mike page
Joined: Sep 26, 2016 Posts: 134 Location: norwich, uk
Posted: Mon May 27, 2019 12:53 am Post subject:
Resistance swing to CV conversion |
Lets say I have a resistance change swinging from 1k to 100k in a fairly linear.
Whats the best way to convert this into a useful control voltage for a eurorack system? Ideally maintaining the linearity of the response.
All I can think of currently is using it as one half of a carefully balance voltage divider, or somehow use with a LM317 or similar.
Any thoughts? |
ixtern
Posted: Tue May 28, 2019 10:57 pm Post subject:
Re: Resistance swing to CV conversion |
| mike page wrote: | Lets say I have a resistance change swinging from 1k to 100k in a fairly linear.
Any thoughts? |
Depends what kind of resistance. If purely resistive, then connect it to reference voltage in a voltage divider circuit. If other kind (e.g.semiconductor type) - current source may be needed and careful reading of datasheet (linearity, max voltage and current...).
In every case Op Amp voltage follower with high input impedance or other way speaking with low bias currents is needed to avoid linearity errors.
LM317 is not suited for precision voltages. Fine more stable voltage source - for entry level it may be 50ppm TL431 or (even better) old 30ppm uA723. Upper case is 2ppm LT1021BCN8, 3ppm REF5040, 2.5ppm REF102CU. |
JovianPyx
Audio files: 224
Posted: Wed May 29, 2019 6:38 am Post subject:
Using an opamp, create an inverting amp.
Ground the noninverting input.
Connect the variable resistance to the inverting input.
Connect a fixed resistor larger than the highest value possible from the variable resistor from the opamp output to the opamp inverting input.
Put a fixed negative voltage on the other end of the variable resistor. The voltage should be small enough to give a full scale output (10 volts) when the variable resistance is at max ohms.
The variable resistor will provide and control the current into the opamp.
The output will change voltage as the resistor changes value. The higher the resistance, the higher the voltage. The resulting voltage should linearly follow the changes in the variable resistance. _________________ FPGA, dsPIC and Fatman Synth Stuff
mike page
Posted: Wed May 29, 2019 10:10 am Post subject:
| Amazing! Thanks!! |
JovianPyx
Audio files: 224
Posted: Wed May 29, 2019 1:20 pm Post subject:
On second thought, it won't be linear. Part of the range will be close to linear. The same is true of the voltage divider method. _________________ FPGA, dsPIC and Fatman Synth Stuff
Joined: Apr 03, 2004 Posts: 24557 Location: The Netherlands, Enschede
Audio files: 303
Posted: Wed May 29, 2019 3:51 pm Post subject:
So this would be resistance to voltage conversion, right? So ... how about then .. maybe:
Set up a current mirror, control the ingoing current from a reference voltage and that resistor, then at the other end of the mirror use a fixed resistor equal in size to the lowest value of the input resistor (with a larger value it would clip against ground or Vcc, depending on NPN or PNP config).
Then maybe use an opamp follower after that to get a lower output impedance. The follower would have to invert .. or the mirror would have to be done with PNP transistors .. I'd use NPN tho I think .. without spending much thought on it ;-)
Or alternatively ... set up something with an OTA .. some fixed small input value on its inputs, and control the gain ( Iabc) with the resistor.. basically this is the same idea .. as an OTA is mostly a bunch of current mirrors, it would need a bit less build space thoughI think.. but .. watch the Iabc to not get too large. This would be less of an issue with a discrete current mirror. _________________ Jan
mike page
Posted: Thu May 30, 2019 9:34 am Post subject:
Once again thanks, that's awesome.
Everyone loves a sassy lil' transistor circuit! |
