Control range of knobs ?
Page 1 of 1 [4 Posts]
chapelier fou
PostPosted: Mon May 20, 2019 2:48 pm    Post subject: Control range of knobs ? Reply with quote  Mark this post and the followings unread
Just to check I'm not missing something : is there a way to change the min and max value controlled by a hardware knob ?
PostPosted: Mon May 20, 2019 2:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Not directly .. you can set a morph range and use a morph knob .. or use a cross fader and two constants connected to a control input and use the fader knob .. or some variation on that.
chapelier fou
PostPosted: Mon May 20, 2019 2:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks a lot for the super fast answer !
I've not gone into morphs for now, so i'll check this out. I had a feeling that it could be the solution.
PostPosted: Mon May 20, 2019 3:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Happened to stumble over just about when you posted & remembered :-)
