Mixing analog voices: DC or AC ?
Page 1 of 1 [13 Posts]
KammutierSpule
PostPosted: Fri Jan 10, 2020 1:43 pm    Post subject: Mixing analog voices: DC or AC ? Reply with quote  Mark this post and the followings unread
Most of the schematics mixers I see are mixing with DC ( a resistor divisor and then a buffer) but, does it makes sense to mix voices in AC, removing any of the offset ?
JovianPyx
Audio files: 224
PostPosted: Fri Jan 10, 2020 2:35 pm    Post subject: Re: Mixing analog voices: DC or AC ? Reply with quote  Mark this post and the followings unread
Yes.
In audio mixers, I've seen only AC coupling. There is no way to know whether a device plugged into the mixer contains DC or not. Since DC has no sound, removing it causes no problems. A DC mixer is used in a synthesizer to mix CVs. If a DC mixer is ever used for audio, it's done because the user ran out of AC mixers. DC in an audio signal reduces dynamic range.
Time flies like a banana.
corruptio optimi pessima
PostPosted: Fri Jan 10, 2020 3:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
One can often see switches at the input so you can choose between AC and DC input configuration per input so you can mix audio with CV
my synth
VA1
PostPosted: Sat Jan 11, 2020 2:53 am    Post subject: Reply with quote  Mark this post and the followings unread
With DC you get clipping fast.
PostPosted: Sat Jan 11, 2020 4:47 am    Post subject: Reply with quote  Mark this post and the followings unread
If you e.g. one channel set to DC (for Control Voltage) and the other(s) to AC (for Audio) you can modulate the CV.
Great stuff!
my synth
efluon
PostPosted: Sat Jan 11, 2020 1:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Excellent idea, need to make some passive highpasses now!
KammutierSpule
PostPosted: Sun Jan 19, 2020 2:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Let me clarify my question. There are two scenarios:
- On a voice, how do you mix the OSC?
Eg: you have a Square Osc, sub-Square Osc, etc how do you sum it? in DC or AC?
- How do you mix multiple voices in a synth?
Moosgummi
PostPosted: Mon Jan 27, 2020 11:43 am    Post subject: Reply with quote  Mark this post and the followings unread
All your examples are in the audio range, so AC it is.
KammutierSpule
PostPosted: Tue Jan 28, 2020 3:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks is makes sense!
Another related basic question.
While summing all OSCs / or Voices, at some pointing it is possible that it starts clipping / saturate the values.
I believe the correct way is to SUM all without any attenuation and let the user adjust levels so it will stop saturate.
But are there any other concerns?
Should it reduce any levels in SUM (eg multiply by 0.5)?
Or should the SUM handle some "head room" to allow mixing with less saturation?
ixtern
PostPosted: Tue Jan 28, 2020 4:28 am    Post subject: Reply with quote  Mark this post and the followings unread
All depends on context. If mixing external signals, AC coupling is reasonable.
If mixing internal known signals e.g. typical eurorack +-5V without DC offset, then DC may be better (no low frequency signal drop, less parts).
So, if such mixer is internal part of thoughtfully designed signal path, it may be DC coupled. If not, AC coupling is better.
PostPosted: Tue Jan 28, 2020 5:44 am    Post subject: Reply with quote  Mark this post and the followings unread
A thoughtful designer would put a small switch in his/her design to choose between AC and DC Cool because you never know what is connected to the input...
my synth
ixtern
PostPosted: Tue Jan 28, 2020 5:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Don't know if it is a good idea if you don't know what is connected to the input.
AC and DC path may require different design decisions.
E.g. if you are designing AC path, you may use op cheap op amps with relatively big offset input voltage and temp drift. in CV DC path you shouldn't do that.
In AC path, if signal volume is low, you may choose low-noise op amps and low input impedances (e.g. input pots 10k, not 100k as for CV).
etc. etc.
PostPosted: Tue Jan 28, 2020 6:09 am    Post subject: Reply with quote  Mark this post and the followings unread
A thoughtful designer can tackle all those problems Rolling Eyes Very Happy
my synth
