Out module "Solo"
Page 1 of 1 [2 Posts]
PostPosted: Sat Jul 23, 2005 9:38 am    Post subject: Out module "Solo" Reply with quote  Mark this post and the followings unread
I want this post to be both a wishlist feature and request for a work-around (I should say efficient work-around, in both implementation & use).
I'd like a way, *in a performance or slot*, to select 1 output module, and solo it. So as I'm developing a performance I can instantly bring in/out the *rest* of the soundscape as I concentrate on one section. Some of the drums I work on have multiple sounds in 1 patch, so muting patches doesn't work that well.
Ideally, this would manifest as a button right next to the "mute" button on the various output/mixer modules. I'd also like to use this for checking points in a patch with an oscope quickly (though the mixer does fine for this).
The best method I'm working on now is by reserving some space in 1 slot that has MIDI control over all the "mutes" in the other slots. Any other suggestions?
Audio files: 327
PostPosted: Sat Jul 23, 2005 10:58 am    Post subject: Reply with quote  Mark this post and the followings unread
I occasionally set up variations just for muting or soloing some things. The G2 leaves a little to be wished here indeed. (I'd also like to have some way to mute MIDI out modules f.i.).
Your idea is that soloing should work over all four patches in a performance, right ?
In that case MIDI seems to be the only way to go now.
When solo buttons would be implemented I'd welcome some visula feedback on all the output modules that were un-solo'd by some other one - this might save some headaches :-)
Jan.
