Powering Multiple Modules with Repurposed Wall-Wart Supplies
Page 1 of 1 [2 Posts]
telstarmagikistferrari
Audio files: 43
PostPosted: Sat Jul 16, 2022 9:42 pm    Post subject: Powering Multiple Modules with Repurposed Wall-Wart Supplies Reply with quote  Mark this post and the followings unread
Hello all!
My question concerns how people tend to go about sourcing power for modular lunetta instruments. I believe I have around 10 modules. I have a 12v 2.5amp supply -- could I just put the ground and +v each to a little strip of perfboard and simply connect the modules thus? And would this be enough juice to run all of my modules without issue? Open to notions as to whether something closer to 5v would be better or worse. Thanks y'all.
Marck
View user's profile Send private message Visit poster's website Yahoo Messenger
PostPosted: Sun Jul 24, 2022 7:12 am    Post subject: Reply with quote  Mark this post and the followings unread
yep, that'll work, it's a method I've used myself too. Leave some space between V+ and GND, so either use seperate sections
of stripboard or leave a couple of unused tracks between them. Makes it easier to solder without worrying about shorts.
5V can be useful if you want to interface it with other things that run on 5V like an arduino and/or TTL logic. The downside is that
the chips can sink/source a lot less current so not ideal if you want to drive LEDs directly.
