logic question
Page 1 of 1 [5 Posts]
James Insert
PostPosted: Thu Aug 11, 2005 12:40 pm    Post subject: logic question Reply with quote  Mark this post and the followings unread
hi all, i'm new to the list...
what is the best way to have two, mixed constants (each with its own individual bias), flip flop back and forth so that only one is modifying a control input at a time?
i'm on the right track with this, but I can't seem to get it quite right.
i'd appreciate any help.
james
Audio files: 236
PostPosted: Thu Aug 11, 2005 2:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
First, welcome to electro-music.com and to the world of G2.
There are many ways to do what you are trying to do. Here is one of them.
There is a level compare module that is tracking a sine wave LFO. When it goes above 0, the output goes to 64 which controls a 2-1 switch which is connected to two constant modules. The osc gets one or the other constant voltages.
CV Switch.pch2
Shows how to use the 2-1 switch with a level comparitor.
 Filename:  CV Switch.pch2
 Filesize:  1.09 KB
 Downloaded:  2883 Time(s)
PostPosted: Thu Aug 11, 2005 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Welcome James.
There are several possibilities, it depends on what you want exactly.
When you want a manual switch just take the sw2-1 module from the switches page.
When it has to be automatic you could use a valSw2-1 or an X-fade and control one of those from a LFO or something.
When it has to toggle with a push button you could use a flip flop module for that in divide by two mode - this is described in the help file in the module reference in the flip-flop section, near the end.
One of the ff's outputs could then control the x-fade or the valsw, and the ff's input would be taken from a momentary action switch then.
Jan.
Audio files: 236
PostPosted: Thu Aug 11, 2005 2:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
James, the forum tried to send you an email message about responses to this topic. It was bounced back because of quota exceeded on your inbox. Thought you'd want to know.
James Insert
PostPosted: Thu Aug 11, 2005 6:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks guys. this definitely solved my problem. so many modules to choose from is never a bad thing.
sorry mosc, i'll fix my email. i know that gets annoying when moderating lists like this.
