Posted: Sat Jan 30, 2021 12:44 pm Post subject:
at the moment the inputs from missing cells are connected to GND (0)
it's the standard Conway's Game of Life rulset so:
if there are less than 2 neighbours the cell is dead (off)
if there are 2 neighbours and the cell is dead it stays dead (off)
if there are 2 neighbours and the cell is alive it stays alive (yellow)
if there are 3 neighbours the cell is alive (green)
if there are more than 3 neighbours the cell is dead (red)
Since they are bicolor LEDs green is just the standard output dead/alive, and red is on either when alive with 2 neighbours or when there are more than 3 neighbours.
If I manually toggle an LED on it will be green, unless the red LED was already on than it will of course be yellow untill the next CLK. And if I manually turn it off it
will be either off or red depending on the state of the red LED. _________________ "My perf, it's full of holes!"
Joined: Apr 03, 2004 Posts: 24666 Location: The Netherlands, Enschede
Posted: Sat Jan 30, 2021 1:33 pm Post subject:
Thank you, will try to put that in  _________________ Jan
dk
Posted: Tue Feb 02, 2021 5:20 pm Post subject:
Got this now .. with some color patterns ... editable rules ... the deviation from standard life isthe 1,5,1 bit in the green rule - it seems as if the patterns are more easily ever lasting with that.
I'm not sure if I did the red rule right ... and I'm not sure I have all the links to neighbor cells set up ok .. but potentially this could be a nice way to explore the effects of different rules and starting patterns I think? (cells toggle live state with a click on them).
O ... and also ... PHOBoS ... you said you have a 12 step repeating pattern .. what is a starting configuration for it? (to check if I have the same thing you have ...).
Posted: Wed Feb 03, 2021 8:39 am Post subject:
oh that's a very nice cuby, was not expecting you'd go for 'LEDs' but just color the entire square.
I am trying to figure out your ruleset which looks to be something like: current state, neighbours, next state
but you left out the ones where there is no change between current and next state, correct ?
so for the standard life rules that would be:
GREEN: 1,0,0; 1,1,0; 0,3,1; 1,4,0; 1,5,0; 1,6,0; 1,7,0; 1,8,0;
RED: 1,0,0; 1,1,0; 1,3,0; 0,4,1; 0,5,1; 0,6,1; 0,7,1; 0,8,1;
there are 2 patterns that are easy to test (assuming my cube actually does work like it should)
the first one is a 4 step looping pattern which is set by creating a single band around the cube.
this band will then move up and down (at least for a horizontal band, it would move sideways for a vertical band)
note that it goes through a sligtly different pattern before it starts looping.
the other one is a triangle using the diagonal cells of 3 adjacent sides of the cube which will result in a 5 step looping pattern.
the one in the gif is the 12 step which is also pretty simple to set but a bit difficult to explain without labeling the cells. _________________ "My perf, it's full of holes!"
Posted: Wed Feb 03, 2021 10:18 am Post subject:
The numbering I'm using is:
| Code: |
// Numbering scheme for the cube of faces of panels of cells ...
// | 0 1 | 0 1 |
// | 0 | 1 |
// | 2 3 | 2 3 |
// +------ 0 ------+
// | 0 1 | 0 1 |
// | 2 | 3 |
// | 2 3 | 2 3 |
// | 0 1 | 0 1 | 0 1 | 0 1 | 0 1 | 0 1 | 0 1 | 0 1 |
// | 0 | 1 | 0 | 1 | 0 | 1 | 0 | 1 |
// | 2 3 | 2 3 | 2 3 | 2 3 | 2 3 | 2 3 | 2 3 | 2 3 |
// +------ 1 ------+------ 2 ------+------ 3 ------+------ 4 ------+
// | 2 | 3 | 2 | 3 | 2 | 3 | 2 | 3 |
// | 0 1 | 0 1 |
// | 0 | 1 |
// | 2 3 | 2 3 |
// +------ 5 ------+
// | 0 1 | 0 1 |
// | 2 | 3 |
// | 2 3 | 2 3 |
// a cell is a single LED
// a panel is a set of four cells
// a face is a set of four panels
// the cube is a set of six faces
Also having it as a txt file @ https://bluehell.nl/small_stuff/cube.txt - I had it printed, cut out and folded to a cube held together with some sticky tape.
And then each LED (or cell) has three numbers/coordinates (face, panel, cell) .. face number is in the center of the face (0-5) panel number in the center of the panel (0-3) cell/LED mumbers are 'as is'.
The triangle pattern works in some locations, not in others .. so I have some wrong connections The current .. seemingly wrong ... list of neighbors is @ https://bluehell.nl/small_stuff/neighbors.txt _________________ Jan
Posted: Wed Feb 03, 2021 12:00 pm Post subject:
I've been thinking to make something to set the cells of the cube in an easier way, likely with an arduino to keep it versatile and I have an idea
for something that I could then use as a fun controller. It's a bit silly of course as I could simply run the whole thing with an arduino that way.
but here's the thing; since I couldn't get ordinary 74HCxx flip flops to work I used the 555's which was also much more convenient for the PCB layout.
The 555's don't use a switch that has one side connected to GND or V+ so it can not simply be controlled with a logic 0 or 1. I'd have to bridge the
switch itself (I did add connectors for that) either with something like a 4066 or if I am lucky just a transistor will work. Of course I need to be able to
address all 96 cells individually so it will require 96 of them and because I don't have 96 outputs on an arduino i'd also need 12 8-step shiftregisters to
control those switches. I might design some PCB's for that too to keep it compact so it can easily fit inside the cube and save some time on soldering. _________________ "My perf, it's full of holes!"
Posted: Wed Feb 03, 2021 12:24 pm Post subject:
Ah .. ok .. that 12 step thing terminates here after 15 or 16 steps .. will check the cell connections ...
And, yes, you guessed the rule rule right (state,count, new-state) and indeed there is no need to specify rules that do not change anything.
Re. using the arduino to do the LED control directly .. you would not be able anymore to proudly say that it runs on your self designed systolic array computer
Ok, dinner and such first now .. then check on the neighbors  _________________ Jan
Posted: Wed Feb 03, 2021 12:43 pm Post subject:
| Blue Hell wrote: | Re. using the arduino to do the LED control directly .. you would not be able anymore to proudly say that it runs on your self designed systolic array computer |
yeah exactly
of course I'd only use it to set the initial state but I was thinking earlier how far I could get with eproms, programming some kind of presets.
but to trigger those presets ehm,. _________________ "My perf, it's full of holes!"
Posted: Wed Feb 03, 2021 2:58 pm Post subject:
Made it so that when ctrl-clicking on a cell it's neighbours will toggle .. found three mistakes that way .. and your patterns now behave as expected .. I think
Still not sure about the red rule tho ... but that is mainly decoration anyway
I gave it history .. so you can step back as well now (8192 steps max) .. can save patterns and rules in files .. red rule can be disabled to make it more clear to see what is happening ... can set the tempo for auto-step ... should be almost complete (except for projections of the faces on a rotating cube .. but .. might be able to beam stuff to an arduino thingie maybe .. trough a serial port emulation or something ... would that be handy for you?)
When done I'll publish it along with the source code. _________________ Jan
Posted: Thu Feb 04, 2021 11:32 am Post subject:
Could get it on a rotating cube after all
The cube faces seem to be incorrectly oriented ..but will get there  _________________ Jan
Posted: Thu Feb 04, 2021 4:22 pm Post subject:
| PHOBoS wrote: | | I guess I need to start working on my zero gravity chamber to get my cube to rotate. |
Hmm .. could you send power trough such a thing even? looks like ... _________________ Jan
Posted: Thu Feb 04, 2021 4:53 pm Post subject:
And a better one .. it's not exactly a 'for breakfast' thingie
Put the numbers in to be able to check the corect orientation of the faces. _________________ Jan
Posted: Thu Feb 04, 2021 5:52 pm Post subject:
The red is indeed different from what I have but for the rest I think it looks the same, so I guess that also confirms that my cube works correct.
And yeah red is just an extra bonus since I had 4 pins free per EPROM but to simplify it; red is on when a cell is alive and has exactly 2 neighbours
(creating yellow) or when it has more than 3 neighbours. Of course you can easily try different rules, or more colors (e.g. depending on the age of
a cell, or the exact amount of live neighbours)
anyway, looks awesome! now go get breakfast _________________ "My perf, it's full of holes!"
Posted: Thu Feb 04, 2021 6:00 pm Post subject:
| Quote: | Hmm .. could you send power trough such a thing even? looks like
if made from a non conductive material using (metal) ball bearings I guess that might work.
I actually had that thing in mind before but for putting it inside the cube with some magnets on it and use reedswitches to set the cells. _________________ "My perf, it's full of holes!"
Posted: Fri Feb 05, 2021 7:35 pm Post subject:
Two more .. the background image is not really an improvement .. as it wants the LEDs to be un-flat They suddenly look like stickers that are being added and removed ... and there is a lot of aliasing ... oh and the LEDs are a bit too big for the background.
Anyways .. will first try to get the red bits okaynow ..better. _________________ Jan
Posted: Sat Feb 06, 2021 12:03 pm Post subject:
This is how you get the borg, you know?  |
Posted: Sat Feb 06, 2021 6:31 pm Post subject:
| PHOBoS wrote: | here's a better background image, don't know if that would improve things though.
also, small detail, I rotated the faces in such a way that they are all perpendicular to eachother (if that makes sense).
Ah, ok, yeah I like that image better .. will see if I can rotate them for faces 2 and 4 .. and then maybe 5 as well .. will see .. they are decoration only .. so doesnt matter how I rotate 'm ... doesn't matter for functionality ... _________________ Jan
Posted: Sat Feb 13, 2021 6:03 pm Post subject:
A version of the PHOBoS cube software emulation is at :: https://bluehell.nl/small_stuff/cube-000.zip
In the zip is a Win64/release folder with in it a 2D and a 3D executable, the rest is source code. When you copy the exe to another location, also copy the back.bmp file - it is the background for the 3D cube .. that is if you want a PCB like background .. you can also put in your own drawing in back.pcb.
It is all a bit sketchy and the 3D version with everything turned on is a bit slow
But I think it can be used for experiments .. without having to reprogram all the EPROMs ... _________________ Jan
Posted: Sun Feb 14, 2021 5:28 pm Post subject:
Besides learning some 3D stuff for myself, my hope was for it to be useful for you.
So, anyway, if you have ideas for improvement for what you want to use it for, I'll try to change things for that. _________________ Jan
