today> Twyndyllyngs Chez Mosc
 Forum index » DIY Hardware and Software » Rob Hordijk DIY Designs
Show your Benjolin / Zeitgeist
Post new topic   Reply to topic Moderators: Rob
Page 5 of 5 [115 Posts]
Goto page: Previous 1, 2, 3, 4, 5
PostPosted: Fri Mar 24, 2017 8:08 am    Post subject: Reply with quote  Mark this post and the followings unread
But we DO care! Smile
Nice job!
mcop
PostPosted: Fri Mar 24, 2017 8:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Indeed we do! I've been following your progress here and over at Muff's - looking great.
Audio files: 235
PostPosted: Fri Mar 24, 2017 11:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Yup, very very nice. Very Happy
yegglet
PostPosted: Thu Apr 05, 2018 4:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's mine! Freshly built!
I was going to stretch leather over the faceplate but I think I'll just gussy it up with some decoupage instead..
Audio files: 235
PostPosted: Fri Apr 06, 2018 5:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
yegglet welcome to electro-music.com
Your Benjolyn looks great...
frequenzteiler
PostPosted: Sun Apr 15, 2018 1:57 am    Post subject: Reply with quote  Mark this post and the followings unread
heres mine . its called bifold benjolin
6 pots to adjust the level of osc 1, 2 and pwm signal not implented yet . dont know if i really need them . but im pretty happy so far .
Audio files: 235
PostPosted: Mon May 14, 2018 12:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow, beautiful.
dragosandriana
PostPosted: Mon Oct 28, 2019 4:53 am    Post subject: Benjolin / Zeitgeist - "Globalizer" Reply with quote  Mark this post and the followings unread
The "Globalizer" contains two benjolins (for patching dialogue) and one zeitgeist.
If you're interested, I can post a video later with it functioning in patch mode.
Thank you, Rob Hordijk!
Enjoy!
 Filesize:  208.2 KB
 Viewed:  602 Time(s)
 Filesize:  106.97 KB
 Viewed:  602 Time(s)
 Filesize:  336.86 KB
 Viewed:  599 Time(s)
 Filesize:  367.5 KB
 Viewed:  593 Time(s)
 Filesize:  166.29 KB
 Viewed:  591 Time(s)
Audio files: 326
PostPosted: Mon Oct 28, 2019 3:40 pm    Post subject: Re: Benjolin / Zeitgeist - "Globalizer" Reply with quote  Mark this post and the followings unread
dragosandriana wrote:
The "Globalizer"
You even put a knob on Rob's home I see Laughing
Nice build! .. I would watch that video Cool
dragosandriana
PostPosted: Sat Feb 29, 2020 1:42 am    Post subject: 2XBenjolin1Xzeitgeist_globaliser
Subject description: in action
https://www.youtube.com/watch?v=BnV9yJ5kRXg&feature=youtu.be
It also allows patches between the two benjolins, thing that is not performed in the video.
Audio files: 235
PostPosted: Wed May 06, 2020 11:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Just watched the video. Very cool. That's a great instrument.
mattkuebrich
PostPosted: Wed Feb 09, 2022 10:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's a quick test of the Zeitgeist circuit, which I recently adapted into a PCB/panel for Eurorack. I'm thrilled it seems to be working! I also did a 10HP Euro Benjolin a few years back, which you can see in the video.
https://www.instagram.com/p/CYux4pghnXf/
LFLab
PostPosted: Sun Mar 06, 2022 1:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Pretty cool, not many Zeitgeist builds around. Would like to build one myself, but there are some interesting other contenders around (NLC Delay no more Very Happy ).
zaphod betamax
PostPosted: Sat Mar 26, 2022 7:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Somewhat based on the Rungler.
Circuit has been changed multiple times.
When I get it right I can post.
Basically there are 2 square VCOs (no musical scaling)
formed with two slots of a CD4093BE.
Each of the VCOs feed a CD4517BE shift register with the
shift register feeding a 8 DA array and a MCP6002 opamp buffer.
These CVs control a F11V FET vactrol with the resistor element
across the resistor element of the VCO.
Each oscillator can either get its data from:
A "random" ring oscillator
-feedback slots on the CD4517BE,
or normalled to the square outputs on the CD4093s.
I need to buy 2 4 position switches!
Both oscillators feed a CD4070BE XOR which feeds a simple
2N7000 "VCA".
Very early days.
https://www.youtube.com/watch?v=aJAYRqCYBCE
zaphod betamax
PostPosted: Sun Apr 10, 2022 10:21 am    Post subject: Reply with quote  Mark this post and the followings unread
The Retroverb generates all sounds and reverbs. The VCF LFO is used to modulate Fc as well. The Audio output of the Retroverb acts as data input for a CD4517BE 8 Bit shift register. The clock is 1/16 notes from CV OCD, with MIDI Monotribe as master clock, it does not sound, it only makes the midi clock. The 8 bit shift register feeds an 8 bit R2R array which is fully buffered by a MCP602 single sided 5Vdd (0-5V CV). The CV controls the Fc on the Retroverb, which in-turn is fed back as data to the SR.
https://youtu.be/e3VhqNR2Iwg
