 Forum index » Online Music
AlanP's Awfulness
Page 3 of 3 [64 Posts]
Goto page: Previous 1, 2, 3
PostPosted: Tue Aug 14, 2018 12:07 am    Post subject: Reply with quote  Mark this post and the followings unread
The Gate Out of Stage 1 went to trigger the Elements input on the switch, Gate Out of Stage 5 went to trigger the Braids input on the switch. I could have ran the clock into a divide by 4, but then I might have sync issues.
Elements wound up going into the CGS60 Stompbox Adaptor, purely for additional gain to ramp it up to Braids' level. The minor shimmer in it's chuffs was from a LFO into the Tone CV for the Blow exciter. (The moving tone in the exciter has an effect on the resonator section in turn.)
I tried running the final mix into the Serge Resonant EQ to get rid of that minor blip when going from Elements to Braids, but no luck. I also tried delaying the Gate Out of Stage 5 a little bit (run that into the Gate In of the Rampage, run the Falling output of Rampage into the switch trigger, play with the Rise time to get a gate delay), but that also didn't do much. I'll have to think about it.
PostPosted: Tue Aug 14, 2018 10:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
AlanP wrote:
Chuff sounds was Elements, chord sounds was Braids in three-saw mode with the other two saws tuned lower and lower again, then run through a reverb.
Great sounds! Very Happy
my synth
PostPosted: Fri Nov 09, 2018 9:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Dad was around today, and I had some fun putting a patch together.
Changes roughly just after 4min into it.
 Filesize:  306.33 KB
 Viewed:  713 Time(s)
2018-11-10 dadfun.mp3
 Filename:  2018-11-10 dadfun.mp3
 Filesize:  7.88 MB
 Downloaded:  3073 Time(s)
PostPosted: Fri Nov 09, 2018 11:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
I can’t play it right now, one of the dogs starts barking when I play this...
Shocked
my synth
Audio files: 309
PostPosted: Sun Nov 25, 2018 1:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some nice Awfulness there :-)
(and can't blame the dogs for recognizing the sounds)
PostPosted: Tue May 14, 2019 11:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Had another play with the Appendage Touch Controller today. I'm not sure... but when I take my finger off the ribbon, sometimes the CV will drop very low, riiiight on the very end before the Gate goes low. In this patch, it was controlling Mutable Elements. (Pho, you really need to build this one!)
Erm, the background sequence is mainly to give me a beat, not for a melody to bounce riffs off.
I messed with the Contour knob on Elements a couple times.
2019-05-14 testtouch.mp3
 Filename:  2019-05-14 testtouch.mp3
 Filesize:  5.92 MB
 Downloaded:  2677 Time(s)
PostPosted: Sat Apr 25, 2020 11:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Short test of the snare, hi-hat (both open and closed), and the Bastl Tea Kick because why not. All sequenced by the mighty Per|former sequencer.
2020-04-26 drum test.mp3
 Filename:  2020-04-26 drum test.mp3
 Filesize:  904.97 KB
 Downloaded:  2317 Time(s)
PostPosted: Tue Apr 28, 2020 5:49 am    Post subject: Reply with quote  Mark this post and the followings unread
sounds great alan
PostPosted: Thu Jun 18, 2020 1:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Two NLC Triple Sloths modules were the core for this.
Voice A - 258 dual osc, one side's audio going into the FM for the other side (that I took the audio output from), going into the 291 Bandpass, then off to the output module.
Voice B - Braids, into Yusynth ARP4072, then output module.
Voice C - Haible Living VCOs, into audio mixer, into Yusynth Minimoog VCF, into output module.
All with liberal amounts of CV from the two triple sloths module.
2020-06-19 two triple sloths.mp3
 Filename:  2020-06-19 two triple sloths.mp3
 Filesize:  21.98 MB
 Downloaded:  2302 Time(s)
PostPosted: Fri Jun 26, 2020 4:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
208 Stored Program Sound Source with a basic krell patch, going through the MTM Reverb (wet/dry controlled by the 266 FRV.)
The 208 isn't completely finished, yet, still waiting on the spring tank.
 Filesize:  379.82 KB
 Viewed:  354 Time(s)
rec_20200627-104008_1.mp3
 Filename:  rec_20200627-104008_1.mp3
 Filesize:  17.65 MB
 Downloaded:  2244 Time(s)
PostPosted: Wed Oct 28, 2020 12:38 am    Post subject: Reply with quote  Mark this post and the followings unread
The last parts for my DIY 4MS Spectral Multiband Resonator turned up, soldering ensued, and playing around with it. This thing is insanely fun, and all I've done so far is run white noise into it, and plug various random voltages into it's control inputs!
The Dunno module (Buchla 266) is providing white noise, and clocked random voltages (which are going through comparators to provide triggers to rotate the bands either up or down in pitch), and the Triple Sloths module is providing CV to the Spread control, the Envelope CV In (I think), and the Resonance CV In. I'm not sure how much the last two were doing anything.
Lots of fun!
 Filesize:  397.4 KB
 Viewed:  329 Time(s)
2020-10-28 smr dunno sloth.mp3
 Filename:  2020-10-28 smr dunno sloth.mp3
 Filesize:  7.5 MB
 Downloaded:  2225 Time(s)
Audio files: 309
PostPosted: Sat Oct 31, 2020 5:39 am    Post subject: Reply with quote  Mark this post and the followings unread
AlanP wrote:
The last parts for my DIY 4MS [...] Lots of fun!
Some nice sounds from that one!
PostPosted: Fri Nov 19, 2021 6:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sloth providing CV to Orgone Accumulator, through the Easel, and then through the Manhattan SVVCF (HP mode). Other drone is the 258, run by the Dunno, through the 291 VCF in BP mode.
2021-11-20.mp3
 Filename:  2021-11-20.mp3
 Filesize:  4.39 MB
 Downloaded:  1910 Time(s)
Audio files: 309
PostPosted: Sat Nov 20, 2021 12:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wild track :)
