Everything you always wanted to know about wavetables
Page 1 of 1 [8 Posts]
PostPosted: Mon Sep 16, 2019 10:47 pm    Post subject: Everything you always wanted to know about wavetables
Subject description: but were afraid to ask...
http://synthtech.com/waveedit/
A very nice website where you can download (free) the program WAVEedit.exe to get acquainted with wavetables, how they sound and look like.
You can even save them as a .wav files
my synth
PostPosted: Tue Sep 17, 2019 7:15 am    Post subject: Reply with quote  Mark this post and the followings unread
hmm I just saw a video yesterday about a module or synth with wavetables that could be edited and there was some software for it
to create them, listen and store (I believe it was also free). Could have been the same thing but let me see if I can find it again.
edit: found it.
The module is the Tabula Rasa which is an arduino/ATmega328 based DIY wavetable oscillator.
Wavetable editing software can be found here: https://github.com/surgesg/tabulaRasa/tree/master/tabularasa_src/software/tabulaRasa_Processing
I haven't tested it but I don't think it can save as wav, could still be useful though. Here's the video I saw it in: https://www.youtube.com/watch?v=
There's also a muffwiggler thread about it here: https://www.muffwiggler.com/forum/topic-27829.html
ixtern
PostPosted: Wed Sep 18, 2019 8:50 am    Post subject: Reply with quote  Mark this post and the followings unread
My Arduino-controlled wavetable double VCO (DCO rather?). Overcomplicated, but I had to use buffers to avoid glitches (race condition artifacts). Project suspended over a year as I change my direction to analog VCOs.
74HC4040 counters were used in the last version instead of 4040.
wavetable_vco_v1.pdf
 Filename:  wavetable_vco_v1.pdf
 Filesize:  193.82 KB
 Downloaded:  526 Time(s)
ixtern
PostPosted: Thu Sep 19, 2019 12:44 am    Post subject: Reply with quote  Mark this post and the followings unread
And here are the AD9833 hex programming codes for MIDI range tempered musical scale x 256 (as 8-bit wavetable VCO needs clock frequency 256 times greater than synthesized waveform). Processed with Excel.
"freq diff" column is the difference between nominal frequency ("Frequency" column) and VCO output frequency ("AD9833 freq out" column/256).
conversion2.pdf
 Filename:  conversion2.pdf
 Filesize:  127.53 KB
 Downloaded:  508 Time(s)
PostPosted: Thu Sep 19, 2019 1:47 am    Post subject: Reply with quote  Mark this post and the followings unread
It's offtopic, but this is how I program the AD9833:
Code:
/* name AD9833 calculation macros */
#define AD_F_MCLK 16000000 // Clock speed of the ad9833 reference clock
#define AD_2POW28 268435456 // Used in calculating output freq
/* Macro that calculates the value for a ad9833 frequency register from a frequency */
#define AD_FREQ_CALC(calc_freq) (float)(((double)AD_2POW28/(double)AD_F_MCLK*calc_freq)*4)
frequency_word = AD_FREQ_CALC(frequency_AD9833);
high = uint16_t (AD_FREQ0 | (0x3FFF&(uint16_t)(frequency_word>>16)));//HIGH word for DDS
low = uint16_t (AD_FREQ0 | (0x3FFF&(uint16_t)(frequency_word>>2 )));//LOW word for DDS
 wave shapes are:
 AD_SINE, AD_SQUARE or AD_TRI
 remember: AD_SQUARE puts out a square of 0 - 5volt, while AD_TRI and
 AD_SINE puts out 0 - 0.65 volt
ad9833_send(AD_SINE);// set waveform shape
ad9833_send(low);//low word
ad9833_send(high);//high word
my synth
ixtern
PostPosted: Thu Sep 19, 2019 2:16 am    Post subject: Reply with quote  Mark this post and the followings unread
And this is how I am doing it:
Code:
// Set frequency of the first AD9833 unit using global variables
void SetAD9833_1(void)
    // With 8000000 clock sometimes problems happens (corrupted data)
    SPI.beginTransaction(SPISettings(4000000, MSBFIRST, SPI_MODE2));
    //WriteRegisterAD9833_1(0x2000);  // no reset bit NOT WORKING
    WriteRegisterAD9833_1(0x2100);  // reset bit set
    WriteRegisterAD9833_1(AD9833_1_256_LSB);
    WriteRegisterAD9833_1(AD9833_1_256_MSB);
    WriteRegisterAD9833_1(0x2028); // set square wave, reset bit cleared
    SPI.endTransaction();
Thread starts to be half-Arduino now Smile
PostPosted: Thu Sep 19, 2019 2:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Difference is that you get your register data from a lookup table and I calculate the register data from a given frequency.
my synth
ixtern
PostPosted: Thu Sep 19, 2019 3:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I wanted to do it faster because I've planned to control 8 VCOs from one Arduino with many additional functionalities.
