today> Twyndyllyngs Chez Mosc
The Garden
Page 33 of 35 [854 Posts]
Goto page: Previous 1, 2, 3, ..., 31, 32, 33, 34, 35 Next
PostPosted: Wed Jan 21, 2026 8:24 am    Post subject: Reply with quote  Mark this post and the followings unread
I hadn't noticed the catkins yet, but did spot them today. Smile
I've also seen some flowering snowdrops and crocuses and 1 very eager daffodil that already has a flowerbud.
Witch Hazels are very nice but my favourite one is probably the Corkscrew Hazel (Corylus avellana 'Contorta').
PostPosted: Wed Jan 21, 2026 2:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
ah, kronkel hazelaar - yes, lovely Smile
PostPosted: Thu Feb 05, 2026 8:07 am    Post subject: Reply with quote  Mark this post and the followings unread
update on this post.
The largest one now has 2 flowers (might produce some more) and there is some green growth in one of the other pots.
edit: Spotted some buds in the other pots as well. They still have a very dark color so aren't very noticeable against the dark soil.
Also just spotted some flowers on the Rosemary, I wasn't aware they flowered in winter.
 Filesize:  144.72 KB
 Viewed:  65 Time(s)
 Filesize:  197.82 KB
 Viewed:  69 Time(s)
 Filesize:  195.72 KB
 Viewed:  64 Time(s)
 Filesize:  233.55 KB
 Viewed:  78 Time(s)
 Filesize:  177.53 KB
 Viewed:  76 Time(s)
PostPosted: Thu Feb 05, 2026 8:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Winter .. what winter .. heh .. i'm in Fryslân now .. bloody cold Shocked
Anyway, quite a temperature difference between north and south .. so no wonder i guess the rosemary is early.
It looks very healthy BTW, way better than mine at home or moms in the green house .. maybe it should not be inside ...
PostPosted: Sat Feb 07, 2026 10:32 am    Post subject: Reply with quote  Mark this post and the followings unread
It has indeed been quite mellow on this side of the country. Did have some frosty days but today I saw the thermometer on my balcony go up to 15°C.
I made use of it to check on my plants and water a bit where needed.
Getting plants through the winter can be rough. They usually do ok if they are planted directly in the soil or in a fairly large container and exposed to the elements
but even then there is no guarantee they'll survive. Main problem is usually not so much the cold directly but in combination with moisture and humidity.
In pots the soil can easily get too saturated or in my case dry out because they are sheltered. Though they are much more likely to survive dry conditions than wet ones.
In a greenhouse you have to be careful that the humidity doesn't get too high so it's always good to have some ventilation. Inside the house it's the opposite
as the air can get very dry during the winter. Also higher temperatures (heating) and low light levels aren't a great combo and on top of that the plants are
more susceptible to pests.
I wasn't the only one that noticed the nice weather today.
 Filesize:  155.17 KB
 Viewed:  67 Time(s)
Pansies are still doing great.
 Filesize:  203.45 KB
 Viewed:  67 Time(s)
 Filesize:  162.54 KB
 Viewed:  74 Time(s)
While I removed the dead leaves from the Aconitum I spotted some new growth under the mulch layer.
Covered it back up after taking the photos.
 Filesize:  390.39 KB
 Viewed:  71 Time(s)
 Filesize:  381.13 KB
 Viewed:  67 Time(s)
PostPosted: Sat Feb 21, 2026 11:33 am    Post subject: Reply with quote  Mark this post and the followings unread
spring is getting closer,.. or are we getting closer to spring ?
At least one of the snowdrops from last year has survived, there might be more but I think most of the green growth in the pot is from bird seed.
 Filesize:  162.15 KB
 Viewed:  61 Time(s)
It might not be easy to see but there are some flower buds on these small white daffodils.
 Filesize:  264.52 KB
 Viewed:  61 Time(s)
Some crocuses are appearing. They do seem to have a bit of difficulty poking through the moss and instead lift it up. I'll keep an eye on it and help out where needed.
 Filesize:  317.11 KB
 Viewed:  46 Time(s)
This one might open up completely tomorrow.
I've only spotted 1 so far but I didn't recognize it as an iris until a few days ago and there is a lot of other green growth showing up.
 Filesize:  163.76 KB
 Viewed:  59 Time(s)
 Filesize:  132.36 KB
 Viewed:  56 Time(s)
PostPosted: Sun Feb 22, 2026 4:37 am    Post subject: Reply with quote  Mark this post and the followings unread
and it did flower
I had a closer look at what else is growing in the planter and I am pretty sure I counted 9 more Irises, which means all 10 bulbs are coming up this year.
They might all open up in the coming week as the forecast is temperatures >10°C with even 18°C on wednesday and the nights are pretty mild too.
Next week is March 1st which is when I'll start with sowing pepper seeds. I might only sow Fresno this year but I'll have a look at the seeds I have.
I also still have 4 plants from last year which I kept inside and at least one of them still seems to be alive. The others don't look completely dead either
but I'll have to wait a bit to see if any new growth will appear.
I probably won't be buying much new plants this year (famous last words) as a lot seems to have survived outside in the little greenhouse. I've also sown
some things in autumn, made cuttings and have more seeds to start. There are 2 plants I do want to get though, one is a fern; Polypodium vulgare also
known as the common polypody, the other a dwarf conifer; Thuja orientalis Aurea Nana.
 Filesize:  177.08 KB
 Viewed:  48 Time(s)
 Filesize:  142.85 KB
 Viewed:  46 Time(s)
 Filesize:  116.22 KB
 Viewed:  60 Time(s)
PostPosted: Sun Feb 22, 2026 5:57 am    Post subject: Reply with quote  Mark this post and the followings unread
this is how things currently look, which I do believe is greener than usual around this time of the year.
 Filesize:  316.81 KB
 Viewed:  53 Time(s)
 Filesize:  380.26 KB
 Viewed:  54 Time(s)
 Filesize:  248.57 KB
 Viewed:  55 Time(s)
 Filesize:  359.49 KB
 Viewed:  57 Time(s)
 Filesize:  375.25 KB
 Viewed:  59 Time(s)
PostPosted: Sun Feb 22, 2026 3:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't remember where I originally got these flower pots from, I think someone might have put them by the side of the road.
I've had them for quite a while but always found them a bit bland so I decided to add a bit of paint. It's just acrylic paint
without any extra protection so I don't know if that will hold up well if I were to use them outside.
original on the left, painted on the right
 Filesize:  213.63 KB
 Viewed:  56 Time(s)
and that's all 4 of them done.
 Filesize:  215.22 KB
 Viewed:  58 Time(s)
PostPosted: Mon Feb 23, 2026 8:14 am    Post subject: Reply with quote  Mark this post and the followings unread
between all the rain there was a little bit of sun for a spring preview. sunny
they're opening up even faster than I was expecting and probably all of the Irises will be in bloom by tomorrow.
 Filesize:  360.54 KB
 Viewed:  55 Time(s)
PostPosted: Tue Feb 24, 2026 1:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
All Irises are in bloom today flower
I don't know what most of the other leaves belong too, I suspect Narcissus 'jetfire' but could be something else.
The weather is supposed to be sunny and fairly warm for the rest of the week so it wouldn't surprise me if some more green appears,
maybe the tulips will poke through as well. Also the Narcissus 'Arctic Bells' might flower by the end of the week.
 Filesize:  388.09 KB
 Viewed:  52 Time(s)
 Filesize:  258.04 KB
 Viewed:  58 Time(s)
PostPosted: Tue Feb 24, 2026 1:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Pretty Smile
And yeah .. short 'summer' on it's way Exclamation
PostPosted: Sat Feb 28, 2026 3:32 am    Post subject: Reply with quote  Mark this post and the followings unread
The Irises are already starting to fade, sadly they don't last very long and the warm weather probably didn't help with that,
but now the small daffodils are starting to open up. They do look more yellow than white at the moment (in the photos they appear less yellow)
but that might change to white over time. I also spotted a bit of red from one of the tulips in the planter hanging on the outside of the railing
that has bulbs from last year in it.
 Filesize:  136.82 KB
 Viewed:  52 Time(s)
 Filesize:  102.46 KB
 Viewed:  55 Time(s)
 Filesize:  98.55 KB
 Viewed:  55 Time(s)
 Filesize:  134.83 KB
 Viewed:  48 Time(s)
 Filesize:  210.25 KB
 Viewed:  47 Time(s)
PostPosted: Tue Mar 03, 2026 12:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
the bees are waking up:
 Filesize:  312.12 KB
 Viewed:  51 Time(s)
more crocuses are starting to poke through than I was expecting. The tallest one was growing under a cover I added as protection for the Atropa Belladonna plant (you can see it just behind the crocus, being enjoyed by some aphids)
 Filesize:  336.45 KB
 Viewed:  52 Time(s)
New growth on both the Agastache and Solidago. The Verbena bonariensis already died before the winter but I took some cuttings. The bulbs that are coming up might be the Irises from last year.
 Filesize:  330.13 KB
 Viewed:  47 Time(s)
Not only the Daffodils are opening up, the hellebore is growing and producing more flowers as well.
 Filesize:  225.25 KB
 Viewed:  51 Time(s)
PostPosted: Sun Mar 08, 2026 6:19 am    Post subject: Reply with quote  Mark this post and the followings unread
you'd almost think it's spring,.. dwarf
 Filesize:  139.97 KB
 Viewed:  40 Time(s)
 Filesize:  144.03 KB
 Viewed:  52 Time(s)
 Filesize:  249.76 KB
 Viewed:  45 Time(s)
 Filesize:  265.9 KB
 Viewed:  43 Time(s)
 Filesize:  274.9 KB
 Viewed:  46 Time(s)
PostPosted: Sun Mar 08, 2026 9:51 am    Post subject: Reply with quote  Mark this post and the followings unread
oh yes Wink
in mom's garden.
spring snowflake - Leucojum vernum
 Filesize:  190.52 KB
 Viewed:  48 Time(s)
PostPosted: Sun Mar 08, 2026 12:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
blue hell wrote:
oh yes Wink
in mom's garden.
very nice Very Happy, don't think I've seen those before.
I've put them on my list of possible bulbs for next year, looks like they can get quite large.
PostPosted: Mon Mar 09, 2026 5:09 am    Post subject: Reply with quote  Mark this post and the followings unread
not as big though as the summer ones .. Leucojum aestivum .. https://en.wikipedia.org/wiki/Leucojum_aestivum
but they are said to be 'difficult' and did take a long time to feel at home in mom's garden .. maybe something with symbiosis?
Oh and you need scilla's too .. if you do not already have those :) [ https://en.wikipedia.org/wiki/Scilla ]
PostPosted: Mon Mar 09, 2026 9:12 am    Post subject: Reply with quote  Mark this post and the followings unread
ah, those are the summer ones. I just looked for Leucojum and didn't realize there were summer flowering ones.
I also saw Leucojum autumnale which, as the name suggests, flowers in autumn and looks lovely.
If they're difficult to grow and need some time to establish they probably aren't very suitable for me though.
Oh and you need scilla's too .. if you do not already have those Smile [ https://en.wikipedia.org/wiki/Scilla ]
I do have Scilla bifolia 'Rosea' this year and also Puschkinia scilloides var. libanotica which looks somewhat similar, both seem
to be some sort of hyacinth. Some of it has started to poke through the soil.
I already like this package of circus balls.
 Filesize:  187.21 KB
 Viewed:  43 Time(s)
In the planter which has some of the bulbs from last year the tulips are starting to open up. There's also quite a bit of self seeded Cerastium glomeratum (mouse ear chickweed) growing in there. It's welcome to stay for now until I sow fresh Phacelia.
 Filesize:  414.29 KB
 Viewed:  46 Time(s)
The violas are still going strong, the scraggly stuff is a mix of aliums and all the green stuff behind it are the large daffodils from last year. There is also another Hellebore (possibly two) that is growing new leaves.
 Filesize:  304.12 KB
 Viewed:  42 Time(s)
PostPosted: Sun Mar 15, 2026 8:39 am    Post subject: Reply with quote  Mark this post and the followings unread
The temperature dropped again and there even was a bit of snow yesterday but today brought a couple rays of sunshine.
it started with a single yellow one and now there are three purple ones, I think there should be some white ones in this mix as well.
 Filesize:  409.24 KB
 Viewed:  39 Time(s)
 Filesize:  121.34 KB
 Viewed:  40 Time(s)
 Filesize:  101.34 KB
 Viewed:  48 Time(s)
opening up to catch those rays of sunshine
 Filesize:  190.13 KB
 Viewed:  36 Time(s)
I repotted the Armeria pseudarmeria from the photobox planter to a hanging planter. It is looking a bit deflated but that's how it has looked for the past couple of months and it is slowly starting to perk up. (peace lily photobombing in the background)
 Filesize:  420.46 KB
 Viewed:  47 Time(s)
PostPosted: Sun Mar 15, 2026 12:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
That white scilla is very nice :)
PostPosted: Tue Mar 17, 2026 9:40 am    Post subject: Reply with quote  Mark this post and the followings unread
blue hell wrote:
That white scilla is very nice Smile
They are indeed very nice but both the scilla and Puschkinia do get overshadowed by the Daffodils.
When I planted the bulbs I mixed them up a bit to get a somewhat even spread without being too organized.
I think for next year (planted at the end of this year) I will group them a bit more and keep the Daffodils at the back edge.
I do really like these Narcissus 'Jetfire', the yellow and orange are just the right color and combine really well
with the bright red tulips, which are now starting to become visible in this planter as well.
 Filesize:  239.64 KB
 Viewed:  46 Time(s)
 Filesize:  196.77 KB
 Viewed:  44 Time(s)
PostPosted: Tue Mar 17, 2026 10:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Some Hyacinth action.
One of the large ones is starting to open up. It's a very nice shade of pink which goes great together with the yellow Hellebore.
The other large Hyacinth (in a separate pot) appears to be a dark purple but needs a couple more days before it will open up.
I also spotted 2/3 of the remaining large ones that are planted in the pot with the Violas. I had a careful dig in the soil and number 3
is on its way as well. Once they are a bit larger I'll probably remove the Violas which are holding on longer than I was expecting.
Last years Grape Hyacinths that are planted in the pot with the Buddleja have some visible flower buds as well now.
These can just stay in that pot as long as the Buddleja survives and hopefully will multiply and spread out over time.
I think there are already more than the 10 that I started with last year.
One of this years Grape Hyacinths is also starting to bloom while also housing a family of aphids.
I was hoping that the foliage of these broad leaved ones would combine better with the large daffodils and tulips
than the regular Grape Hyacinths and it appears that it does.
 Filesize:  144.71 KB
 Viewed:  50 Time(s)
there's also new growth visible on the Buddleja
 Filesize:  399.41 KB
 Viewed:  38 Time(s)
 Filesize:  324.42 KB
 Viewed:  35 Time(s)
 Filesize:  123.7 KB
 Viewed:  44 Time(s)
PostPosted: Tue Mar 17, 2026 10:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Not only are more of the spring bulbs flowering, I spotted some lovely small flowers on the Brunnera as well.
It was still growing in the greenhouse which made it very hard to reach for insects so I moved it to a more suitable spot.
I only noticed after I took the photos that it had a visitor. I don't know if it was already on there before I moved it.
 Filesize:  401.37 KB
 Viewed:  39 Time(s)
 Filesize:  119.86 KB
 Viewed:  38 Time(s)
PostPosted: Sat Mar 21, 2026 6:50 am    Post subject: Reply with quote  Mark this post and the followings unread
SPRING IS HERE!
(at least on this side of the planet)
flower dwarf cheers love xxsun banana smurfin
 Filesize:  208.28 KB
 Viewed:  31 Time(s)
 Filesize:  291.1 KB
 Viewed:  34 Time(s)
 Filesize:  214.57 KB
 Viewed:  43 Time(s)
 Filesize:  166.49 KB
 Viewed:  39 Time(s)
 Filesize:  201.33 KB
 Viewed:  33 Time(s)
