 Forum index » DIY Hardware and Software » The Repair Shop
YAMAHA PSR6 CERTAIN NOTES DO NOT WORK IN ALL OCTAVES
Page 1 of 1 [4 Posts]
Daniel8393939
PostPosted: Fri Jan 19, 2024 8:20 pm    Post subject:  YAMAHA PSR6 CERTAIN NOTES DO NOT WORK IN ALL OCTAVES
Subject description: YAMAHA PSR6
Hello everyone, I recently bought a YAMAHA PSR6 but the notes E# and A do not work in all octaves. In addition to that, two buttons to change the sounds that it comes with do not work. I don't know if that has anything to do with it. In addition, I already checked the contacts and it doesn't seem like it. be the problem since they do not work equally well with the other good contacts, I don't know if someone could help me solve the problem in advance, thank you very much
Airlock
Audio files: 54
PostPosted: Sat Jan 20, 2024 4:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
https://www.youtube.com/watch?v=eJach-HanHw
In that video the guy used WD40 as a contact cleaner, I'd try contact cleaner first. There are other tips for those Yamaha keyboards in the comment section of the video too.
Daniel8393939
PostPosted: Sat Jan 20, 2024 10:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the help but that was not the problem, the problem was in the printed circuit, so I had to make a jumper to some pins and then everything worked correctly again
Airlock
Audio files: 54
PostPosted: Sat Feb 03, 2024 5:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Good job!
