0k, here's a pic of my first SL...
Page 1 of 2 [41 Posts]
Pehr
PostPosted: Wed Aug 24, 2005 4:15 am    Post subject: 0k, here's a pic of my first SL... Reply with quote  Mark this post and the followings unread
Here's how my Sound Lab looks right now. Very Happy There's nothing inside it yet but it will be finished soon. The manual gate button is missing too. Razz
I'm also having trouble finding 1/4W 5% resistors with the values 200k, 20k, 2M and 3M, but I'll figure something out... Confused
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
Wild Zebra
PostPosted: Wed Aug 24, 2005 6:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Boy your diving in head first huh. Sweet. This was my first BIG project, but its laid out so nice if you take your time and follow the instructions you can't go wrong.
"your stripes are killer bro"
PostPosted: Wed Aug 24, 2005 7:42 am    Post subject: Re: 0k, here's a pic of my first SL... Reply with quote  Mark this post and the followings unread
perhaps you can find some at http://electrokit.se ?
Flickr
Pehr
PostPosted: Wed Aug 24, 2005 7:48 am    Post subject: Re: 0k, here's a pic of my first SL... Reply with quote  Mark this post and the followings unread
Nope, I've tried electrokit, trimlog and elfa... I guess I have to use two resistors in series instead. I think it could work if I mount them vertically.
YouTube channel
flickr photostream
Clack
PostPosted: Wed Aug 24, 2005 8:18 am    Post subject: Reply with quote  Mark this post and the followings unread
wow thats really nice/slick, you got those sexy knobs I cant find , where did you get them from? is it black laminated wood?
I had weird results with resistors , use accurate ones when joining them i got some really far off results. this program is great if you want parralell
http://www.computertorture.com/noncompliant/parallel/ gives you a table of possible combinations.
Pehr
PostPosted: Wed Aug 24, 2005 8:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Nope, those are plastic knobs, just the cheapest I could get. I bought them from www.trimlog.se ( http://www.trimlog.se/butik/products.asp?varugrupp2=Ratt%20-%206mm%20axel ).
Hmmm, havn't thought about that... I think I will use 5% in series anyway, I'll just measure them before I mount them ^_^
YouTube channel
flickr photostream
Macaba
PostPosted: Wed Aug 24, 2005 8:31 am    Post subject: Reply with quote  Mark this post and the followings unread
If you are really stuck, i've got those values in my spares collection, i'm sure we could come to an arrangement.
Pehr
PostPosted: Wed Aug 24, 2005 8:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Really? That would be great! :D
The 5% 1/4W resistors that I need is:
500 (2)
20k (8)
200k (4)
620k (1)
2M (2)
3M (1)
It would be great if we could come to an arrangement. :D
YouTube channel
flickr photostream
opg
PostPosted: Wed Aug 24, 2005 9:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Be sure to put up a sound sample when you are finished! I'm planning on building that SL from MusicFromOuterSpace in the coming months.
Pehr
PostPosted: Wed Aug 24, 2005 9:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Of course I will
YouTube channel
flickr photostream
dnny
PostPosted: Wed Aug 24, 2005 9:34 am    Post subject: Reply with quote  Mark this post and the followings unread
wau -Pehr you are fast!
it looks really good
i have been doing my SL for about 6 moths ?
and i´m stuck whit the panel and many mods . . .
but soon i will join the SL club...
good luck whit wiring up
dnny
www.koelse.org
flickr: cable porn group
Audio files: 235
PostPosted: Wed Aug 24, 2005 9:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Pehr, looks great. Congrats.
Wild Zebra
PostPosted: Wed Aug 24, 2005 9:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Sorry to jump in, but it sorta is on track. A while ago I made the sample and hold and I didn't have a 330k resistor so I put two in parallel.
Well without thinking I assumed a 300K in parallel with a 30K would make 330k is this correct? Does series or parallel make a diff with resistors?
I would think not? I know it seems like a silly question.
It shows my electronic ignorance and newbism
Audio files: 235
PostPosted: Wed Aug 24, 2005 9:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Resistors in serial are added. 300K in series with 30K is 330K. Parallel is more complicated.
If there are just to the resistors in parallel the equation is
Reffective = (R1 * R2)/(R1 + R2)
It's called the product over sum rule.
Wild Zebra
PostPosted: Wed Aug 24, 2005 9:52 am    Post subject: Reply with quote  Mark this post and the followings unread
So I reckon I should get out the old solder braid and put'em in series. Maybe thats why its acting up.
How bout caps 2x 1uf in parallel = 2uf? Or is it the same type of theory
Pehr
300k in parallel with 30k would make (300k*30k)/(300k+30k)~27k right?
300k in series with 30 would make 330 k Smile I think...
YouTube channel
flickr photostream
Audio files: 235
PostPosted: Wed Aug 24, 2005 10:01 am    Post subject: Reply with quote  Mark this post and the followings unread
You are right. Caps in parallel - add the two values together. It's the opposite of resistors.
Wild Zebra
PostPosted: Wed Aug 24, 2005 10:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Learning all the time. Well the rate pot on my S&H seems to bunch up real bad about half way through and the said resistor is in line with the pot
so I bet when I put em in series, boo yah. Its gonna work. Hopefully I haven't damaged anything. It seems to work fine excepy for the rate.
Hey thanks for your help MOSC and Pehr(and sorry for the thread hijack)
etaoin
PostPosted: Thu Aug 25, 2005 5:20 am    Post subject: Re: 0k, here's a pic of my first SL... Reply with quote  Mark this post and the followings unread
I found that while impossible to find over here at 5%, they were pretty much stock items everywhere at 1%, which I guess is even better anyway. Since I needed to buy those 100 at a time, if anyone in or near the Netherlands needs some 200k, 20k or 2M, I have plenty left... The only one I couldn't find in the end was the 3M one.
PostPosted: Fri Aug 26, 2005 1:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
The 2M I made from 1M*2 in series.
The 3M I made from a 1M8 and a 1M2 in series which are heaps easier to find.
Just be sure to check the total before you put it in.
Anything you can't find in 5% is better in 1%
Audio files: 235
PostPosted: Fri Aug 26, 2005 4:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's another trick that might be helpful. 1%, 5% and 10% resistors are virtually all the same, they are just speced to be closer to the exact value. So, if you have a bunch of 10% 10K resistors for example, and the spec is for 5% ones, just measure the ones you have. If the value is withing 5% of 10K (9500 and 10500) then consider it as a 5%. The same trick can be used to find resistors that are within 1% of the specified value. Sometimes you'll be lucky and find some good ones. The resistors themselves won't age any differently.
Pehr
PostPosted: Wed Sep 07, 2005 7:23 am    Post subject: Reply with quote  Mark this post and the followings unread
0k, I'm finished Very Happy
Here's some pictures and a sound file
YouTube channel
flickr photostream
Wild Zebra
PostPosted: Wed Sep 07, 2005 7:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Alright, alright sweet all done. Nice sound file. I'm about to post some completed photos I finally got from a friend.
Ever hear of the Tall Dwarves? I think they are/were from New Zealand
anyway 2 guys they moved apart after awhile and started sending Tracks back and forth to make their records. Thay did an Album were they asked fans to send tape loops or single tracks and they recorded an album around them. Pretty sweet record. Well maybe a International
Sound Lab recording is in order. Huh Huh maybe. Record a track and pass it on. Just a thought.
Macaba
PostPosted: Wed Sep 07, 2005 8:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Ow. That sound file reaches painfully high frequencies. Ow. Very Happy
Pehr
PostPosted: Wed Sep 07, 2005 12:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! Cool
I'm already building a second one, and soon there will be a sequencer and a keyboard for them
YouTube channel
flickr photostream
