today> Bill Fox solo tonight! Chez Mosc
 Forum index » Instruments and Equipment » Waldorf
Blofeld with low output and no phones
Page 2 of 2 [31 Posts]
Goto page: Previous 1, 2
nephilim
PostPosted: Sat Jun 04, 2016 12:31 pm    Post subject: Blofeld BFMB V2.03 NO Sound :(
Subject description: Sound problems with blofeld, of fix doesn't work for me.
Hey All! I've had a blofeld for a while and I really love it. I recently unplugged it and was considering posting on eBay.
I had a change of heart and decided to keep it but when I plugged it back in I got absolutely no audio from any of the outs, although if the headphones are in I do hear a pop when I power on, so presumably all the outs are receiving some signal.
Anyhow I was relieved to see the fix oft discussed but when I went to make the repair I found that I do not have the same pcb as is photographed in various "replace the 6.8ohm resistor" fixes.
My board seems to have a different layout. It says BFMB V2.03
Has anyone done this fix on this board or know anything about this problem?
It would make me sad to have to sell the blofeld for parts (cheap:() on eBay.
Is this my punishment for thinking of selling it in the first place?
Any help would be appreciated.
a100user
PostPosted: Fri Aug 12, 2016 8:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I have this problem too BFM V2.03 board and no sound.
So if anyone can help with identifying the problem resistor?
Thanks
http://a100usersplace.blogspot.com/
magiobus
PostPosted: Thu Sep 15, 2016 9:40 am    Post subject: Reply with quote  Mark this post and the followings unread
I opened my blofeld and couldn't find the resistor.
This post has an image of where is located http://www.stereoping.com/waldorf-blofeld-reparatur-toter-audio-output/?lang=en
but the problem is that in the photo it says on the board rev 1.something
and my board is different is v2 and the resistor is not located as the image.
Can somebody help me to locate the resistor in the v2 board?
magiobus
PostPosted: Thu Sep 15, 2016 9:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks
any progress?
a100user
PostPosted: Sat Sep 17, 2016 12:56 am    Post subject: Reply with quote  Mark this post and the followings unread
embarrasingly it transpired i had not chnaged my MIDI Local Off setting
mahavoice_skytravers
PostPosted: Tue Mar 01, 2022 2:09 am    Post subject: Blofeld has no outputs Reply with quote  Mark this post and the followings unread
This informations are for V2 mainboard of blofeld.
Replace R56 with new one the value is 5.1 ohm
You can also use 5.6 ohm.
 Filesize:  814.28 KB
 Viewed:  416 Time(s)
