What is bass?
Page 1 of 2 [29 Posts]
PostPosted: Fri Jun 03, 2005 8:42 am    Post subject: What is bass? Reply with quote  Mark this post and the followings unread
I guess I should state that I do know what bass is. What I am trying to discuss here is the fact that many don´t really know what they are hearing bass wise.
OK.. an oberservation:
Many of my friends don´t really enjoy that deep and clean bass from high quality loudspeakers. they can enjoy the deep boom.. and when the room starts to move.. but most tend to like that traditional 70-130 hz crunch with a lot of driver distortion. The mixes these guys are making tend to reflect this. When given access to studio monitors that don´t distort violently, they don´t know how to understand what they hear. The fact that very cunning producers often add distortion and other artifacts to the bass.. in order to give the inpression of "loud bass" and speakers driven to the brink of selfcombustion.. is of course also messing up people´s understanding of bass.
I think it is not really possible to make mixes that "translate" if one doesn´t understand how bass really sounds and how various gear really handles deep bass. This is of course possible to understand intuitively.. but..
Many will choose their studio monitors based on the specs. alone. So.. if you choose a pair of studio monitors that will hit 25HZ.. those will be better than some that "stop" at 50 hz. ? this is of course not always the case. More important is the fact that most pro studio monitors that can go seriously deep will be better at the 50-200 Hz range than say a pair of M-Audio BX5s or similar. On the other hand.. the huge new nasty monitors that hit 25Hz won´t neccesarily perform well at 30-25 Hz anyway.
Flickr
seraph
Editor
Editor
Audio files: 33
PostPosted: Fri Jun 03, 2005 9:05 am    Post subject: Re: What is bass? Reply with quote  Mark this post and the followings unread
really Question what do you have, toothed whale ears Question Shocked
PostPosted: Fri Jun 03, 2005 9:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes..
Well.. but I hoped to get some Kassen insights and more though.
I hope to get into a discussion about how we percive bass and how to handle it productionwise. You know..
Flickr
astroid power-up!
PostPosted: Wed Jun 29, 2005 12:32 am    Post subject: Reply with quote  Mark this post and the followings unread
elektro, one of your pieces, the one about the sinking ship in WWII, that had some of the most wicked bass sounds i think i've ever heard.
yeah. working with sine waves exclusively in a d&b context, i became slowly aware of tone perception, and my mixes became brighter and brighter. originally, i loved low, sub 50hz sounds, because of how they rattle the brain. however, in a mix, it's hard to be aware of them unless they are distorting (and therefore creating artifacts in the aforementioned higher range).
Astroid Power-Up!: "googleplex" available at:
http://cdbaby.com/cd/googleplex
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Wed Jun 29, 2005 1:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Exactly. I was a fan of deep bass for quite a while (I still am Wink) and tended to put alot of it in mixes. When I first got monitors and learned about EQ and the like, I'd just grab 58-63Hz on the kick/bass and gain like crazy Laughing Needless to say, we (myself and my mate who I write tracks with) learnt a hard lesson when we played our first "proper" gig and all our stuff sounded very "distant" because there was too much bass and we couldn't turn the volume up much for fear of killing the PA system. Embarassed
I think it's very important to spend alot of time working around the 70-150 range and getting that clean. If people can hear your bass around this range and it sounds good (ie, not muddy and crap) then at least the bass will translate well onto hi-fi's and PA systems alike, and you don't get a shock when you play it to your friends over a cheap hi-fi and they say "where's the bass???" Laughing
Sine wave basses are great, but mean nothing unless the track is played over a good system. You just have to make sure they have a good attack transient so you can hear the start of the notes on a typical system. That way, when your bassline goes into the sub regions the listener can hear the beginning of each note as it move down into the subby, bassy as hell regions and then rise back out again. Makes you go "woah, that bass is so low I can't even hear it", because you know the bass is there. It's done well on Adam F's early drum and bass stuff (like his Colours album).
PostPosted: Wed Jun 29, 2005 2:50 am    Post subject: Reply with quote  Mark this post and the followings unread
I was meditating on the hard question. :¬p
No, there is a lot going on at the same time, all intertwined, as usual.
We call the low frequency range "bass", we call certain instruments (like the bass-guitar and the stand-up bass) "bass" too and just to complicate matters further we also call anything that roughly takes the compositional role that those instruments would take "bass" too, even if it´s in a completely different spectral area. The 303 is a good example of this, 303 "basslines" are often mostly high-mid. Some punkbands played with the bass lines higher then the lead guitar´s; listen carefully to some Joy Division.
This is all tremendously confusing, particularly because modern popular culture dictates that anything needs lots and lots of "bass" because "bass" equates additude and being subversive. This creates such silly things as dance tracks with lyrics speaking at length on how much "bass" the (often novice) composer uses while there seems to be very little bass there. All of this, I was told, relates to sex (which inherently means we should discuss that side of it because anything relating to sex usually has large social effects with which fun or trouble can be had.), aparently the most primitive side of our brain, the one we share even with reptiles, still asumes low tones to be mating calls.
Ok, so, we want to have lots and lots of bass so we´ll apear to have lots and lots of additude and so we´ll sell well, right? Wrong. Having lots of bass takes lots of energy from the poor amp, meaning there will be less energy for other stuff, we´ll lose lots of bandwith, speakers will start acting up and so on. It´s all good and well that your synth could produce a 20Hz tone, the PA you´ll perform on most likely can´t, if you are lucky it´ll go down to 50Hz and even then the notes above aply.
Fortunately we don´t need all that bass at all, our ears aren´t even that sensitive in that region, our perception of pitch down in the bass area is also quite bad and so on. I think a much better idea is lying. We can pretend that we have a lot of bass. For this we can use a bit of HP filtering, then boost the low-mid to compensate and add punch, your hearing psychology will compensate and add in the lower harmonics that are now missing. This is actually going on already when we we listen for a bass guitar´s melody; in brighter notes this is much easier to follow then in the realy low, muffled ones since in the brighter notes we actually track the higher harmonics. This illusion is quite powerfull; when monitoring on headphones it´s quite possible to imagine you are feeling the low notes vibrate on your chest when in fact the room will be nearly silent. On a related note; if you can point at the location of the sub when entering a room there is likely some amount of distortion involved that makes the sub generate harmonics in the lower mid area. This is quite common, particularly in the cheaper "surround sets" (I sugest you don´t invest in those and spend you money on a proper stereo, but those are out of fashion)
Next up we need volume. We´ll just turn it up realy loud, right? Wrong (again! with audio it´s rarely simple). Actually the real volume of a note has not that much to do with how loudly we preceive it to be; it´s the attack of the note that counts for our hgearing psychology. If we suply our bassline´s sound with a little click or burst or midrange sweep or similar during the attack and we keep that one loud the rest can go a bit down, freeing up headroom and so on. The "attack" setting on dencent compressors can do this, avoid compressors that lack one for bass or rithem use unless you are very sure of what you are doing and why (actually you should probably avoid compressors in general if you aren´t sure because of this, amongst other factors, nothing can mess up a nice piece of music quite like compressors).
The important thing here is to realise that it doesn´t matter at all what your music *is* in most cases. Far more important is what it sounds like which, given that our brain should be considdered a part of our hearing, is often a very different thing.
Productionwise I think many basslines can be improved by enabeling the lowcut (unless it´s unreasonably high, 100Hz is a bit high already), then adding a bit of boost in the higher bass/ lower mid area on a eq, as always I prefer fully parametric analogue eqs here but from time to time a fir one with latency compensation will be requirered, particularly if there is a need to preserve the natural aspects of some recordings. If the bass sound in question lacks enough harmonics for this you can considder overdriving it a little on the input of your desk (Behringer need not aply, D&R ar A&H prefered) but it may be wiser to go back to the drawing board and restructure the sound in your synth. Cutting the bass is generally considered "bad" because generally people believe more bass and lower bass is better, this makes people object heavily as soon as you even sugest enableing it (Kassen, 2005). Do it secretly behind their back if need be, then charge them for getting "more bass".
PostPosted: Wed Jun 29, 2005 4:27 am    Post subject: Reply with quote  Mark this post and the followings unread
I guess it has some bass in there somewhere Very Happy That kind of deep bass is what makes the woofer cones go flooooooof-rabbarabbarabbarrrrrGrrrrllllOINK ..
One problem with that piece and a few others is that sub 80hz freqs have a little too much gain.. and a lot of loudspeakers don´t love these pieces at all. Vented enclose designs, rated at like 30-40HZ will quite often selfcombust when these pieces are played loud. Fact is that pretty much 98% of all loudspeakers out there are designed in order to show amazing specs and perform OK when used for pop music and rock. These products will handle impact sounds like drums and stuff like that far better than continuos growling sub signals. Cone ringing ( and often mixed with internal reflexes in the enclosure ), is still a really large problem. Some of the larger Mission speakers with those transparent woofer cones ( mid 80s?) sounded fine when playing rythmic 80s stuff like Yello. Classcial music or something like "the sinking of the scharnhorst" would make these speakers sound really bad.
Flickr
PostPosted: Wed Jun 29, 2005 4:50 am    Post subject: Reply with quote  Mark this post and the followings unread
These are great points, Kassen. Very Happy
Flickr
PostPosted: Wed Jun 29, 2005 4:52 am    Post subject: Reply with quote  Mark this post and the followings unread
That´s all good and well, but if your piece sounds like crap on 98% of all speakers then I think it´s worth serious consideration to mix it down in a different way, perhaps using some of my tricks above....
PostPosted: Wed Jun 29, 2005 4:57 am    Post subject: Reply with quote  Mark this post and the followings unread
PostPosted: Wed Jun 29, 2005 5:19 am    Post subject: Reply with quote  Mark this post and the followings unread
I am tweaking the mixes some. However, I don´t see this as much of a problem anyway. I am not making dance / pop music. The main point about these specific pieces is that I am applying a different set of estethics more along the lines of performed acoustic orchestral music rather than the club sound. It is however a problem that a lot of consumer playback devices cannot do this well at all, but I guess they will build it if the music starts to show up on CD. One important issue is however to understand how the woofer cone vibrates at say 20-40 HZ and how the cone excursion works at high levels. A complex bass signal with say several bass drones moving up and down in pitch and with impact components hitting in for the harmonics above 130 hz and so on will sound less cool on most gear out there. Too bad. I still think it is valid to make such music, but your production suggestions won´t work too well on such material. We need better playback devices.
However, your suggestions are quite excellent anyway. I have often stated that pop music has little bass anyway, that is why it sounds bassy and loud. The same methods apply for any production of music with a beats. Basscut is an excellent suggestion. It is very smart to do some serious bass management. If not we will often end up with a muddy bassy mix that doesn´t have either impact or volume. This can be taken even further during final mixdown or if doing layered mastering. Beats and channels and can be sidechained in order to do signal ducking on the 8ths or 16ths or whatever.
Flickr
opg
PostPosted: Wed Jun 29, 2005 5:43 am    Post subject: Reply with quote  Mark this post and the followings unread
I always worry about not having enough bass in my songs. Sometimes I just avoid it. Like on "Anglerfish," I didn't put any bass notes at all, just a kick drum. Then I didn't trim off the low end on the other sounds like I normally would with bass. The water bubbles, for example, have more of a low end than I had anticipated. If I had a bassline in that song, the bubbles would have had their low end cut and the higher pops and gurgles of the bubbling would have been more noticeable. In that song, I just decided what was more important.
On every song I make, I constantly switch back and forth between my M-Audio SP5Bs (small, but reliable), and a big old Sony stereo. When I can hear those low-mids on the SP5Bs, the lows on the Sony, and there's nothing wasting power below 40 Hz when viewing the frequency spectrum, I'm usually happy with the results.
PostPosted: Wed Jun 29, 2005 6:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmmm, most of my tips are indeed more apropriate for more "popular" types of music but if you want to release your music and want it played on home stereos then you´ll need to do something about those problems. You simply can´t sell cd´s that will make stereo's choke, then blame it on the stereo's. For soundsystems it´s even harder.
Industrial ambient has been around for decades and manifacturers of audio gear seem in no great hurry to start building sets suitable for playing it on. If anything the quality of home audio is going down; suround sets are getting popular meaning people invest roughly a third (if that much) of what they once invested in one channel of amplification and speaker. First people went down from vinyl to cd and from reels to casette, now people are moving towards mp3; at this rate they´ll be listening to 4bit sounds on their computer case´s internal speaker in a few years, claiming it´s a improvement.
Still; many artists are able to mix drones down in a way that gets across quite nicely on the average system. I think it´s too easy to blame it all on consumer gear. Quite a few of my tips will work on this material to some degree and of cource this material is affected by the exact same psychological phenomena. You can do subtile modulations in the 20-40Hz regions and indeed that´s perfectly valid but you have to realise that our hearing isn´t very sensitive to modulations in that range at all; if they need to be perceptible you´ll need higher harmonics for the ear to track anyway. Did you try fir-based eq´s? I think that for this type of material those will work much better then iir. They should leave all phase interactions alone while still enabeling you to take some of the very low end off a little, I suspect that will free up headroom and generally improve matters.
You have to remember that many playback systems will already atempt to do such things in order to decrease the load on the amp and the needed speaker size. Given that I´d perfer to do it myself before the amp can touch it. You can always keep another copy with a different mix for your own enjoyment.
opg
PostPosted: Wed Jun 29, 2005 6:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Laughing HILARIOUS! It's so true. Everything is becoming so portable these days, that people will all go blind and deaf from squinting at Dick Tracy video wristwatches and listening to loud, poorly-compressed music through headphones.
PostPosted: Wed Jun 29, 2005 6:34 am    Post subject: Reply with quote  Mark this post and the followings unread
opg wrote:
Laughing HILARIOUS!
No offence intended to the micromusic crowd which already believes these things, of cource. Some of my best friends think gameboys sound good.
:¬p
PostPosted: Wed Jun 29, 2005 6:53 am    Post subject: Reply with quote  Mark this post and the followings unread
The fact that I have a few silly bass pieces might be OT in this context anyway. I am very aware how gear works and what will selfcombust and why. Who knows, I might throw in a bonus CD for owners of high end state of the art hifi rigs.
As for playback devices, I guess we will soon see a trend towards hifi again. The last 15 years have been a period of convergence and the new low prices on iPods and "digital home entertainment servers" and what have you, pretty much concludes this phase.
Flickr
PostPosted: Wed Jun 29, 2005 7:08 am    Post subject: Reply with quote  Mark this post and the followings unread
I didn´t doubt that, I was trying to encourage you to not make it combust, then blame the HiFi. I don´t think your customers would like you if you did and so they´d never turn into fans. That would also greatly harm your chances of getting groupies, obliterating the subconcous "mating call" sides of bass frequencies. Realy, you might as well compose for triangle and picolo flute in that case!
Now that´s a good plan. Perhaps also have a multisession with readymade mp3´s on the data section, mixed for pc speakers. People will rip it to mp3 anyway, you may as well do it for them and mix it properly for the medium.
opg
PostPosted: Wed Jun 29, 2005 7:55 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't know, man. That sounds like a lot of work!
I try to keep in mind who my audience would be, what they use now and what they might possibly use in the future. If there is an album I really like and listen to from beginning to end, I'll listen to it on some big headphones. On another site, someone asked what albums do you own that you listen to the entire thing in one sitting. I mentioned Radiohead and Photek. I'm trying to remember what audio device I first heard the songs on......
Radiohead - Kid A and Amnesiac - headphones, CD
Photek - a PA system in some college students' apartment filled with weed smoke, on vinyl.
I choose to listen to Radiohead only on headphones. Photek does not sound good in a car (especially with some crap tape adapter), but does well on headphones. If I had listened to Photek in someone's car first, would I still have bought the album?
Audio files: 228
PostPosted: Wed Jun 29, 2005 11:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Good points by everyone. An interesting discussion.
A few months ago, Greg, Robin Miller and I went to see Rebecca Mercuri and Milton Babbit's talk about he RCA synthesizer. During Babbit's talk, he requested the tech to play one of his peices from 45 years ago. The music started and Babbit immediately asked him to stop it and make it louder. The tech made some adjustments and started playing the piece again. Babbit immediately stopped it again. He said, "This sound system can not play the music the way I intended it to be heard, so we won't play it at all."
I was very impressed.
Much of this discussion focuses on the fact that if the music is going to be played on mediocre equipment, then we better be aware of that and make the music in such a way that it sounds good on such gear. Well, when we do that, what happens when we play such music on really good playback equipment? Would it be heresy to say it might be mediocre?
Should painters paint so that their art looks good when reproduced in magazines? Should filmakers make films that look good on small TVs with tiny speakers?
Who are we creating music for?
opg
PostPosted: Wed Jun 29, 2005 11:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Good question. I think it coincides with my opinion of the article in the Commentary and Editorial section here:
http://electro-music.com/forum/post-44596.html#44596
PostPosted: Wed Jun 29, 2005 11:39 am    Post subject: Reply with quote  Mark this post and the followings unread
This is the production forum, so I guess in this context music= recorded music.
On the other hand, it is quite obvious that a lot of art doesn´t have suitable playback engines. A sensible 2 dimensional playback device for sculptures anyone? Should artists only design and make sculptures that look good as jpegs/gifs on a webpage?
Flickr
PostPosted: Wed Jun 29, 2005 11:44 am    Post subject: Reply with quote  Mark this post and the followings unread
I for one want to comunicate. I want to be able to play some of my pieces on big soundsystems and for other pieces I think it´s very important that people will be able to enjoy them in private and comfort, preferably alone in their own room. I mix for this. If I´d do a piece speciffically for a speciffic instalation then that´s a different matter.
I think the drama isn´t nearly as big as it´s made out to be here. With proper engineering and some knowledge of psychoacoustics a lot can be done, including drones. Realy.
Audio files: 228
PostPosted: Wed Jun 29, 2005 1:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, my questions were rhetorical.
From research I have done with John Meyer, see: http://electro-music.com/forum/topic-6944.html , and with Robin Miller, I know our ear/brains really can hear and discriminate very low bass. If you put in a high-pass filter and cut everything below 75 Hz, then you are throwing away two octaves. We only can hear 10, so that's 20%.
As people get older, their high frequency response starts to deteriorate, but not the low frequency. People who spend a bit of time listening to loud rock music often have their top octave trimmed. This makes the bass even more important, IMHO.
It is true that most speaker systems don't reproduce much below 75 Hz, but it is possible to get decent performance down to 25 Hz or less. Experiments with Robin Miller prove that at least down to about 45 Hz, you can perceive stereo. Not only that, but there are beautiful dramatic enveloping sounds that you can make when you use stereo at this range. Robin described some of these at his talk at recent Audio Engineering Society meetings, and at electro-music 2005. Perhaps I'll document these in a future post on the forum. Also, it has been proven that difference frequencies between the left and right can induce changes in brain wave frequencies, and this effect gets stronger as the frequencies get lower.
PostPosted: Wed Jun 29, 2005 1:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
I guess the reason Mahler wrote for the symphonic orchestra had nothing to do about communication. That´s´fine. Introverted art can be quite ok.
Flickr
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Wed Jun 29, 2005 4:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
While I agree with most of what Kassen said in his bass post above (thanks for some of those tips, really useful Very Happy), this is the one I don't necessarily agree with. I understand that by cutting out most of the sub you can make the music louder, and you'll be able to hear the lo-mid/hi-bass range alot better, but sub plays a huge part in almost every modern (released in the last 4-5 years), commercial (as in released on a label) electronic music recording I've heard. Doing these kind of cuts is very important, but (taking the example of house music) either your kick drum or your bassline should have that sub element (sometimes both if you're clever about it), otherwise your track misses out on the important body shaking bass that we all crave for on the dancefloor. For me anyway, alot of a bassline's groove has to do with when it enters that sub range and vibrates your body. If you took that out of many recordings you'd wreck the groove quite badly and the bassline wouldn't make sense. I think as long as your sub range is very clear and defined it is fine to have this in your music. The problems arise when either the sub area is too loud, or you've got more than one instrument with little bits and pieces in the sub range which messes it up and again wrecks whatever groove is happening over the top.
