speak_onion
Posted: Fri Nov 11, 2011 2:13 pm Post subject:
| wheely wrote: | | i would like to use this as an fx unit to mangle up drums live, has anyone tried that? |
Yep, it's one of the main things I do with my G2 Engine. See this set, where any drum distortion you hear is probably form the nord: http://soundcloud.com/speakonion/speak-onion-live-7-9-11-in Last edited by speak_onion on Sat Nov 12, 2011 9:15 am; edited 1 time in total |
wheely
Posted: Sat Nov 12, 2011 9:02 am Post subject:
thanks a lot for that information david.. i think i could defo benefit from one of these units.. i just missed one for £550 on ebay...
regards. |
kuki808
Posted: Fri Jan 25, 2019 9:59 am Post subject:
| thanks a lot! that's helpful! |
dorremifasol
Joined: Sep 28, 2006 Posts: 823 Location: Barcelona, Spain
G2 patch files: 49
Posted: Thu Sep 08, 2022 2:54 am Post subject:
Just read the very sad news about the passing of Rob Hordijk
I learned more about synthesis with his tutorials and his posts here in electro-music than anything else. He was such a great source of knowledge. My condolences to the family and friends. Thanks for all!
RIP, master. _________________ Cheers,
Albert |
Electromagnetic Wave
G2 patch files: 38
Posted: Thu Sep 08, 2022 3:10 pm Post subject:
| This is sad news. I learned a lot from what he shared too. Condolences to the family and friends. Thanks Rob |
dorremifasol
G2 patch files: 49
Posted: Sat Dec 14, 2024 2:26 am Post subject:
Unfortunately, the amazing Rob Hordijk's tutorial is no longer online.
It was an invaluable source of knowledge, not only for G1 and G2 users, but to anyone interested in synthesis in general.
Does anyone have a copy of the files?
I couldn't think of a better place to host the tutorial than here, at electro-music.com, to keep his memory and knowledge available for years to come.
Would that be possible? _________________ Cheers,
Albert |
Burp
G2 patch files: 7
Posted: Sat Dec 14, 2024 5:21 am Post subject:
I have downloaded it a long time ago. And yes, i have it still. I can make a zipfile and share it here as a start? _________________ if you don't know where you're going, you will allways arrive |
Joined: Apr 03, 2004 Posts: 24505 Location: The Netherlands, Enschede
Posted: Sat Dec 14, 2024 6:35 am Post subject:
Ja graag
I'd want to share it here  _________________ Jan
Posted: Sat Dec 14, 2024 6:38 am Post subject:
| dorremifasol wrote: | | Unfortunately, the amazing Rob Hordijk's tutorial is no longer online. |
It is a sort of a miracle already that that xs4all user site was kept up for so long.
I do not have it myself I think ... but great that burp has :)
Sad that things like this disappear, it makes the memories misty. _________________ Jan
dorremifasol
G2 patch files: 49
Posted: Sat Dec 14, 2024 9:02 am Post subject:
Here it is. I have downloaded it from Internet Archive and tweaked it to work a in local folder.
Edit : Blue Hell
I've put up an edited version in the wiki - it can be downloaded fromthere as well. I've removed the file that was originally posted here.
https://electro-music.com/wiki/pmwiki.php?n=Articles.SynthWorkShop _________________ Cheers,
Albert Last edited by dorremifasol on Sat Dec 14, 2024 10:29 am; edited 1 time in total |
Burp
G2 patch files: 7
Posted: Sat Dec 14, 2024 9:33 am Post subject:
| dorremifasol wrote: | | Here it is. I have downloaded it from Internet Archive and tweaked it to work a in local folder. |
I just wanted to pack it up and share it, but you found it yourself allready
Nice! _________________ if you don't know where you're going, you will allways arrive |
dorremifasol
G2 patch files: 49
Posted: Sat Dec 14, 2024 9:49 am Post subject:
I'm not sure if it works as it should. Could you upload your version as well?
I tried to remove things that Internet Archive puts in the html files, but it would be better to have the files as close to the original original files as possible. _________________ Cheers,
Albert |
Posted: Sat Dec 14, 2024 4:33 pm Post subject:
It looks ok to me, except some odd characters around 'overeasy' and a bit of a strange layout for the toc .. did some minor changes for that ...
Will now wait if Burp has something to add to this ... for now you can see it @
edit: I've removed the rrr one, it was - the sss one still is there : bluehell.nl / rrr / [ https://bluehell.nl/sss/ ]
edit: I've removed the sss one as well, theworkshop canbe found on the wiki : https://electro-music.com/wiki/pmwiki.php?n=Articles.SynthWorkShop and it can be downloaded fromtere as well. _________________ Jan
Burp
G2 patch files: 7
Posted: Sun Dec 15, 2024 1:44 am Post subject:
Ok this is the version i have. Unzip it to a folder and open the Index.html in a browser and it should work fine.
Edit by Blue hell :
https://electro-music.com/wiki/pmwiki.php?n=Articles.SynthWorkShop _________________ if you don't know where you're going, you will allways arrive |
Burp
G2 patch files: 7
Posted: Sun Dec 15, 2024 1:46 am Post subject:
I notice my version seems slightly bigger (the zipfiles) so there seems to be a difference. _________________ if you don't know where you're going, you will allways arrive |
Posted: Sun Dec 15, 2024 6:09 am Post subject:
| Burp wrote: | | [...]there seems to be a difference. |
Yes seems so .. had to rename Index.htm to index.htm as the webserver would not auto-serve the one with a capital I... it seems mac-ified a bit with an AppleTitle and an AppleIcon .. but .. it has the characterset set to windows-1252 which probably is original .. knowing how Rob would create html .. with µsoft tools.
Oh and the structure is a bit different too the rrr one has sub folders, the sss one not; I did not look at the details much though.
Now see : https://electro-music.com/wiki/pmwiki.php?n=Articles.SynthWorkShop - the workshop can be downloaded from there as well
edit: .. o hey there was a voting tool for that .. ah .. that's only on the first post in a thread it seems .. well .. then post here .. or i'll use the dice
And thank you Burp and dorremifasol  _________________ Jan
Burp
G2 patch files: 7
Posted: Sun Dec 15, 2024 7:12 am Post subject:
It is possible that i made some changes (years ago) to make it a bit easier to use on my macbook.
Nice to have it oneline available now! Thanks blue hell!
Vote? I did not notice any difference yet by looking at a few pages so don't know where to put my vote  _________________ if you don't know where you're going, you will allways arrive |
Posted: Sun Dec 15, 2024 8:14 am Post subject:
Ah no, for me there is no visible difference either .. the macified one seems closer to the original than the waybacked one .. to me  _________________ Jan
dorremifasol
G2 patch files: 49
Posted: Mon Dec 16, 2024 2:12 am Post subject:
Burp, in your zip there's no "SynthesisWorkshops.htm" file.
Jan, thanks for uploading the tutorial!
I remember having read about another tutorial more oriented to the first modular, or is it my imagination? _________________ Cheers,
Albert |
Burp
G2 patch files: 7
Posted: Mon Dec 16, 2024 4:23 am Post subject:
| dorremifasol wrote: | Burp, in your zip there's no "SynthesisWorkshops.htm" file.
I remember having read about another tutorial more oriented to the first modular, or is it my imagination? |
Never missed that file
Maybe you mean this one:
https://www.cim.mcgill.ca/~clark/nordmodularbook/nm_book_toc.html _________________ if you don't know where you're going, you will allways arrive |
dorremifasol
G2 patch files: 49
Posted: Mon Dec 16, 2024 4:56 am Post subject:
Ah Ok! I see it's "index.htm", sorry. _________________ Cheers,
Albert |
Burp
G2 patch files: 7
Posted: Mon Dec 16, 2024 5:12 am Post subject:
| dorremifasol wrote: | | Ah Ok! I see it's "index.htm", sorry. |
Ah ok, that makes sense. _________________ if you don't know where you're going, you will allways arrive |
InfernalGrape
Posted: Thu Dec 19, 2024 4:07 am Post subject:
Thank you all for your archiving efforts.
Hordijk's G2 pages are great inspiration and knowledge source. |
cube666999
Posted: Mon Feb 17, 2025 2:40 am Post subject:
Re: Has anyone updated the tutorials at clavia.se? Subject description: The source page no longer exists but is available in the webarchive. |
I thought it might be useful to someone.
https://web.archive.org/web/20070515203612/http://www.clavia.se/nordmodular/Modularzone/index.html
I just bought Clavia nord modular G2
I'm a bit late
I will be grateful for any other helpful learning materials.
Regards.
Jacob
| ark wrote: | Rob and others apparently wrote some interesting tutorials at http://www.clavia.se/nordmodular/Modularzone/index.html. However, those tutorials are for the Nord Modular, not the G2.
I've started going through them, and can usually figure out how to make the examples work on the G2. However, not having a Modular, I don't know for sure if I'm getting it right. So I am curious: Has anyone updated these tutorials to use G2 patches? |
Posted: Mon Feb 17, 2025 9:26 am Post subject:
This one I think? :: https://electro-music.com/forum/post-415660.html#415660
That is in the g2ools folders ... probably the dx patch converter is there too .. or maybe even converted patches .. i did see the original yamaha syx files somewhere on one of my harddisks btw. but not any converted patches.
And & congrats on the Nord and have fun
Edit - ow .. i thought you had asked for those - maybe already found .. I answered in the wrong place anyway  _________________ Jan
