 Forum index » How-tos
interactions of no input feedback mixing consoles
Page 1 of 1 [6 Posts]
jm56k
PostPosted: Wed Feb 03, 2021 12:51 pm    Post subject: interactions of no input feedback mixing consoles
Subject description: (in a noise music context)
I would like to know if someone could shed some light on this :
I've tried to play with two no input mixing consoles at the same time.
So I plugged them both into a third one (say, line 1 and line 2)
I find that instead of having two independant sources that I could mix together using the third console, consoles 1 and 2 interact together, creating one interdependant signal.
So, when I change the settings of the first console, it will affect the other console as well.
I've also built a sequencer (this type of thing : https://hackaday.com/2015/02/23/logic-noise-the-switching-sequencer/ ) and when plugged into mixer 3, it behaves the same way as mixer 1 and 2, as an interdependant tool rather than a separate instrument.
Does anyone know how the signal is behaving in that type of configuration and if there would be a way to stop the interaction at some point in the circuitry ? (something using diodes maybe ?)
Thanks for reading!
PostPosted: Wed Feb 03, 2021 1:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
hmm not sure, what kind of mixers are you using ?
In theory if you connect a source to something (in this case a 3rd mixer) it should not affect the signal.
But I think because you are working with feedback it might be very sensitive to any noise because it gets amplified over and over.
The question is what is introducing the 'noise', what connections do the mixers share ?
jm56k
PostPosted: Wed Feb 03, 2021 1:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi !!
I'm using two behringer xenyx 802 and one 1002
Currently I'm using a very basic setup :
on mixer 1 and 2, control room out right goes to line 1 and control room out left goes to line 2.
Then, I send the main out of mixer 1 and mixer 2 to mixer 3 (line 1 and 2 respectively)
Also, the mixer power source is fed through transformers, so if I'm correct they don't share a common ground (so maybe some noise is induced there).
PostPosted: Wed Feb 03, 2021 2:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok, no shared power, no diy, so there's not much you can improve on the mixers themselves.
Something that could work is to eliminate the electrical connections between the mixers by using audio isolation transformers.
Transformers are bidirectional though so I don't know if this could still cause any crosstalk.
also
welcome party!
jm56k
PostPosted: Wed Feb 03, 2021 2:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks a lot = ))
I'll look into that !
jm56k
PostPosted: Sun Feb 28, 2021 8:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi !
So I've finally tried that audio isolation transformer solution and sadly it doesn't change a thing. *
If anyone has another idea, I'd be more than grateful!
* I've actually used a palmer dacappo re-amp box, but it does contain such a transformer I believe
