SuperKoopa
dnny
Joined: Mar 12, 2005 Posts: 519 Location: Helsinki, Finland
Posted: Fri Sep 02, 2005 12:29 pm Post subject:
on the web i have seen these ribbon controller instructions:
and more advanced:
but there is no gate option on these but your "touch the ground" - idea will be perfect to generate the gate. so if we combine these whit your design i think it will work on SL whit out frying it. but in any case the 9.1V zener is not a bad idea at all to protect SL CV inputs
or if you are planning on something more complicated you can make this board and include keyboard and ribbon controller to the keyboard bus input. and for all you looking for descent power supply this board has a +/-12V PSU included! so you can power up all those modules - and SL _________________ Association of experimental electronics
www.koelse.org
flickr: cable porn group |
SuperKoopa
Posted: Fri Sep 02, 2005 12:47 pm Post subject:
The Simpliest idea for the single bus keyboard (With any else but the bus, resistors and switches ) is to put two switches for each key or a dpst switch for each key.One is for CV the other simply put to ground the pin 2 of S1.
In this way will be lost portamento legato ... ,but I think that this is the simpliest and better way to build a keyboard controller. |
Clack
Joined: Aug 08, 2005 Posts: 438 Location: Walthamstow - london
Posted: Fri Sep 02, 2005 3:20 pm Post subject:
| if you have some lying around anti-static bags work ( ive found all the ones with low enough resistance are genrally black ones ) |
Macaba
Posted: Fri Sep 02, 2005 3:50 pm Post subject:
To further the point about anti-static bags, its the ones that are a black non-seethrough plastic that are best, NOT the silvery see-thro ones.
EDIT: To further my further point, the black bags are matt in appearance. You should know exactly what i'm talking about now.  |
SuperKoopa
Posted: Fri Sep 02, 2005 4:36 pm Post subject:
Sorry I've made a big mistake
touching pin2 of S1 we will not put this point to ground directly,but via a 50k-200k resistor (this is the typical resistance of an human body).I don't know what this really implies but I think that in this way we don't put to 0V pin2.(Is this true?)
One suggestion may be a glove with a piece of conductive material glued on the top of a finger,connected directly to the SL ground.
maybe it isn't a powerful and free control but it's so '80s ! |
Joined: Jan 31, 2003 Posts: 18298 Location: Durham, NC
Audio files: 235
Posted: Sun Sep 11, 2005 9:27 am Post subject:
What keeps the tension? _________________ --Howard
my music and other stuff |
Posted: Sun Sep 11, 2005 10:09 am Post subject:
| mosc wrote: | | What keeps the tension? |
well that's it. I was hoping that someone would shed a bit of light on this ;) The string holds no tension but I thought copper wire may be a better option. What are your thoughts?
Tom :) |
Posted: Sun Sep 11, 2005 10:14 am Post subject:
| a continuous loop? that would do it- wouldn't it? |
Macaba
Posted: Sun Sep 11, 2005 10:22 am Post subject:
| Loop is the best idea, with a return line basically. |
SuperKoopa
Scirocco
Joined: Dec 11, 2005 Posts: 22 Location: Barcelona/Catalunya
Posted: Wed Jan 11, 2006 2:58 pm Post subject:
I´m trying to buid the ribbon controler without any success at the moment.
I´ve been using 8mm and VHS video tape but it seems to have a really-low conductance
I´ve used 1/4 " audio tape from my old akai reel-to-reel too and it works ,but not fine,too much resistance (about 10M in about 2" or 5 cm. +/-)
I´ll have some 1/2" audio tape soon and I´ll it with anti-static bags to see wich´s better material .
Anyone has some pics of a well done ribbon  _________________ Have a nice day
http://www.flickr.com/photos/monocapa/ |
Scott Stites
Audio files: 96
Posted: Wed Jan 11, 2006 3:17 pm Post subject:
An alternate type of conductive material may be that strap material that is used with the little webbings one wears on one's feet in order to dissipate a charge through conductive flooring.
Check out the late Larry Hendry's site here:
http://www.wiseguysynth.com/larry/ribbon/ribbon.htm
Scott |
Posted: Fri Jan 13, 2006 6:45 am Post subject:
Another thing worth checking out is the black foam they use for storing static sensitive chips. I've tested this and it works. If you could get a long enough piece, it would just be a case of deciding how wide (and therefore how much R per centimetre) you want to cut it. You could even cut a tapering piece and get a log "strip" I suppose. _________________ What makes a space ours, is what we put there, and what we do there. |
Scirocco
Posted: Fri Jan 13, 2006 8:11 pm Post subject:
Ty very much, really cool link, and I´ll take a look at that black foam to see what happen...  _________________ Have a nice day
Scott Stites
Audio files: 96
Posted: Fri Jan 13, 2006 11:50 pm Post subject:
Tom Henry's Percussion book has a section that details making drum pad trigger sensors out of the conductive foam (placing it between two blank copper PCB's).
I don't know if they've changed the makeup of that stuff since then, but I do know in the past the black foam, over time, has been know to degenerate into a nasty black goo. I've got some IC's that were put in that stuff in the late 80's that wound up with gooey legs as a result. Maybe it's improved since then.
Scott |
Posted: Sat Jan 14, 2006 2:56 am Post subject:
You can scrub it off with "Servisol" or a similar hydrocarbon cleaning solvent. Isopropyl alcohol would probably do it too.
The foam I've got is brand new, so I don't know how it will age. _________________ What makes a space ours, is what we put there, and what we do there. |
