G2 midi capabilities and limitations
Page 1 of 1 [3 Posts]
cappy2112
PostPosted: Mon May 05, 2025 11:24 pm    Post subject: G2 midi capabilities and limitations Reply with quote  Mark this post and the followings unread
I’ve never really played with the G2’s midi capabilities until now.
Is it possible to create patches which transmit midi on multiple channels?
Is it possible to create sequencer patches which transmit midi on multiple channels at the same time (6 different midi channels)? By transmit- I’m referring to sending midi data to the midi out connector as opposed to sending imidi to another slot.
Thanks
PostPosted: Tue May 06, 2025 2:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Multiple channels - sure ... you can select the channel to use on the send modules and can have as many of those as you want .. well .. maybe not .. but multiple Laughing
For reference I've added the G2 manual - see page 256 and a couple more there.
Nord Modular G2 English User Manual v1.4 Edition 1.4x.pdf
nord modular g2 manual
 Filename:  Nord Modular G2 English User Manual v1.4 Edition 1.4x.pdf
 Filesize:  10.53 MB
 Downloaded:  80 Time(s)
cappy2112
PostPosted: Wed May 07, 2025 10:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, I have a manual, but I’m not seeing the results I expected.
I either have the synth connected to the g2 configured wrong,
or my patch is wrong.
