, can you give more clues?
"N" = feedback ratio?
Is it pinged or oscillating?
I have just come across this very similar approach
https://aether-machine.com/mutant-theory/
Was always fascinated by "analog" physical modeling, whatever that is---
And this seems to invite experimentation!
 	  | Quote: | 	 		  | The Mode switch changes the physical modelling behaviour between the wave equation and fluid flow, the latter tends to be more unstable. |
What might that mean(from above link)? |
 Posted: Tue Apr 02, 2019 10:06 am    Post subject:
The N = 3 refers to the number of parallel filters .. you can excite them with a saw or pulse shaped wave .. but add some noise for whispering .. self oscillation I never tested ... altough I had some idea to make a formant osciallator maybe ... being a set of oscillators tuned to formant frequencies.
The example software posted above has N=4. _________________ Jan
