Bit-crushing reverb: The ART DR2A
Page 1 of 1 [5 Posts]
Christoffer
PostPosted: Tue Apr 24, 2018 2:34 pm    Post subject:  Bit-crushing reverb: The ART DR2A
Subject description: Adding switches to the DAC of the DR2A to force individual bits to 0
I got this idea after snooping around in my lovely ART DR2A 1985-vintage reverb. it has a dedicated dip 12-bit DAC that's unlatched - the AM6012.
It'd be interesting to add toggle switches to all the incoming data lines, toggling between normal and 0. if one started from the least significant bit, you'd basically 'round down' lowering resolution; hi-res sound with 4/8/..-bit reverb!
Here's a quick doodle of my planned implementation, see attached. I'm avoiding putting switches directly in-line with the DAC, as the long leads might mess up normal operation, one key feature being that this mod can be turned OFF completely, retaining the original sound.
I'm unclear as to exactly how the DAC works, on the datasheet it seems the 4 most significant bits are treated differently; different timing pulse, separate latch etc.
I'll try this when I get the time. I'm going to put it all on a board that plugs into the DAC socket, the DAC plugging into a socket on the new board, so i can undo my damage again.
Has anyone done anything similar? Anyone worked with this specific chip before?
thanks for your time,
Chris
 Filesize:  97 KB
 Viewed:  597 Time(s)
--Christoffer
Christoffer
PostPosted: Mon May 14, 2018 1:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
So, this didn't attract as much attention as I'd hoped it would, but i think it deserves an epilog anyway;
I got a prototype wire-wrapped up and it did work as intended..ish. sound was terrible and response to each bit being flicked was at best erratic. the noise was unbearable, though, as i extended the entire DAC socket off-board to a wire-wrapped card. If this needs to be done, either have a DACrificial (hehe) AM6012 with pull-down resistors directly on the chip, and bend out/cut off the legs you don't want or design a small SMT chip carrier that keeps all distances VERY short.
Chris out
--Christoffer
PostPosted: Tue May 15, 2018 12:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
By placing this and function between the address generator (processor?) you introduce a delay of about 10 to 15 nsec. Maybe too much?
Also be sure to place a capacitor of say 100nF between vcc and gnd as close to the 74LS08 as possible.
my synth
djwizzz
PostPosted: Tue Nov 21, 2023 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Chris did you ever get to implement the Lo-Fi glitch for the art dr2???
just curious
was thinking about picking up one of these units
I have the dr1a but all the chips have the writing on them filed off so not very easy to figure out what's what
Please reply if you can
hageir
PostPosted: Wed Nov 12, 2025 3:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
Rise from your grave you dirty thread! LOL
I acquired a ART DR2a which I’m modding, someone had already been at it and upgraded the opamps hehe
Anyways, without a schematic (I contacted ART, they didn’t have it) I’m a bit in the blind…
I was very successful modifying my Yamaha REV7 by adding a LTC1799 variable clock into a strategic node on the data line. I can now vary the SAR DAC sampling rate, albeit also slows down the operating speed of the interface/CPU.
That was one node so to speak, where the signal was injected (old one lifted).
In this DR2a on the other hand, I have removed the Quartz crystal and when I inject the LTC1799 on the “left hand side” of the XTAL pad, I get the CPU/front panel operating, which slows down (strobing) to basically blinking LEDs BUT no sound.
If I inject the signal to the “right hand side” pad of the XTAL position, I get a variable frequency on the AM6012 DAC BUT no operation on the panel, it’s just frozen.
Any ideas?
Haven’t spent much time on it, at home now researching and brainstorming…
