Posted: Sat Aug 01, 2020 11:38 am Post subject:
PHBoS - PHOtism Subject description: Live improvisation, recorded July 31, 2020 |
Another improv, cut into 2 parts so if you're not bored yet after part A there is more!
I did remove a section from Part B as it had some annoying clicks*, but for the rest it is unedited.
unedited (but still 2 parts) on youtube: Part A, Part B
or uncut as it went out live on Twitch but this will only be temporarily available.
*the video recording doesn't seem to have it.
| Description: |
| Filesize: |
2.02 MB |
| Viewed: |
369 Time(s) |
| Description: |
| PHOBoS - PHOtism - Part A (Jul 31, 2020) |
 Download (listen) |
| Filename: |
PHOBoS - PHOtism - Part A (Jul 31, 2020).mp3 |
| Filesize: |
48.58 MB |
| Downloaded: |
2098 Time(s) |
| Description: |
| PHOBoS - PHOtism - Part B (Jul 31, 2020) |
 Download (listen) |
| Filename: |
PHOBoS - PHOtism - Part B (Jul 31, 2020).mp3 |
| Filesize: |
48.77 MB |
| Downloaded: |
2144 Time(s) |
Joined: Apr 03, 2004 Posts: 24493 Location: The Netherlands, Enschede
Posted: Sun Aug 02, 2020 7:18 am Post subject:
Part one was enjoyable .. bit of a French atmosphere I heard in it.
It was also good music to combine with some programming .. aand .. as there is more programming to do ... _________________ Jan
Posted: Sun Aug 02, 2020 8:19 am Post subject:
... so yeah, nice too, nice ending in the last 3 or 4 minutes. _________________ Jan
Posted: Tue Aug 04, 2020 3:54 pm Post subject:
Thanks jan
nice thing with doing endings is that it often has less restrains. Once I have a recording of a patch I can mess it up at the end
without worrying about not getting it back. This is also why my live music often goes on for quite a bit without a lot of change,
I want to see what I can get out of it before messing it up because unlike your amazing wren there is no save or undo. _________________ "My perf, it's full of holes!"
Posted: Tue Aug 04, 2020 4:52 pm Post subject:
Hah, but you don't want a live undo either .. but it is possible to parameterize chaos .. so you can fade from chaos to order as well ... like for instance getting your feedbacks (that can make the chaos) trough VCAa and then controlling it from wild to mild and the other way around.
Of course a digital VCA is a lot cheaper than an analog one, being 'just a multiply' in digital vs a 'fokkingmultiplicationfokthing' in analog.
Heh, and storage can be solved too [1]
BTW, there was a Formant version published by Elektor, which added lots of analog switches, DA converters, sample & holds & some what nots added to a Z80 computer .. just to have patch storage and undo and all. Wondering if anyone ever actually built that- it was pretty wild for those days.
[1] 1 just needs more modulars.
Posted: Tue Aug 04, 2020 5:46 pm Post subject:
Hmm, you're right about the chaos and I have done things like that before to some degree. Might have to experiment a bit more with it.
Though sometimes there are patches where even the slidest knob adjustment can make the whole thing collapse like a house of cards.
| Quote: | | BTW, there was a Formant version published by Elektor,.. |
If that was published in an issue of elektor magazine I should have it here.
Storing settings reminds me of Keith Emerson's moog, but by the looks of it that worked more like presets on an old radio or TV set.
It doesn't seem to record/store voltages it's just a prepatch system, but I haven't really looked into it. _________________ "My perf, it's full of holes!"
Posted: Tue Aug 04, 2020 6:26 pm Post subject:
| PHOBoS wrote: | | If that was published in an issue of elektor magazine I should have it here. |
I was spread over several issues .. maybe poly-formant ... maybe this .. https://www.elektormagazine.com/magazine/elektor-198205/44819 .. although that is pretty much unreadable .. it may have a correct date  _________________ Jan
