multiple input and output switch wiring
Page 1 of 1 [2 Posts]
flatledge
PostPosted: Sat Jul 08, 2023 1:05 pm    Post subject: multiple input and output switch wiring Reply with quote  Mark this post and the followings unread
Hello,
I am building a CGS513 wave multiplier and made a panel that I am hoping to implement. What I am hoping to do is have one input and one output and have a toggle switch change through hardwired options. position one would be the input into the first multiplier, position two would be multiplier 1 into chained into multiplier 2, and position three sending the input into multiplier 2. Unfortunately I have not been able to wrap my head around this, or if possible. Would I be using an on-on-on and doing something with the inputs or outputs? any and all info truly appreciated!
Steveg
PostPosted: Sun Jul 09, 2023 12:57 am    Post subject: Reply with quote  Mark this post and the followings unread
You will probably want one of these kind of switches: https://www.altronics.com.au/switches/rotary-switches/
Most parts suppliers carry them so use one close to you.
Use a three pole switch first pole goes to multiplier 1, the second pole is to multiplier 2 and the third pole is to the output (whatever follows the multipliers).
Position 1 - pole 1 connects input to multiplier 1, Pole2 is not connected. Pole 3 connects multiplier 1 output to the next stage.
Position 2 - pole 1 connects input to multiplier 1, Pole2 connects multiplier 1 output to multiplier 2 input. Pole 3 connects multiplier 2 output to the next stage.
Position 3 - pole 1 is not connected, Pole2 connects the input to multiplier 2. Pole 3 connects multiplier 2 output to the next stage.
When I say "not connected" you may need to tie that connection high or low if leaving it float would be bad.
