pseudo random bit generator not working
Page 1 of 1 [14 Posts]
Estebandito
PostPosted: Wed Jun 21, 2023 12:16 pm    Post subject: pseudo random bit generator not working
Subject description: this must be electronics 101
Hi all,
I lifted the pseudo-random bit generator from the CMOS cookbook, breadboarded it and it worked. Had a pcb made, and now something’s wrong. I checked all connections, replaced every chip, and still, this happens: the circuit only runs when I touch or nearly touch the top half of the first IC in the circuit.
Working with cmos chips and Lunetta circuits is often so straightforward it makes me forget my basic theoretical knowledge of electronics is really rather poor. So when something like this happens, I am at a loss. Can someone point me in the right direction?
thanks!
IMG_3313.mov
 Filename:  IMG_3313.mov
 Filesize:  112.34 MB
 Downloaded:  215 Time(s)
PostPosted: Wed Jun 21, 2023 12:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd need a circuit diagram to have any idea what's going on but by the looks of it you have 1 or more pins floating.
Likely it's the chip in the top left but it could also be a pcb trace going to another chip that's picking up the noise.
PostPosted: Wed Jun 21, 2023 12:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmm .. it is touchy eh ... do you maybe have any unconnected (as in: hanging loose; not connected to anything) inputs?
Estebandito
PostPosted: Wed Jun 21, 2023 2:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
I used this circuit. Instead of 4013s I used 4015s, which was suggested as an option in the text. This means the outputs bar two on each 4015 are floating, but there aren’t any floating inputs.
 Filesize:  78.28 KB
 Viewed:  183 Time(s)
PostPosted: Wed Jun 21, 2023 2:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
what are pin 6,14 of the 4015 connected to ? and how is the clk input connected ?
Estebandito
PostPosted: Wed Jun 21, 2023 11:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is how I hooked up the circuit
 Filesize:  184.54 KB
 Viewed:  198 Time(s)
Estebandito
PostPosted: Thu Jun 22, 2023 12:00 am    Post subject: Reply with quote  Mark this post and the followings unread
The clock is a 555 timer oscillator
PostPosted: Fri Jun 23, 2023 6:31 am    Post subject: Reply with quote  Mark this post and the followings unread
so far so good, though 1M (SR2) could be too high to keep the data input stable.
I am actually wondering what the reason is behind having is connected through a capacitor, usually it's just connected directly.
I guess it might have something to do with that "optional starting circuit". You could try bridging that cap to see if that helps.
In the video it looks more like an issue with the CLK though, unless it's running at a high frequency.
Also, does IC4 have any unused XOR gates and if so did you ground the inputs of those as well ?
Estebandito
PostPosted: Fri Jun 23, 2023 11:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
The clock is running at a high frequency (101/102 cap and 1m pot). As for the 1uf cap 1m resistor circuit:
 Filesize:  785.57 KB
 Viewed:  146 Time(s)
Estebandito
PostPosted: Fri Jun 23, 2023 11:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
The other XOR inputs aren’t floating either, they are used in another circuit:
 Filesize:  308.81 KB
 Viewed:  184 Time(s)
Estebandito
PostPosted: Fri Jun 23, 2023 11:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
The second circuit is this one: https://makezine.com/projects/really-really-random-number-generator/
 Filesize:  61.23 KB
 Viewed:  167 Time(s)
zaphod betamax
PostPosted: Fri Sep 29, 2023 6:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Did you check for cold solder joints?
You said it would work if you touched the chip.
noto
PostPosted: Sun Oct 22, 2023 12:50 am    Post subject: Reply with quote  Mark this post and the followings unread
The shift register needs to be "seeded" to start. I noticed the capacitor polarity is reversed in your drawing. You might also want to buffer the output depending on its load
zaphod betamax
PostPosted: Tue Oct 24, 2023 11:15 am    Post subject: Reply with quote  Mark this post and the followings unread
I designed and breadboard this and it works well.
rough noise generator for evaluation Model (6).pdf
 Filename:  rough noise generator for evaluation Model (6).pdf
 Filesize:  18.84 KB
 Downloaded:  154 Time(s)
