Sustain pedal with andrromeda
Page 1 of 1 [4 Posts]
Macha1
PostPosted: Tue Mar 08, 2022 9:50 am    Post subject: Sustain pedal with andrromeda Reply with quote  Mark this post and the followings unread
Does any of the andromeda users here know if there is a setting somewhere in the menu of the a6 that handles sustain pedal use? Somehow none of my pedals work properly with the andromeda. Tried pedals with polarity switch but no luck.
Who has the solution ?
sunny pedaal
Audio files: 12
PostPosted: Mon Jul 18, 2022 3:54 am    Post subject: Reply with quote  Mark this post and the followings unread
how did you set the pedal input as source in the patch ...?
CoolColJ
PostPosted: Thu Jun 29, 2023 7:06 am    Post subject: Reply with quote  Mark this post and the followings unread
My old Yamaha FC4 pedal, purchased in 2011 works
made in Japan Smile
I find I have to have the sustain pedal plugged in before I turn on the A6, otherwise the polarity is reverse and it acts like switch only regardless of settings
CoolColJ
PostPosted: Thu Jun 29, 2023 7:10 am    Post subject: Reply with quote  Mark this post and the followings unread
sustain pedal automatically sustains the notes
Under the Pedal tab in the Global settings, you can set the pedal to continuous or switch, and reverse the polarity
Under the mod list there is a input for control pedal, foot switch, as well as midi CC
