JovianPyx
Audio files: 224
JovianPyx
Audio files: 224
Posted: Fri Sep 28, 2018 8:57 am Post subject:
I plan to make more out of it, add acoustic guitar and KS for bass.
Hmm. Seems I misspelled Ukulele in the title. _________________ FPGA, dsPIC and Fatman Synth Stuff
Joined: Apr 24, 2009 Posts: 2521 Location: Bristol UK
Audio files: 505
JovianPyx
Audio files: 224
JovianPyx
Audio files: 224
Posted: Thu Oct 18, 2018 10:45 pm Post subject:
A couple questions:
All the recording done with contact mics?
What kind of strings? They sound a lot more metallic than the typical nylon.
A soprano?
My eldest has been quite taken with the ukulele for nearly a year now, and he's been noodzhing to get a studio together when we can afford it (and when he meets my requirements about school) and I'm interested in what special things we might need. |
JovianPyx
Audio files: 224
Posted: Fri Oct 19, 2018 7:56 am Post subject:
Thanks PHOBoS
elmegil: The instrument is a Mele Tenor Ukulele. The last two recordings were done using a new contact mic "John Pearse" with the mic on the treble end of the bridge. The signal was recorded through a DigiTech Polara reverb into Audacity. The recording was then mildly EQ processed to slightly boost bass and slightly attenuate highs.
The strings are nylon for the upper two and wire wound nylon for the two lower strings. This instrument uses the low G tuning (not traditional Hawaiian). I have a 10 band guitar EQ pedal that I want to try to preprocess the mic signal before sending it to the reverb. The mic is very sensitive and tends to respond lop-sidedly well to highs. I will also try putting the mic on the bass side of the bridge.
What I've read about ukulele is that it's a difficult instrument to mic and I can understand that conclusion.
The mic comes with two methods of installing - there is a permanent adhesive dot (circle) on one side with the adhesive covered by a sort of wax paper. I did not use that. There are also 2 pieces of temporary adhesive included which is what I used to stick the mic to the bridge. It appears to work with the temp adhesive on the side opposite the permanent. The instructions say that the permanent adhesive can be removed if not used. I've not tried that. I read from one reviewer (who seemed really pissed about the permanent adhesive) that it's difficult to remove. From my experience, the mic is sensitive on both sides. Watch hanging sleeve touching the mic while playing, it will cause noise. I play with short sleeves. _________________ FPGA, dsPIC and Fatman Synth Stuff
Posted: Fri Oct 19, 2018 8:43 am Post subject:
great, thank you for the detailed reply  |
JovianPyx
Audio files: 224
JovianPyx
Audio files: 224
Posted: Fri Dec 28, 2018 8:29 pm Post subject:
I just got both ukuleles back from the luthier shop where both were intonated and both had Aloha Twin mics installed. The 4 string tenor also had a problem with the fingerboard which they fixed. Action was setup on both instruments. They are so much better to play now. And since both have built in mics, it's too easy to plug in and record when I practice.
So here are some snippets of working with the 4 string tenor Mele ukulele.
Played through a DigiTech Polara on plate setting.
 Download (listen) |
| Filename: |
seg_00_rec_20181228-172931.mp3 |
874.35 KB |
| Downloaded: |
2747 Time(s) |
 Download (listen) |
| Filename: |
seg_01_rec_20181228-172931.mp3 |
1.98 MB |
| Downloaded: |
2760 Time(s) |
 Download (listen) |
| Filename: |
seg_02_rec_20181228-172931.mp3 |
1.54 MB |
| Downloaded: |
2808 Time(s) |
 Download (listen) |
| Filename: |
seg_03_rec_20181228-172931.mp3 |
1.38 MB |
| Downloaded: |
2696 Time(s) |
JovianPyx
Audio files: 224
Posted: Sat Dec 29, 2018 7:05 pm Post subject:
Some more ukulele stuff, these were done on my 8 string Baritone ukulele.
 Download (listen) |
| Filename: |
seg_00_rec_20181229-132912.mp3 |
1.04 MB |
| Downloaded: |
2701 Time(s) |
 Download (listen) |
| Filename: |
seg_01_rec_20181229-132912.mp3 |
730.67 KB |
| Downloaded: |
2774 Time(s) |
 Download (listen) |
| Filename: |
seg_02_rec_20181229-132912.mp3 |
458.83 KB |
| Downloaded: |
2757 Time(s) |
 Download (listen) |
| Filename: |
seg_03_rec_20181229-132912.mp3 |
416.79 KB |
| Downloaded: |
2661 Time(s) |
 Download (listen) |
| Filename: |
seg_04_rec_20181229-132912.mp3 |
1.12 MB |
| Downloaded: |
2761 Time(s) |
JovianPyx
Audio files: 224
Posted: Sat Dec 29, 2018 7:15 pm Post subject:
more
 Download (listen) |
| Filename: |
seg_05_rec_20181229-132912.mp3 |
1.11 MB |
| Downloaded: |
2686 Time(s) |
 Download (listen) |
| Filename: |
seg_06_rec_20181229-132912.mp3 |
2.42 MB |
| Downloaded: |
2692 Time(s) |
 Download (listen) |
| Filename: |
seg_07_rec_20181229-132912.mp3 |
1.12 MB |
| Downloaded: |
2772 Time(s) |
 Download (listen) |
| Filename: |
seg_08_rec_20181229-132912.mp3 |
1.46 MB |
| Downloaded: |
2726 Time(s) |
 Download (listen) |
| Filename: |
seg_09_rec_20181229-132912.mp3 |
1.5 MB |
| Downloaded: |
2723 Time(s) |
JovianPyx
Audio files: 224
Posted: Sat Dec 29, 2018 7:21 pm Post subject:
more
 Download (listen) |
| Filename: |
seg_10_rec_20181229-132912.mp3 |
937.2 KB |
| Downloaded: |
2653 Time(s) |
 Download (listen) |
| Filename: |
seg_11_rec_20181229-132912.mp3 |
1.7 MB |
| Downloaded: |
2813 Time(s) |
JovianPyx
Audio files: 224
JovianPyx
Audio files: 224
JovianPyx
Audio files: 224
JovianPyx
Audio files: 224
JovianPyx
Audio files: 224
